SOURCE: amd foxconn 6100k8ma-rs 6100
Hello, here are your drivers
http://www.foxconnchannel.com/EN-US/support/downloads.aspx?ProductModel=6100K8MA-RS&TypeID=en-us0000004
if link is broken click here
If you need anything else, let me know.
Thank you,
Ekse
SOURCE: nvidia geforce 6100 nforce 405 if i can enable the
dude its prety easy go to control pannel detect the nvidiacontroler there
go to its properties and reduce the frequency to as of the monitor its better make it 60mhz that normally works
SOURCE: A8NVM Series MotherBoard with NVIDIA GeForce 6100
You need to download Video Graphic from this site.
SOURCE: GIGABYTE GA-M61SME-S2 AM2 NVIDIA GeForce 6100
Is this a new board? Check the processor to make sure that it is seated properly. You will have to remove the fan and heatsink, but if you put the processor in yourself, it is possible that it didn't seat properly.
SOURCE: AMD ATHLON 2800 XP PROCESSOR, (using XP Pro, Svc
The integrated graphics may have bit the dust.. but I'd suspect a poor connection at the jack first. Try disconnecting the cable from the PC (and the monitor if not molded in) and reseat the plug(s) into the jack(s). Give it a wiggle and see if you can detect the red channel coming on. Check the VGA cable for signs of damage. If unable to get the red, you'll need to isolate the trouble to either a faulty graphics port or monitor. You can do that by swapping the monitor with a known good one OR installing a VGA card in an open slot of the MB. A third possible swap would be for the VGA cable if it can be separated from the monitor.
You may have to change a setting in the BIOS to tell the computer to use the PCI or AGP video if you go the expansion card route tho. Swapping the monitor shouldn't be a problem if you change the resolution in the OS to match the new monitor (or simply set to VGA) so that you don't over drive the replacement monitor.
Either of these two methods will provide you with a definitive answer as to the health of the monitor or graphics adapter. Just remember to change ONE thing at a time - don't make two changes at the same time as you won't know which is the faulty component.
I hope this helps!
• HyperTransport 1.0 supporting speed up to 1000MT/s
Chipset
• NVIDIA® nForce 630a & GeForce 7025 chipset
Main Memory
• Supports Dual Channel DDR2 667/800
- 2 DDR2 DIMMs (240pin / 1.8V)
- Supports a maximum memory size up to 8GB.
Slots
• One PCI Express 1.0 x16 slot.
• One PCI Express 1.0 x1 slot.
• Two PCI slots (support 3.3v/5v PCI bus interface).
On-Board IDE
• One IDE port by NVIDIA® nForce 630a & GeForce 7025 chipset
- Supports Ultra DMA 66/100/133 mode
- Supports PIO, Bus Master operation mode
- Can connect up to two IDE devices
On-Board SATA
• Two SATA II ports by NVIDIA® nForce 630a & GeForce 7025 chipset
- Supports storage and data transfers at up to 3Gb/s
RAID Function
- SATA II 1~2 supports RAID 0, 1 mode by NVIDIA® nForce 630a & GeForce 7025 chipset
