Question about Saeco Primea Cappuccino Touch Plus Coffee Maker
Saeco primea touch settings
Hello 0505,
I was able to follow your instructions to get into the Service menu for my Saeco machine, but I'm not sure how to increase the milk temperature. It seems like there are several settings for this (pulse width, steam length, etc). Any idea what combination of settings to use?
Do you happen to know what all of the settings are for? It's hard to tell what effect they have.
Thanks,
Rian
  • 74 Answers
SOURCE: Steam escaping from milk container
When you say change Oring do you mean the Oring in the capp. or in the machine?
Posted on Jul 11, 2008
  • 5 Answers
SOURCE: primea ring - milk not hot
Hello!!
Okay! Looks like many of you out there has the same problem, whit the milk temerature (not me i never had).
But there is a service menu on primea touch plus series.
Im from Sweden but i will try my best to explain how to enter the menu. First of all !!MUST!! write down off parameters before changing any thing!!!! It is possible to set the grinder to grin more coffie for each cup. I think the factory setting is 85 Aroma impulse. It is possible to change that for you type of coffie beans that you use, i will diff from bean to bean.
Okay, to enter the menus you have to turn you machines off.
Now turn it on !!!!!EXACTLY!!!!! when the display lights up press your display in the following order ALWAYS IN THE CORNERS (you will not see any icons were you have to touch on you display) RIGHT LOWER CORNER, LEFT UPPER CORNER, RIGHT UPPER CORNER, LEFT LOWER CORNER.
To enter the second service menu, do as i explained before but use this "CODE" instead. LEFT UPPER CORNER, RIGHT UPPER CORNER, LEFT LOWER CORNER, RIGHT LOWER CORNER. This is it! Hope i could help you! Remeber to write down before doing any changes! DO NOT ERASE ANY FAULT CODES YOU SERVICE CENTER WILL FIND THAT INFORMATION VERY IMPORTANT!!!!!
Dont say that it didnt work, it will it´s a huge matter of timing!!!! IT WILL WORK!!!!
Let me know some results please!!
Posted on Jul 30, 2008
  • 5 Answers
SOURCE: Saeco Primea Ring - no milk - just steam
Hello!!
Posted on Jul 31, 2008
SOURCE: saeco cappuccinatore not taking milk, instead blowing some steam into milk
Try this, the valve diagram shows that you twist the knob, but you left it up and down to adjust the flow. You could also check that the container you have the milk in, is lower in height than the cappuccinatore to help it siffin the milk up from its container. Make sure the cappuccinatore is fitted correctly pushed in fully and half fill a cup with milk and pull the valve adjuster up a small amount and push the button. It should start pushing steam out the cappuccinatore and then within a few seconds it should start siffining milk up the tube.
Cyril
Posted on Oct 01, 2008
JohnnyBeans
  • 223 Answers
SOURCE: Saeco Primea Touch
If you use the milk feature, please make sure that you rinse after making a milk drink or the machine will automatically request a milk cleaning cycle which is different than a rinse. For example if you make a milk drink and you skip the rinse cycle and leave the machine without rinsing for more than 20 minutes it will schedule a mandatory milk cleaning cycle.
It is okay to skip milk rinsing if you are making drink after drink as long as you rinse after the last cup.
Hope this helps you out.
Saeco's First Authorized Service Center of New York
Cerini Coffee Services
www.CeriniCoffee.com
Posted on Nov 25, 2008
Hi, I have a Saeco Primea Touch Plus, in the display it says error 5. What ca I do? Regards, staffan
I had that error too, the very first day after i received my Saeco Primea Cappuccino Touch Plus from Germany. The curiosity is that the machine was able to prepare a cuple of cups and suddently died with 5 in screen. Going to the service, they said that error 5 is about a lack of pression in pipes, probably due to the unprotected transport to Romania. I don't know if they fixed alsi some jonctions, but i had to pay for few rings. Everything took a day in service, but now is working fine. Hope it was usefull and my english enough inteligible.
Apr 17, 2011 | Saeco Primea Cappuccino Touch Plus Coffee...
Error 1 on saeco primea touch plus
The grinder motor is not working,,better to take it to the service center to replace a new one under warranty if the machine is new.
Oct 24, 2009 | Saeco Primea Cappuccino Touch Plus Coffee...
I have a Saeco Primea Cappuccino Touch Plus. how do I adjust the machine to make the coffee fill up a cup or mug(using different size). Can the machine work out the size of cup used automatically.
Yes, you can adjust the sizes and aroma according to your taste,just hold the the product without releasing your finger,the screen will show programming.Then follow the instructions on the screen. Easy.
Apr 26, 2009 | Saeco Primea Cappuccino Touch Plus Coffee...
Primea ring hot milk
Remember that the milk temp should be around 60-70c. Milk will start to boil around 80c.
You´re welcome and good luck!
Jan 11, 2009 | Saeco Primea Cappuccino Touch Plus Coffee...
if you go in the menu there a temperature setting for that machine pierre
Saeco Primea Touch
Oct 21, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Hello!!
Apr 30, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Primea ring - milk not hot
Hello!!
Mar 04, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Saeco Primea Cappuccino Touch Plus Coffee Maker Logo
172 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
