Creative zen shuts down after rebuilding - Audio Players & Recorders
  • kerrence_09 Feb 25, 2009
    A friend just lended their old Creative Zen nano to me and it played FINE the first day. I deleted all the songs on the player, added my own, played FINE... Now, for some reason, when i go to play it, it will shut down after about 3 seconds of ANY song playing. But if i pause it, the player will still stay on. But right when i play a song, it shuts down automatically after 3 seconds. I JUST bought new batteries.
  • Anonymous May 03, 2009
    Creative zen nano 1gb. shuts down randomly after starting recording or playing... freshly charged AAA battery inside.
Shut down your player. Press and hold play/pause button, then switch it on. Select clean up and after that reboot. Voilá!
Posted on Feb 07, 2009
Hi, My Creative ZEN has frozen up. When you switch it on a 'rebuilding' screen is displayed and once that has run its course the last song that was playing is displayed as playing but does not play &...
First of all, I hope you mad a backup of it's content, becouse there is
no other way, it need to be fomated from it's service menu.
1. Make sure bthat your Zen is turned off and has a full battery.
2. Press and hold the Play/Pause button and Back/Options button simultaneously.
3.
The Recovery Mode screen appears when the player, and three menu items are shown: Clean Up, Format and Reboot.
4.
Format your ZEN and then do a clean up.
5. When done reboot.
6. Hook it up to your computer an reflash to the latest firmware, you can download the tool here to flash your firmware:
http://ccfiles.creative.com/ManualDn/Applications/PDE/10398/0x8CCCF7FC/CT-RT_PCAPP_2_00_05.exe
Jul 28, 2010 | Creative Labs Zen Touch MP3 Player
Zen won't charge and continually rebuilds library unsuccessfully
buy a new battery, or try cleaning the connections dist is a big problem at small devices like this...you your vacume cleaner, but BE CAREFUL!!!
Aug 25, 2009 | Creative Labs ZEN V Plus MP3 Player
My crative zen moziacv lx shut down
charge is then if dat doesnt work go to zen website and get the mp3 player recover program
Feb 10, 2009 | Creative Labs Zen Touch MP3 Player
Creative Zen Freezes on Rebuilding
My Zen locked when I turned it on. It wouldn't play the track the screen was on so I pressed the reset button and turned it on again. It was then still locked on the same track so I tried turning it off which then froze as it was shutting down. After another reset it went through the rebuild screen then locked again. I then used the above fix (pin in reset, then hold play and power switch down). Taking me into the kind of bios screen I formatted the contents. Then added my library again. It's now working fine.
This is the second Zen I've had because the first one had the same problem so I took it back without trying to fix it. Both times the problem occured when I had my Zen plugged into my car stereo auxiliary jack whilst switching the ignition on in my car. I can't understand why this would cause the problem but I'll avoid doing that in future.
Dec 27, 2008 | Creative Labs Zen Digital Media Player
Creative zen not recognized by computer
I was having the same issues with my Zen Vision M : 30 G. It was not recogznized on any computer, and when I turned it on after having it off for a large amount of time (24 hours), it would rebuild half way before completely turning on.
I did a TON of research and found nothing but I finally got my Zen to work by trial and error.  This is how I did it:
Download the MP3 Recovery tool on the Creative Support Website. Make sure that the MP3 player is at least half charged.   Turn on the mp3 player, holding the on power switch in the ON position. (Very important to hold the Power switch!) While holding down the Power switch, reset the Zen by inserting a small object into the hole at the bottom (thumbtack, wire, earring).  A menu will appear: Clean Up, Format (All), Reload OS/Firmware, and Reboot. I chose Clean Up first and this did not work for me so then I Format.  It will remove all of your data on your Zen.   After Formatting, Reboot your Zen and plug it up to your computer. Run the MP3 recovery tool again.   The Firmware should recognize your Zen, and once installed, so should your computer.
I hope this helps!
Sep 30, 2008 | Creative Labs ZEN Vision:M Digital Media...
Rebuilding Library
Corrupt DB, firmware to reolve on creative website
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Feb 21, 2008 | Creative Labs ZEN V Plus MP3 Player
Creative zen 60gb
I had the same error - unfortunately mine was a hard disk error and it was unsaveable. i lost all my songs.
Jan 12, 2008 | Creative Labs Zen Touch MP3 Player
Zen frozen
Go to recovery mode, and do a disk clean up. If that doesnt work, then you might have to format it.
Did you reset it properly? To reset your zen, put a pen head in the hole under the power button for 20 seconds
Mike
Nov 08, 2007 | Creative Labs ZEN V Plus MP3 Player
Creative zen v plus frosen
Did you hold down the power button while resetting it?
727 people viewed this question
 Grubhead
Grubhead
