Question about Toshiba MW27F51 27 in. TV/VCR/DVD Combo
At the top of Viewing screen
Several close verticle lines run across the screen approximately 4" or 5" down from the top of the viewing screen. Any help would be greatly appreciated.
Thanks in advance
Ernest Martin
hitchhiker49@hotmail.com
  • kjantz1 Nov 25, 2008
    lines at top of screen. 2-3" down. when dark color at top, lines go away where the dark is. when tv program is wide screen with black at top and bottom, no problem. thanks kent
    Problem Solver:
  • 15 Answers
I would suspect that the vertical output transistor is getting ready to go.
Posted on Oct 17, 2008
Diagonal lines at 45 degree angle from left top to right bottom of screen
db:: 4.31::Diagonal lines on tm2 screen? fz - Hivmr
www.hivmr.com/db/fzap9jk8dp87mcjk3cc9jsp7fzxk7pz1
There are faint 45 degree diagonal lines covering my brand new tm2 LCD ... with some static looking diagonal lines going from bottom left to top right. .... DB:3.01:Dv6113 Us - Computer Freezes Showing Diagonal Lines On Screen aj ... Also there arediagonal lines that run across the screen at about a 30 degree angle.
3M Privacy Filter for Laptop diagonal-14.1" viewing screen ...
www.amazon.com/3M...diagonal-14.../B00006B8A9
Amazon.com, Inc.
Rating: 3.8 - ‎1,617 reviews
Amazon.com: 3M Privacy Filter for Laptop diagonal-14.1" viewing screen ... Premium 14.0 Inch Privacy Screen for Widescreen Laptop or Computer Monitor .... 3M™ Privacy Filters create a 30-degree cone of vision so on-screen data is .... You'll also notice a large "3M PF14.1W" printed in the top right hand corner of the filter.
FZ190: Faint Diagonal lines on screen? ' NotebookReview
forum.notebookreview.com > ... > VAIO / Sony
Jan 27, 2016 | Computers & Internet
Wavy horizontal lines across the screen
It sounds that the main power supply section to your TV has the fault. The horizontal thik lines that appears crawling down across the screen should be of video 'HUM'. Have you replaced the main filter capacitor at the power supply section? If not, replace it along with the main rectifier. The AC power is rectifed by a bridge and applied ot this main filter capcitor. It will have a capacitance value between 120 to 350MFD 450VDC. Check this section. Measure the rectifed DC voltage acorss this main filter capacitor. It should be around 350VDC, if your home power supply line is 220VAC. If it is 110AC, this DC voltage will be around 165VDC; and it should be. If rectified DC voltage found lower than the input AC voltage, replace the rectifier bridge. In some sets, this bridge section have four diodes. Some other circuits, a bridge rectifier stalk may be used.
May 20, 2012 | JVC AV-27050 TV
HP Pavilion dv6000z 15.4" Notebook Laptop PC (AMD Turion 64 X2 Duo Core TL-50 1.60GHz, 1GB RAM, 100G... (d6000z) PC Notebook: a thin verticl line across the screen...
it might be due to static on the notebook
turn off the notebook and then remove the battery from the notebook press and hold the power button on the notebook for 4-5 sec and then put the battery back and then turn on and check
if the line is still there check it in the safe mode or in BIOS if its still there then replace the screen
May 17, 2010 | HP Pavilion dv6000z Notebook
Verticle lines across my dell lap top
Put your screen saver to black..let the screen saver come on if lines are there you need a new lcd.....if lines are not there uninstalll all graphics drivers reboot your laptop and reinstall this will fix it if not your lcd screen is on its way out.....NEVER CLOSE YOUR LAPTOP AND STAND ON IT THAT IS JUST SILLY THINK ABOUT IT PEOPLE I MEAN COME ON HOW STUPID CAN YOU GET YES PUTTING PRESSURE ON THE LCD WILL REMOVE THE LINES FOR A WHILE BUT THEY WILL COME BACK.
Aug 22, 2009 | Compaq Presario M2000 Notebook
BLACK LINES ACROSS THE SCREEN Panasonic PT-47WX51E
Replace c7136 & c7154 on A board This should clear up your problem
Dec 11, 2008 | Panasonic PT-47WX51 47" Rear Projection...
Line on the Picture Screen
panel t-con parts n/a will most likley be replaced.
Nov 03, 2008 | Protron PLTV-32 Television
Verticle line down the middle of lcd monitor.
This is a common problem with LCD screens. It is pixel line damage and the screen is permanently damaged and is not repairable. It will probably get worse. The only answer is to replace it
Oct 01, 2008 | Toshiba Satellite P30 P35 Series Notebook
Horizontal white lines across top of TV screen
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
Vertical, pencil-thin blue line appears after 10 minutes of viewing (any source)
I would suspect a connection breaking down as the set heats up. A shop will probably have to put the set in a stand to hold it while they check for loose connections or defective components inside. Not a DIY job by any means. If this line went completely through the picture either vertically or horizontally and stayed there then this would have indicated a failure in the Panel itself. A thin Line any where on the screen consisting of one pixel in width is a Panel Failure according to Hitachi.
Jan 01, 2007 | Hitachi 55HDT51 55 in. HD-Ready Plasma...
Toshiba MW27F51 27 in. TV/VCR/DVD Combo Logo
98 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
