Question about Panasonic KX-T7630 Corded Phone
I cannot store outside phone numbers on my KX-T7630
Hi, I am following instructions from the user guide to store outside phone numbers so that their names display on the screen of the main phone when ppl I know are calling.... but when I enter the number and press 'store' a mesage comes onto the screen that says 'limit exceeded'. It doesn't matter how many digits you enter, it still tells me that I have exceeded my limit. Is there a solution for this?
  • 1 more comment
  • naggles Sep 25, 2008
    I type in the mobile number I wish to store, then press 'store' or 'enter' then it comes up with 'limit exceeded'. I says in the manual that you can store names against outside numbers-not so?
  • Carl Navarro
    Carl Navarro May 11, 2010
    Does the phrase EXACT KEY SEQUENCE register? You have to start with a code that starts with PROG something. I don't see that in your description.
  • Carl Navarro
    It comes to mind that a TDA system will show CID information if it's being sent and not information from the directory.
    Outside of that, please provide the exact key sequence you're doing, I can't duplicate it on my system.
5 Suggested Answers
  • 9 Answers
SOURCE: setting the time on the panasonic KX-T7630
This is a PBX system, correct? If so, the fastest way would be through the PBX control computer. If you have a Panasonic TAW series PBX, I really like the AbleComm websites, search for your model PBX there.
Posted on Dec 06, 2007
  • 6 Answers
SOURCE: kx-t7630 product spport
This is how I did it:
1. Press the 'Program' button 2. Then dial ** (star, star) 3. Enter the password (usually 1234) 4. Press 'Next' until you get to 'Ext Name' 5. Press 'Enter' 6. You will need to know the Extension Number of you phone, when you find out enter it (eg: 104 or whatever yours is) 7. Press 'Clear' to get rid of the old name then start entering the new name via the number keys. Note: If you keep cycling through the letter on each number you can get to lowercase or uppercase letters. 8. Press 'Enter' then you are all done... pick and hang up the handset.
Posted on Feb 12, 2008
SOURCE: Transfer the Call
how do i put the answer phone back onto the phone so when ppl riing the office the answer phone comes on to tell them what to ring when the office is empty
Posted on Aug 11, 2008
cnavarro
  • 2460 Answers
SOURCE: Panasonic phone KX - T7630 - memory
Of course it's possible. Maybe the PROG softkey is a start. That an a manual.....
Carl
Posted on Aug 23, 2008
cnavarro
  • 2460 Answers
SOURCE: How do you cancel night mode on the KX T7630? Or
If it's enabled on your phone, on the intercom dial *7800 That puts the system in DAYS. *7801 puts it in NIGHT. By default extension 101 or the main phone has access to it. We turn it on for everybody in most offices by Class of Service options.
Carl
Posted on Apr 27, 2009
How do I change our recorded message on our Panasonic KX-T7630? Its an old system and I have downloaded manual but it has no instructions. Any help would be appreciated many thanks
Hi Caroline, this kx-t760 doesn't have a answering machine function. This is why you can't find it in the user manual.
I can not take credit for this answer as it was answered in sep 2009
with
The panasonic KX-t7630 doesnt have a answering machine and runs through voice mail.. if you have voice mail set up simple dial your number for voice mail (eg. 500) press 311, then record greeting at the end of tone. hope that helps.
http://www.fixya.com/support/t2417399-record_voice_message_oanasonic_kx_t7630
and
http://www.fixya.com/support/t7388687-im_trying_change
page 16 of the manual below may be useful to you as it has the voice mail access codes listed
http://www.boileau.com.au/assets/Manuals/Panasonic-Manuals/OPERATER-GUIDE-New.pdf
Have a Happy New Year Caroline and I hope you find the answer you are looking for.
Jan 02, 2015 | Panasonic KX-T7630 Corded Phone
How to store numbers using panasonic KX-T7630
Hello Jd,
For storing numbers in panasonic KX-T7630
While on-hook Enter phone number(max. 32 digits). AUTO DIALSTORE OR Press STORE or ENTER. Enter name(max. 20 characters). AUTO DIAL Store or Pres STORE or ENTER.Press Exit or Pause.
Aug 18, 2011 | Panasonic KX-T7630 Corded Phone
How do i customize a call button to a number?
What number? You have 24 buttons. You can store inside numbers under a button by pressing PROGRAM the button and dial 1 + the extension number and ENTER or STORE.
Outside numbers depend on what you dial to get an outside line (usually 9). In that case, press PROG button 9+your outside number and ENTER or STORE.
Press EXIT to leave programming.
Carl
Sep 30, 2010 | Panasonic KX-T7630 Corded Phone
How can i change the extension numbers and names on kx-t7630
It requires access to system programs 003 and 004. That can be done from the extension authorized for programming, usually extension 101. There is no "swap" command and we usually move the hardware at the frame rather than in software, but you can do it if you find a vacant number. An example would be to swap 102 and 108 you make 102 some other extension, like 402, then make 108 102 and then 402 108. Yeah. Sure.
Anyway, the user's guide (UG) for your specific system (not the phone) has instructions for the System Manager that details how to program Extensions and Names.
Carl
Aug 26, 2010 | Panasonic KX-T7630 Corded Phone
Hello, I have 4 Panasonic KX-T7630 with TDA100, and I set the flexible button for CO or INT, but the LED on the buttons didn't light when I receive a call. I can make a call use this buttons, but the LED...
Whenyou program the buttons use the following steps -
press PROG
press the BUTTON to store
press 1 for an extension and the enter the extn no. followed by STORE
(or press 0 to store a line key)
(or 2 to dial an outside number dont forget a 9 for outside line access)
Aug 10, 2010 | Panasonic KX-T7630 Corded Phone
Hi, Expert Guy , I have some problem with Panasonic TDA100 about calling Out by co line i have 20 extension and 4 CO line , so when i need to call out , i press number 9 , it will switch to the line free ....
To call out: Go off hook press an idle CO button-- Dial outside phone number. There is no need to dial "9".
If you need a copy of the manual you can get one for free at the following link: HTTP://phone.manualsonline.com/manuals/mfg/panasonic/kx-t7630.html....Let me know if this answers your question. Master FixYa...
saailer@att.net
Dec 05, 2009 | Panasonic KX-T7630 Corded Phone
I want to program the hour and date in my telephone Kx - t7630 Panasonic
Here is the User Guide for your KX-T7630, which can be found at IdacomUSA. We provide User Guides and System Manuals for every system and phone that we repair/refurbish.
KX-T7630 User Guide
Jun 22, 2009 | Panasonic Lands Phones
Kx-tg5632 how do i forward call to my cell
you need to call your carrier and get a forwarding code and then a cancell code.
good luck
s
Jun 11, 2009 | Panasonic KX-T7630 Corded Phone
Programming new numbers into kx t7630
If it's going to be an extension press PROG dial 1 and the ext number and ENTER
If you're trying to put an outside number on it, press PROG dial 2 then 9 + number and ENTER
Carl
Nov 27, 2008 | Panasonic KX-T7630 Corded Phone
Panasonic KX-T7630 Corded Phone Logo
238 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
