I recommend contacting your local authorized service center for assistance.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
SOURCE: I'm looking for A service manual for A McCulloch
This is an IPL for a Titan (11-600152-03):Please ensure this is your saw
http://www.ordertree.com/modelinfo/MCC/11-600152-03-TITAN-50-05%2F88-to-02%2F95-IPL-222956/139.11-600152-03-TITAN-50-05%2F88-to-02%2F95-IPL-222956.1.59.1.html
There are others here (IPL #11-600152-03 - just above this one. There may be others 12- etc.) :
McCulloch IPLs
http://www.ordertree.com/modelinfo/McCulloch/139.59.html
This is an international collection of chainsaw enthusiasts, sellers/mechanics. There are McCulloch threads where repair and overhaul are discussed.
ArboristSite.com Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
This thread is where to request a service manual:
Beg for manuals thread (ArboristSite) (free to join)
http://www.arboristsite.com/showthread.php?t=72322
one was requested here:
http://www.arboristsite.com/showthread.php?p=1342509&highlight=titan+50#post1342509
with no answer published. Good luck
Lou
Testimonial: "Thank you soo much the IPL was just the ticket. pokeydell"
SOURCE: Wen replacing all fuel lines
Hi kerry,
I am not too familiar with that chain saw. Although it is a well known saw, in this area we don't see it much. If it is like most saws it has an out and return line, and I will approach it that way. One line goes into the tank all the way to the bottom with a filter attached to it, The other is the return line that is attached to the primer and just goes in the tank about 1". If you don"t have a primer then you probably won't have the second line (return line). Do you have 2 holes in the tank that are within 1" of each other. First get the proper size fuel line and cut one end at approx. 45 degrees to help getting the line into the tank hole, because it is a tight fit so gas can't escape. I will give you a little trick to get the line in the tank. Get a small wire and twist it around the fuel line where it is cut at 45 degrees, put the wire into hole, help it along (this is where the 45 degree angle will be helpful) and with a bent wire or anything you have, work the wire to opening in the tank and now you can pull on it to the tank opening. Once there remove the wire and install the fuel filter and get enough line so it reaches the bottom of the tank. Now cut the other end with a bit extra length and put on inlet of the carburetor, (it should be the one closest to back of carb, nearest to motor). The other line goes to other hole of tank and should have a one way valve and go in about 1 ", other end to other outlet.
I hope this is s bit helpful. All the best and good luck. Any questions welcome
SOURCE: Where do I obtain a
Hi
idano1...
To receive your user manual and parts if you need them for your McCulloch chainsaw.
You need to call 1-800-521-8559, ask for parts, and then ask for a PDF Manual, you will need the model number of the chainsaw.
They will email it to you for free
Please take time to rate me
