My phillips rear projection tv 60p8341a the colors has seperated on the screen, can you help
  • bigcgillis Mar 27, 2009
    Hello, I have the same problem. I have tried to adjust the convergence, but the green looking color is warped and wobbly.
    I do know how to solder and read a meter. Do you think you could coach me as to what to check?
    Thanks in advance,
    Charlton
    Novelist:
    Champion:
  • 203 Answers
Sounds like a convergence problem. Do you know how to solder and use a meter? If so you might be able to repair this yourself for uner $100. Otherwise you will need to call a repairman and he will run you somehwere between $300-$500. Let me know and i can help!
Tim Nolan
Posted on Sep 23, 2008
  • Delton Smith
    Delton Smith Nov 21, 2011
    yes it sound like thoes stk's i just fixes a 60p8341 stk392-110
Phillips ptv916 60p8341a fix color
Which menu were you in? Set has Customer, hidden tech, and hidden convergence.
the dark picture may be the lens dirty--clean them if you have not and the red picture may be adjustment of the screen controls just slightly off.
May 27, 2012 | Televison & Video
I have a magnavox projection tv and all three colors seperate on the screen. How do I fix this?
Thats usually a convergence issue. Most phillips and magnavox ear projections use the Phillips DPTV305 - DPTV345 convergence repair kit which contains the parts and the CD with instructions for the repair. The kit is available at www.tvrepairworld.com
May 01, 2011 | Philips Televison & Video
Yes my 60 in phillips rear projection tv model # 60p8341a the screen is a reddish orange color and wanted to know how to fix it
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc
Dec 19, 2010 | Philips 60P8341 60" Rear Projection...
Colors seperate
Yes, this problem is fixable.
Replace convergence out chips on D board of tv to fix the color separation issue.
Jun 05, 2010 | Sony KP-46WT500 46" Rear Projection...
COLOR PROBLEM
you have a miss aligned convergence. try to aligned it first.
Aug 06, 2009 | Philips 55PP9363 55" Rear Projection...
I have a Phillips rear proj. 60pp9202/17f with a color problem
3_24_2012_6_00_06_am.jpg This is a common problem on many brands of Projection Tv sets. Its usually a convergence issue. You can get more details and a solution here on fixya using this link http://www.fixya.com/support/r11932741-convergence_repair_dull_video_repair
Jul 12, 2009 | Philips 60P8341 60" Rear Projection...
We have a red green color seperation on screen. how do we correct this
You can get the phillips DPTV305 _ DPTV345 convergence repair kit at the following link . The repair kit contains the two ICs 12 resistors and the Deatailed instructions with pictures on CD. Just look under the Phillips repair kits category.
http://www.tvrepairworld.com/
Jul 12, 2009 | Philips 60PP9202 60" Rear Projection...
Color seperation on rca 1998 46" rear projection tv
projection tvs have seperate color bulbs that put out the same picture the lenses just need to be adjusted. they probably shifted during the move.
Dec 04, 2008 | Televison & Video
Phillips hdtv 60in.rear projection tv started having the colors seperate and it looks like two pictures at once.seems that the red is trying to break away.
replace the convergence ICs. Easy repair if you can solder. If you need more info post the model number of your set.
Mar 25, 2008 | Televison & Video
Televison & Video Logo
110 people viewed this question
Top Televison & Video Experts
Electro Med Services...
