Question about Samsung Digimax D53 Digital Camera
3 beeps One day my camera was working fine. The next day, I tried to turn it on and the lens came out just a little and then it stopped and beeped three times. It now makes this noise everytime that I try to turn it on. It did this before when the lens was uneven. However, the lens appears to be in proper place so I don't understand why it is doing that.
  • 3 more comments
  • felixtata Sep 30, 2008
    i have 3 beeps problem
  • Anonymous Oct 02, 2008
    1. sded
  • babycakes130 Oct 02, 2008
    • my camera (Digimax D53) has that 3 beep and turn off problem, when i cut on my camera and it says that the batterys low and thats not true because i jus bout brand new ones, but then it dose the 3 beep noise and turns off every time! What should i do?
  • shadowerjmr Oct 23, 2008
    My Digimax D53 Digital Camera has the problem in which the light flickered and the lens came out. I don't know if it's all the way, but the lens are out. I thought the reasons were the batteries so I tried some cheap ones and hoped they'd work. They didn't and then I tried my remote batteries. Those didn't work ither. So now my lens is stuck out and I tried to bang it on the floor/wood. But I have no idea which side to bang, so if thats the solution can you tell me where? Also if its the batteries, what kind should I buy?
    ALSO I left my camera's battery container open.. Like the bottom part in which you slide to the right and it opens to put in 2 double A batteries, could that be the problem?
  • youngxa Nov 16, 2008
    Have the same problem. What's the solution. Please help.
After some attempts to turn on the camera following the instructions posted in this page, i just bang the camera when y press the start button, and the lens was released, and the camera start up with no problem :)
Posted on Aug 11, 2009
Had the same problem with my D53 eneded up buyin a new camera pulled the D53 out the other day was going to toss it then i noticed the lense was just a lil crooked i played with it a freed it up camera works great now
Posted on Nov 02, 2008
My camera digimax d53 does that sometimes but i just push the power button and no other button then it works fine
Posted on Nov 06, 2008
SAMSUNG DIGIMAX D53 DIGITAL CAMERA LENS IS STUCK IN AND WILL NOT COME OUT ..NOW I TURN IT ON AND THE GREEN LIGHT IS ON NOTHING HAPPENS..I HAVE MECHANICAL EXPERIENCE , I HAVE TOOLS ..CAN YOU EXPLAIN HOW TO REPAIR ..IM A LITTLE INTIMADATED ABOUT TAKING THIS APART SHOULD I BE.THANKS BOB I ASO HAVE KODAK C713 AND LENS STICKS I HAVE TO PULL IT OUT TO MAKE IT WORK
  • 75 Answers
If you already tried replacing the battery and it didnt solve the problem,
call 1-800-SAMSUNG and set up a repair for your camera.
Posted on Oct 04, 2008
I Know This Problem Is With Cheep Lenses in Samsung Cameras ,
The Solution Is SEND IT TO SAMSUNG :-)
It Is The Only Way
Posted on Nov 29, 2008
My camera does the exact same thing. all you gotta do is bang it when you turn it on. and the lens will come right out
Posted on Oct 08, 2008
Three beeps when i try to turn it on
i had the same problem a while back. I fooled around with my camera lens a bit and it turned out that one side of the lens was sticking out a bit. I pressed down on this and pushed the power button and it worked. The next time I turned it on the same thing happened but if you keep doing the same thing it should work.
Hope this helps!
Aug 21, 2009 | Samsung L100 Digital Camera
Beeps repeatedly, lense won't retract...won't take pictures?
Hi Jeanice21, I just posted the same problem a few minutes ago with my SD400. I followed a few steps of the suggested solutions and here's what worked for me.
1) take apart the front and back by unscrewing the six screws holding the camera together
2) on the left of the flash, there are two little retangular holes with grooved dials in them
3) using a little flat head screwdriver, push up or down to turn the grooves while power up in the movie or capture mode
4) the lens retracted at this point and my camera started working again. Good luck!
Dec 28, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
I have a polaroid i634 can you help?
how do I empty a full memory on a polaroid i634
Dec 12, 2008 | Polaroid i634 Digital Camera
Camera won't turn on, just beeps
first check the battery... charge or replace it... else reset the camera or repair
Sep 05, 2008 | Olympus Camedia D-510 Zoom Digital Camera
Samsung NV10 heeelp!Pleeease
Not sure about the battery... that could be it and I haven't tried switching it out for a new one yet, but in the meantime I am getting around this problem my grabbing the lens with my fingers and "helping" come all the way out... just give it a little pull, a little encouragement and it will come all the way out... but the trick is that you have to do it right after you try to turn it on and before you get the beeps...
So if your lens is stuck out right now and the camera is powered off, then turn the camera on and then pull the lens out before you get the beeps... once you give it a little tug, the mechanics should take over and it will extend all the way... the LCD will come on and you'll be good to go...
Like I said, I'm having this problem too and my girlfriend suggested we change the battery... I guess that's possible, that the battery is not holding enough of a charge to push the lens all the way out... I'll investigate how much a new battery costs and then determine if I think its worth a try...
Jul 10, 2008 | Samsung NV10 Digital Camera
When I try to turn on my camera (Samsung Digimax S500), it beeps 3 times.
My Samsung S500 kept shutting down (with lens extended but no beeping) as soon as it was turned on. After reading similar problems being caused by a jammed lens mechanism, I GENTLY twisted & tugged the extended lens mechanism (no crude comments please), and it worked the next time it was turned on.
Apr 20, 2008 | Samsung Cameras
The lens is jammed.
This is a result of damage to the gear in the motor asssembly.
The gear teeth have been broken off & as a result the gears that drive the opening& closing of the barrel dont mesh together resulting in the jam and your 4 beeps!!
Jan 24, 2008 | Samsung NV10 Digital Camera
Samsung camera power-on problem and beeping
same problem! camera HAD been dropped....carefully pull up with a gentle twist on the 'tilted ' side.
thanks for the tip! camera works fine!!
Oct 05, 2007 | Samsung Digimax S630 Digital Camera
Power does not stay on.
Check out the Samsung Tech Help Team But A stuck lens that is then given some 'help' does not bode well- these are very delicate mechanisms- Chances are it is now damaged - and repairing Digi Cameras is not an economic or technicalfeasability
Jul 02, 2007 | Samsung Digimax L60 Digital Camera
Samsung Digimax D53 Digital Camera Logo
329 people viewed this question
Top Samsung Cameras Experts
Jerry Z
Are you a Samsung Camera Expert? Answer questions, earn points and help others
