Question about Polk Audio M3 Speaker
M3 mounting bracket securing pins
I have broken one of the pins that fasten the M3 AW speaker to the wall bracket. Does anyone know where i can get replacements?
Polk in the US are sending me a replacement pin. What great guys they are.
Posted on Sep 23, 2008
Elan wall speaker mounts
Try Radio Shack, Best Buy, Sears, or eBay.
Apr 13, 2012 | Elan SEL350 Speaker
I need to find out how to mount stereo MA-10D speakers to a wall. I can't see any mounting capabilities on the back, sides, top, or bottom of the speakers. Has anyone successfully mounted speakers like...
Hmmm. .U don't have option given for speakers to fix them onto the wall. You have to do the following steps.
Things U need are:
  • Masking Tape
  • Level
  • Pencil
  • Keyhole saw
  • UL Class 2 speaker wire
  • Fish tape
  1. Locate the studs closest to where you'd like to install your speaker. You'll want to install the speakers in between the studs.
  2. Tape the template that comes with the speakers in the center. Check to make sure your configuration is level and plumb. Your template will tell you exactly what size hole to drill to insert the speakers. Trace the opening you need to cut into the wall or ceiling
  3. Cut the hole using a keyhole saw or a drywall saw. Keep the section you cut open in case you can't install the speaker and need to patch the hole you just made. If the hole reveals plumbing, you need to relocate the speaker
  4. Run the speaker wire through the wall, or fish speaker wire from an existing installation.
  5. Install the brackets to support your speaker if one is included with your speakers. Some speakers use clips to secure them to the inside of the wall.
  6. Strip the protective coating from the end of the speaker wire, and insert it into the speaker jacks. Test your speakers now if the wires are attached to an audio source. If not, locate the other end of the speaker wire and hook it up. Testing now will save trouble if you run into problems.
  7. Surround the speaker with insulation to enhance the sound. Secure the speaker into place, and do any necessary patching or painting
Aug 27, 2010 | Roland MA-10D Main / Stereo Speaker
How to install the mounting bracket to JBL control 25?
big red
they allways have a screw in the back you just tighet it and level your speaker
Oct 17, 2009 | JBL Control 23 Speaker
How can I mount these on the wall?
The WS-100 is a floor standing speaker, and they are equipped with polycarbonate bases, attached right out of the box for ease of setup, providing a secure stable speaker system.For the price you paid I would not risk wall mount but if they must be eleveate I suggust a mounting shelve then the speakers ontop (shelves must hold speaker weight)
Oct 05, 2009 | Athena WS-100 Speaker
Where to purchase a bracket
Unfortunately there are two standards for the pole diameters. Some of the smaller poles have caps to accomodate the larger brackets. First thing is to measure what you have for poles and the two sizes of mounting holes. Many of the mounting bosses are standard and available online here is an example:
http://www.amazon.com/Speaker-Cabinet-Metal-Stand-Mounts/dp/B0035AJTL8
Sep 19, 2009 | Mackie SWA1501 Subwoofer
I have a pair of M3 speakers and one is distorted, it sounds like the cone is warped. What would it cost to replace just the speaker?
I know the problem is a bad speaker it's warped, I was wanting to find a contact to purchase a new speaker. Not the whole housing but the speaker itself.
Feb 19, 2009 | Polk Audio M3 Speaker
Mounting under flat screen tv
There is no wall mount bracket for the VCS-10. It was not designed to be wall mounted. Your best solution is to mount a 22"x8" shelf to the wall 4-6" below the TV. Make sure it is mounted sturdy enough to support 10lbs.
Sep 05, 2008 | Bose VCS-10 Center Speaker
JVC DVD players
Use a sling for multiconnection to connect 8 pin input;
Sling Media - Slingbox
Jul 19, 2008 | Audio Players & Recorders
Dayton SB36 wall mount question
Only you have the answer. Is there enough adjustment if you mounted on your wall specs? If not absolutely no!!!!! To support the weight, you must be in the stud.
But a question. Is this an interior or exterior wall. If you house is made of concrete block, the exterior wall only has 1x2 studs. The interior studs are usually framed by 2x4 (1.5x 3.5 in reality). Some houses use aluminum studes which I personally would not use.
If you are on an exterior wall, you couldn't use wood screws anyway. I would suggest using the appropriate TapCon. A screw made for concrete. An appropriate lenght might be 2 1/2 to 3 inches. This depends on sheetrock (1/2 or 3/4 inch) the depth of the bracket (you need to measure). To find the sheetrock depth simply take the cover off an AC receptacle. See if you some how measure the entire distance to the actual outside wall (stick a skewer along side the box till you make contact). Add 1 1/2" for the concrete, whatever your bracket depth is (at the point were screws go) and viola, you have the proper length of the screw. To size the screw, use the larget that your bracket can take (usually a #10 or 12). Definately pre-drill using the right size bit.
Hope this helps.
Jeff
Dec 21, 2007 | Audio Players & Recorders
Polk Audio M3 Speaker Logo
288 people viewed this question
Top Polk Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Iron
Iron
Are you a Polk Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
