Question about HP Office Equipment & Supplies
The tape looking thing (3/8 wide X 15 or 16 " long) that runs the cartridge back and forth on the printer has come off. Can I fix it. Thanks, Nancy Tucker
  • steve shroder May 11, 2010
    what model printer is it?
Bought a new printer
Posted on Sep 23, 2008
What's a Carrier jam?
Carrier Jam means that the Carrier which carries the cartridges is not moving correctly in this case please follow the below Steps:
Lift the Flat Bed Scanner up so that you can find the Cartridges Inside.
Remove the Cartridges from the Printer.
Move the Cartridge Carrier Back and Forth as fast as you can!
Replace the Cartridges back to the Printer!
Good Luck!!!!
May 07, 2013 | Lexmark 3-Pack Axis 5400 Print Server .:...
Printer goes about its normal printing actions, sounds, the tray moves back and forth and it sounds and seems like its printing but then the paper comes out and nothing at all is printed on it. Both...
Make sure that the plastic part is taken off the ink cartridges. They are usually sealed with an orange, yellow, or red plastic tape-like thing over the bottom part of the cartridges.
You may also want to run a "clean head" process on the printer. This can also help if there is no plastic thing covering the ink cartridge.
Jul 09, 2011 | Lexmark X125 All-In-One InkJet Printer
Won't print. Orange "alarm" light blinking. When I press the OK button, a thumping noise comes from inside the machine. Maybe ink cartridge container isn't sliding properly?
the ink cartridge head typically runs on a clear tape back and forth , it uses this tape for head positioning. often the tape gets dirty and the head cannot position its self, which causes the ink head to slam into it carriage limits, while trying to find it. solution is to simply and carefully wipe off the tracking tape with vinegar and water. do this while the machine is unplugged and off. Try to move the head around to clean the tape, dont pull or move the tape as it has to run "just so" through the print head. The tape runs all the way across the inkhead travel zone. you will see it. please provide some thumbs up if this helps you. Thanks. Cheers
Aug 26, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Brother printer shows cyan empty Can i fool it so I can print in B
Hi there
There are only a few steps you need to do to reset a Brother printer ink cartridge and once you do it, you will be up and printing in no time. There are actually two things that a Brother printer uses to detect ink and you can manipulate one or the other.
Instructions
Things You'll Need: · Black electrical tape, masking tape or duct tape
1. Step 1
Identify the printer If your printer uses memory, you can tell which printer you have by looking at where the cartridge goes in, if you see two "eyes" and a part of the cartridge goes in between them, follow Step 3. Otherwise, continue with Step 2.
2. Step 2
Clear the memory by taking the cartridge out and unplugging the unit for 30 seconds. Then, plug it back in and put back in the cartridge. You may need to do this five times, as the memory holds the last five cartridges.
3. Step 3
If the Brother printer has "eyes" where the cartridge goes, you will need to block in between them with a piece of tape so that it thinks the cartridge is always full. Simply put a piece of tape on the piece of the cartridge that goes in between the eyes to block the path of the infrared beam
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 29, 2010 | Brother MFC-5840CN All-In-One InkJet...
MFC-6490 CW we have run out of black ,work on offshore gas platform have plenty of colour ,how can i make printer work
Hi there
May be you can fool it so you can use your printer, try this hope you can win.
Instructions
1. Step 1
2. Step 2
3. Step 3
Mar 14, 2010 | Brother MFC-640CW All-In-One InkJet...
Just replaced ink cartridges on my Brother MFC
Hi there you can refill Brother cartidges, like other printers it will not have it sorry.
This is the only way you can trick it.
Instructions
1. Step 1
2. Step 2
3. Step 3
Mar 04, 2010 | Brother MFC 420CN All-In-One InkJet...
Have replaced the ink cartridges and it's still saying they are empty
Hi there
Instructions
1. Step 1
2. Step 2
3. Step 3
Mar 04, 2010 | Brother DCP 115C All-In-One InkJet Printer
Won`t recognize new ink cartridges. Still insists black is empty, other colors low, although all have been replaced. Any way to reset or override? Thanks
Hi there
Instructions
1. Step 1
2. Step 2
3. Step 3
Mar 03, 2010 | Brother MFC-230c Printer
Printer not printing black ink
This is a problem that is always happening with these printers, to fix it, this is what you do: if you look at the cartridge it has a grip tip at the top, for you to pull it out of the printer, after you fill the cartridge put the top back on. Before you put it back in the printer, as you can see, the label on the cartridge goes around the front middle of the cartridge, it give you the model number and so forth. now turn the cartridge around, place a stripe of tape around the top of the cartridge in the same manner as the label, so that the tape is facing the toward the back of the printer. Use tape that blocks the sensor, no clear tape. The reason it does that is because no matter how much you fill the cartridge or how new it is, with this model printer, those sensors go bad and thinks every thing is empty but it only happen on the black, go figure. Try this and when you close it, it will start a long process of cleaning and your ready to go.
Aug 03, 2008 | Brother MFC 7300C InkJet Printer
20 people viewed this question
Ben Johnson
