Question about Philips Magnavox 51MP392H Rear Projection Television
No picture my screen dosent display a picture my bulbs are still good
  • Anonymous Jan 03, 2009
    also have no picture
Wont turn on
Posted on Jan 24, 2009
The camera s 730 works poperly in doors but dosent take pictures outdoors ( after taking the picture it show a the picture as a white screen ) pl. help asap as i am with my family for a vacation pl...
Problem with the Samsung Digimax S730 Digital Camera the camera s 730 works poperly in doors but dosent take pictures outdoors ( after taking the picture it show a the picture as a white screen )
Jul 14, 2011 | Samsung Digimax S730 Digital Camera
When i load call of duty black ops the screen splits into 2 horizontal screens ......dosent do it with any other games i have
Go to your display settings and instead of choosing automatic for display choose custom. The 3D option is splitting your picture horizontally.
Nov 26, 2010 | Activision Video Game Consoles & Games
My hp pavillion ze4900 laptop is having display problems. It works if you plug it in to the moniter but either way if you don't plug it in or not. the laptop itself will not picture anything. Well i can...
1. Test using an external monitor. If it works, then either the screen bulb or the inverter board might be defective.
2. Test the inverter. Easiest way to do it if you have a good screen with a good bulb. Connect the good screen to the inverter board & test it. If it lights up, then the inverter board is good. If it did not, then the inverter board is bad & needs to be replaced.
3. If the inverter board is good, then we are left with the possibility that the screen bulb is bad. To fix this, we will need to replace the LCD screen.
Oct 10, 2010 | HP Pavilion Ze4900 Notebook
Thinkpad T20 display is very, very dark (unreadable). Does the display need to be replaced ?
Oct 08, 2010 | IBM ThinkPad T20 2647 Notebook
Turns on green light comes on but blue dosent and theres no picture on my screen
The no display error is caused by overheating and you can fix it yourslef using a good guide
Jan 08, 2010 | Sony Playstation 3 (PS3) Console
Screen display problem
It sounds like your "backlight" went out. This is a tiny compact fluorescent bulb in the LCD that lights up the screen. There are usually two reasons for this 1) the bulb burns out or 2) the little circuit board that powers the light fails, this is called the "inverter board" and is either in the "lid" (screen part) of the laptop or in the main base of the laptop. That's why there is a really dim picture. There are two parts of the LCD, one to produce the picture and the bulb that illuminates this picture so you can see it easily.
There's no easy way to test this. You will either have to replace the LCD or replace the inverter board to check. Usually the problem is with the inverter board, which is good because it can be easier to replace and a lot cheaper than a new LCD screen.
You can check HERE to see if any of these guides looks like they might help you replace the inverter. They don't have your exact computer, but they do have several models that are similar.
If you take it to a commercial repair shop it will probably cost between $250-400 to repair. If you contact someone good through Craigslist or some other similar service in your area, you should be able to find someone to do it for about $50+ parts.
Good luck.
Oct 08, 2008 | Acer Aspire 3690-2196 Notebook
No picture
Most likely the vertical output IC needs to resolderd. When the picture goes out if you press menu can you still see the on screen displays?
May 23, 2008 | Philips 60PP9202 60" Rear Projection...
No date display
yep i have the same problem too. no date display. it displays the date on the outer screen when i flip the phone shut. but not on the main screen when it is open.
Jun 18, 2007 | Motorola Mobility RAZR V3
Menu will not display.
you may not have much of a choice. Look in the insruction manual on how to save to a compter> try to save all the datas thats on that drive and then do a reset. If that dosent work then try calling the manufacturer and tell them your delima . Maybe they have a secrit button pressing wayt to reset without loosing data? 1-800-SAMSUNG. Good luck
May 07, 2006 | Samsung YP-T8 Digital Media Player
Philips Magnavox 51MP392H Rear Projection Television Logo
61 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
