Question about Zapf Chou Chou 716212
Sharp Atomic Clock spc 373 won't display correct time/zone
I live in the Central time zone and my clock will only display Pacific time - have re-booted multiple times.
  • 1 more comment
  • Anonymous Mar 14, 2009
    I have the same problem with my Sharp Atomic Clock spc 373 will not diplay correct time/zone.
    I have a "Sharp Atomic Clock SPC373 which will not diplay the correct time/zone CST. I have tried many times to change, however it goes back to DST. How can this problem be corrected?
  • Anonymous Mar 22, 2009
    Cannot set the correct time zone on my Sharp Atomic Clock SPC 373
  • 3 Answers
To change the time zone press the "time" button, on the front the space that shows the date will change to show the time zone. With the time zone showing press the "up" or "down" button to get to the correct time zone.
Posted on May 03, 2009
Need to set my sharp atomic clock 373.
Posted on Nov 08, 2008
  • lenash87 Nov 08, 2008
    I live in the state of Arizona, I am not within the california area, it is state on PA scale.
How can I set the time?
Once you select the time zone and whether you are observing DST, the clock sets automatically. That's the point of having an atomic clock.
Apr 19, 2016 | Sharp Atomic Wall Clock, Silver/Titanium...
How do I change from military to 12 hour format on the time display of the Sharp Atomic Weather Station SPC1003
Resetting: 1. Remove batteries from both the outdoor transmitter and the Temperature station. 2. Wait at least 30 seconds and then repeat the procedures specified in Setting up (above). Note: Always wait at least 30 seconds after removing the batteries before reinserting, otherwise start up and transmission problems may occur. Also, remember when insertting, that both units have to reset and to always reinsert the batteries to the transmitter first
Instructions
    • 1 Insert the batteries into the clock and verify that the clock's display is functioning.
    • 2 Set the correct time-zone and Daylight Saving Time (DST) switches. The switches are on the back of the clock. Select EST if you are in Eastern Standard Time, CST if you are in Central Standard Time, MST if you are in Mountain Standard Time, or PST if you are in Pacific Standard Time. The DST selector should be set to "off" or "on" depending on the laws of your state.
    • 3 Wait 15 minutes. The clock should synchronize automatically.
    • 4 Set the clock manually using the buttons on the back panel if the clock does not catch the radio signal within the first 15 minutes. Push the correct button to advance the month/day/year on the calendar; use the MODE button to set the hour and minute.
    • 5 The clock should adjust itself within 48 hours to match the atomic signal. Verify that the clock is receiving the signal by checking the front display. You should see the image of a tower with circular lines at its top.
Read more : http://www.ehow.com/how_5698886_set-sharp-atomic-wall-clock.html
May 08, 2015 | Audio Players & Recorders
I bought Sharp Atomic SPC 936 in the USA but live in South Africa, can I change the clocks time zones
I brought a alarm clock for my daughter and all the instructions are all in chinese
Apr 12, 2014 | Home
Can not set time zone
Press the triangle shaped button to set the correct time
zone. It will toggle the clock mode through the four available time zones in the Continental U.S. Above the seconds digits, the LCD display will indicate "P" for Pacific, "M" for Mountain, "C" for Central and "E" for Eastern.
Mar 01, 2011 | La Crosse Technology WT8005UB Atomic...
Sentry self setting atomic clock lost the instructions
Select The Time Zone - For Sentry Self-setting Atomic Clock (ATC - 10)
The default time zone is Pacific zone.
1. In the normal time mode, press the MODE key to enter the alarm time mode.
2. Press the SET key to change the time zone.
each press of the SET key will move the time zone back one hour
P= Pacific M=Mountain C=Central E=Eastern
3. Press MODE key when correct Time Zone is highlighted.
I think the Instructions may tell you to use the ADJUST key instead of the SET key.
ADJUST key does not work for TIME ZONE change, SET key works.
This will set your clock to your chosen Time Zone for normal time.
Instructions for the ATC20 are located at the following url
http://www.sentryindustries.com/pdf/instructions/ATC20_instructions.pdf
Sep 28, 2010 | Office Equipment & Supplies
Atomic clock is 2 hoursfast
You need to reset it to YOUR time zone. The default on this model is Pacific Coast time so you must be in the Central Time Zone (2 hours ahead of Central). Instruction manual should show you how to reset.
Feb 09, 2010 | SkyScan 86742 Digital Atomic Wall Clock
Mt atomic clock is always 2 hours slow no matter
How to Change the Time Zone
Press and hold the “-“ button for 3 seconds the letter P will appear where the seconds are than press and release the “-“ button until the correct letter for your time zone appears. The four time zones are P is Pacific, M is Mountain, C is Central and E is Eastern Time zone. Press the SET button to confirm or leave the setting to confirm and exit automatically.
Sep 26, 2009 | Acu-Rite Adagio Clock Radio
I need to change time zone on atomic clock to EST
I need help setting the time zone on the sharp atomic clock model #spc364.
Apr 18, 2009 | Bose Wave Radio
Changing Time Zone on Wind & Weather Atomic Clock
1. Press MODE to select the time with the day of week
display mode.
2. Select the time zone by pressing and holding the “ + ”
button for 3 seconds.
3. Keep holding until the desired time zone (Pacifi c,
Mountain, Central, or Eastern) is selected on the
display map
Jan 20, 2009 | SkyScan 86742 Digital Atomic Wall Clock
Honeywell RC182WB Atomic Alarm Clock with Temperature--stuck on pacific time!!!
I KNOW HOW TO FIX IT!
Take off the battery cover, and take the batts out, leaving the outside thermometer working...
You will have to reset everything but it automatically detects your time zone!
I just did it literally 2 minutes ago!
Nov 23, 2007 | Honeywell RC182WR Atomic Alarm Clock - Red
Zapf Chou Chou 716212 Logo
2,613 people viewed this question
Top Zapf Baby Gear Experts
Dorel UK
Dorel UK
Are you a Zapf Baby Gear Expert? Answer questions, earn points and help others
