My tv doesnt turn on I also cheacked the internal fuse but its ok and when you turn it on there is going to be a tick sonund but after that nothing happens and after few seconds it ticks again and the red light blinks it happened when I was watching it and there was a boom sound and screen went blank
  • 320 Answers
SOURCE: Sony KDF-46E2000 - Screen Goes Blank
You definitely have a bad lamp. Sony rates the lamp life at between 4000 and 8000 hours. There are 3 things that effect the lamp life, listed in order of importance:
1) number of times the lamp is turned on and off. Every time the lamp is first fired, it takes life off the lamp. Customers I see that turn the TV on in the morning, leave it on all day and then turn it off on the evening can get up to 12000 lamp hours
2) ventilation. Be sure you have at least 6 inches of open space all the way around the set and that the vents are clear of dust and debris.
3) power. If the power is interrupted when the set is on, there cannot be a proper cool down cycle. The fans will run after you turn the set off to properly cool it down, if the power is lost this cannot happen. If your power is unreliable, buy a small UPS to let the set finish a cool down cycle
Occasionally a lamp will faill before the average lamp time due to being defective. from your purchase date it sounds like you got about average lamp time. Be sure to purchase AN ORIGINAL SONY LAMP as a replacement, becuase the aftermarket lamps are bad news, Be sure to rate this solution. Thanks!
Posted on Nov 09, 2008
  • 8617 Answers
SOURCE: 5 red flashs on power/standby light on kdsr60xbr1 screen blank,
Thats the error for lamp driver error. Which means the Ballast is most likely defective. You can get the replacement ballast for your model at the following link which comes with installation instructions.
Posted on May 23, 2009
SOURCE: Mitsubishi projection tv WS-A55 blank screen but sound ok
Bad connection at the horizontal output on main board (board with flyback on it) just resolder it, it should fix this problem
Posted on Sep 16, 2009
  • 5138 Answers
SOURCE: pioneer sd-532hds. the red light is on but when
STK ICS 2 of them replace Both STK392-110 use 180s Mats Electronics has them $10.95 each
Posted on Feb 25, 2010
I also have a Sony KDF 46E2000 that my husband purchased back in November 2006. It's now June, 2010 and for the past two years when I turn the television set on, at the botton left of the screen a box would pop up stating "Projection lamp life is ending, please replace bulb." (or something to that effect). I let it go because I didn't want to have to spend the $150- to buy a new lamp. Well, this morning it finally stopped working. So just as a little information, if you see this box pop up, you don't need to replace it right away. Like I said it was saying that for two years before it did anything. I love this television and it's the only issue we have had with it. I like the fact that the bulb is very easy to replace. Maybe we got lucky and got one of the better tv's since it has lasted us almost four years before having to replace the bulb?
Posted on Jun 12, 2010
I have a vizio 32inch lcd, i was watching tv normally and then boom, it completely turns off, no yellow light, no blue screen, nothing, i tried connecting the cord to a different outlet and everything,...
well in this case maybe you have problems in your tv power supply. you need technician to cheack it..... as you said everything in your house electricity is okey.
May 30, 2011 | Vizio L32 32 in. LCD HDTV
We have Frigidaire 24 in. FDB1050REC dishwasher. The control panel has no power; no lights and nothing works. This problem started after a power outage. All circuit breakers in house ok and other outlets...
more than likely fuse is gone in plug. take dish washer out. change fuse in plug. if it doesnt work get extension lead and run it from a socket that definatly does work and plug washer into that. if nothing then its internal.
Jan 16, 2010 | Frigidaire 24 in. FDB1050REC Stainless...
No power
unplug the unit for 24 hours and try it again. if the unit doesnt come on at all, even after that, then the internal fuse is blown, or a power spike / surge has friend part of the internal power supply. you'll have the go through the warranty process of the manufacturer, or find a local tv repair shop.
Sep 24, 2009 | Daewoo DTQ-27S5FC 27" TV
Cooling fan doesnt come on at all
1 step cheack power to fan if no power
2 step cheack relay and fuses
3 step if there is power at fan then repalce waterheat sending to the computer
if non of that works and you have power to fan replace the fan motor
Jun 27, 2009 | 1995 Ford Escort
Green leds turn on momentarily when first plugged in then shutoff
ok , on hitachi pro tv is very common with bad power supply u may want to replace the voltage regulator which is next to the fuse u already replace , also loose connection on all the power supply seccion , also u may want to check the resistor close by the convergence ic 2.2 ohn if this are smoke replace stk392-110
May 07, 2009 | Hitachi 50SBX78B 50" Rear Projection...
Won't turn on, ticking noise that continues when unplugged
Bad flyback transformer.....Emerson parts source ..Fox international or the ...............T.
Jan 15, 2008 | Emerson EWF2703 27" TV
Ticking sound
ticking sound (like a Watch) coming from around the Flyback Transformer but I don't see a spark is called EHT voltage . if eht voltage is ok 1 check filament is glowing or not if it is ok check voltages on crt. 2 if it is ok check luminance section in chroma section. if filament is not glowing check for low eht due to hor section check power supply output also. good luck
Sep 18, 2007 | GE 25GT270 TV
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
