Question about Panasonic TH-42PD50U 42 in. Plasma EDTV
42"panasonic plazama
Half of the screan show picture other half blank
Send it back to wea you purchased it and get them to replace it or refund your money
Posted on Sep 23, 2008
Electronic tech needs help this tv only half of picture is showing what could be the problem i wants to fix it myself
Hello Danyell,
According to the model number you provided you have a 42" Insignia plasma TV. The problem you reported with having just a blank black screen on the lower half is due to a bad lower buffer board or also called a lower scan board. The part number is LJ92-01739C and if you Google this part number you can find these online and also find some sites that may show a short video on how to replace it. Price of this board looks to be about $35. Also of note is you will find that this part number is a Samsung part number which means your Insignia TV has a Samsung plasma panel in it so the associated circuit boards will also be Samsung parts.
May 02, 2014 | Insignia 42" Flat-Panel Plasma HDTV
One half of the t.v screen goes blank
Sounds like a back-light fault. Check its back-light inverter. To get more details, up older posts.
Nov 30, 2013 | Panasonic TH-42PX75U 42 in. Plasma HDTV
Half screan show dark rest screan o k
The LCD screen is defective, the only option is replacement. Go to Type make and model of your laptop, refine search to screen and go through the list.
Jul 06, 2012 | Computers & Internet
Half screen is blank 42lg20 or 42lg50 when
This is likely to be the T-con board. If the entire screen glows but you have no picture on the second half of the screen then it is the main board, not the backlight inverter. If the screen is half picture and half gray it is the T-con board.
Replacement of one of the above will fix the issue.
Please rate if this helped :)
Mar 07, 2011 | LG 42LC2D 42 in. LCD HDTV
I am having a problem with my picture on the top
NEED REPLACED SU BOARD Manufacturer Panasonic Part Number TXNSU1HNTU Description PC BOARD
Feb 17, 2010 | Panasonic TH-42PX75U 42 in. Plasma...
Blank white screane. When i open the camera to take pictures the screen doesnot show any thing it just blank white . the zoom and other thing work
Sounds very strange, hope it isn't serious. Maybe try removing and replacing the batteries. Sometimes a reset helps problems like this. I have the same model.
Jan 20, 2010 | Fuji FinePix S5000 Digital Camera
Half the screen will go blank
it seems to be happening at certain resolutions such as are used
during post screen, splash and those programs.
a lot of kid educational software changes the video output
resolution to run
your monitor would be suspect.
go through the monitor setup, the setup on itself
that doesn't use the computer, see if it has
a reset, see if it has diagnostics to test it out.
Nov 10, 2009 | Sanyo DP42746 42 in. Plasma Television
Picture problem, half screen blank
On a plasma there are 2 buffer boards, upper and lower, it all depends which half of the screen is on as to which buffer to replace, the buffer boards are located usually on the left hand side if you have the back off the unit. You maybe able to reseat the ribbon cables and get the video back up
Feb 17, 2007 | Panasonic TH-42PX500U 42 in. Plasma...
Mitsubishi CS26301 27" TV
Have you tried flipping the pictures so you can troubleshoot it from the larger screen?
Feb 16, 2007 | Mitsubishi WT-42315 42" TV
Half screen activated only
When only a half screen is produced, it is usually a upper or lower buffer board, if the top half is blank then it is the upper buffer, and of course if it's the bottom half then it's the bottom buffer board
Sep 15, 2006 | Panasonic TH-42XVS30U 42 in. Plasma HDTV
Panasonic TH-42PD50U 42 in. Plasma EDTV Logo
98 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
