Question about Powerware 9120 UPS System
Battery Failure UPS PowerWare9120 Battery Failure
You can contact value power, an approved Powerware specialist, who know what batteries are required and how to go about changing them. www.vps-ups.co.uk
Posted on Nov 06, 2008
  • 790 Answers
Hi
if the battery is bad you better to replace a new one!
Thanks!
Posted on Sep 23, 2008
APC Smart VT 30KVA UPS cannot sustain power after power failure
ups units run a computer directly from mains power and from a battery when mains power is cut.
some run the computer through the battery at all times and so use the battery as a surge protection
points to check on your unit
is the by pass system being damaged in the surge protection section
is this requiring the batteries to provide power but not being charged at the same time
Is the power consumption exceeding the battery rating ( pc, printer, monitor , modem etc exceeding the out put of the ups
Apr 27, 2015 | American Power Conversion Corp...
Invertomatic victron imv ups
Malfunction of input circuit: voltage delivered is too low. The batteries may
be faulty or depleted. Wait for a few hours, leave the UPS switched on
If absence of input power (utility failure, maintenance work) is expected to last longer than a few hours, switch
off the UPS to save battery power. If the UPS input power is absent for several days and the UPS remains on
under no-load conditions, the batteries can be discharged very deeply, resulting in a short battery life time
Apr 22, 2014 | Computers & Internet
UPS Bypass mode failure
it looks like you have a faulty static switch
Apr 11, 2014 | Eaton Powerware 9355 UPS System
Ups off shows in the display of powerware9120 3000va
Was the UPS commanded to power down? Make sure there is nothing plugged into the UPS and disconnect it from whatever is powering it. Then pull out the all of the batteries inside of the UPS just enough to disengage them from their connections. Once everything has been unplugged and nothing has been feeding the UPS power - then go ahead and re-engage all of the batteries. Turn on the power source to the UPS. It should start up and function as before - you may need to instruct the UPS to carry the load.
If you need more help with this reply or call:
Daniel • daniel@psihq.com • Power & Systems Innovations • 800.260.2259 • www.psihq.com
Nov 16, 2013 | Powerware 9120 UPS System
APC BACK-UPS ES 500VA fails to provide back up during power failure
Get APC Powerchute Personal Edition for free and run it. If it says your battery isnt charged, check its voltage disconnected. Charge it with a car battery charger and see if its still a good battery. If not , replace it. If the battery is good, then check the charging voltage. Should be about 14 volts. if not, check the small transformer on the main board. Should be 120 in and 17 to 18 out. 4 diodes in a bridge for charge. The input to the transf has small fuse into it alone.
Jan 04, 2013 | APC BE500U ES 500 USB BACK-UPS 500VA/300W...
I have a powerware 9120 (6kva) and about 1 week i replaced all 20 batteries after the UPS failed. but its displaying battery disconnected when i try to power it. i cant seem to figure the problem. i tried...
Did your UPS display "Battery disconnected" or did it display "Battery Failure"? If it was "Battery Failure", for some reason the Powerware 9120 will take almost 18 hours after plugging in to power after battery replacement to correct the Battery Failure indication. Charger has to charge up the batteries, followed by an automatic battery test by the UPS. If the indication was "Battery Disconnected", you will need to check the internal fuses to see if they are blown. If the UPS keeps blowing fuses, it will require a board repair.
Jun 12, 2011 | Powerware 9120 UPS System
UPS emits a regular beep at about 5 minute time lapses - what is the problem?
My guess it it is trying to get your attention for some reason. While I am not familiar with this brand, the competition brand beeps because of battery failure or impending failure.
Thanks for your interest in FixYa.com
Dec 12, 2009 | Powerware PowerRite Plus UPS System
I have a Powerware 9120 2000 UPS battery failure message
After you replaced the batteries did you perform a manual battery test?
If not do so.
Regards
Alan Hood
ami-man
UK
Mar 03, 2009 | Powerware 9120 UPS System
9120 battery failure
sometimes the battery tester is not enough to check the battery. battery also prone to tear and wear.because of charging ang discharging. replace the battery
Feb 05, 2008 | Powerware 9120 UPS System
Powerware 9120 UPS System Logo
466 people viewed this question
Top Powerware Computers & Internet Experts
Vassilis Chamaidis
Level 1 Expert
Jax Planet
Jax Planet
Are you a Powerware Computer and Internet Expert? Answer questions, earn points and help others
