Question about GE Profile Harmony DPGT750EC Electric Dryer
HELP!Fan on dryer not working
Exhaust fan on dryer not working. need to fix asap large family (7)
  • 750 Answers
Hi, panamapinto,
Huuum at your service,
welcome to fixya.com
Did you try to reset the system?
Some times it is an electronic glitch and you can reset it by doing this simple procedure.
With an error code.
This can reset the system.
First unplug the washer and wait a 5 minutes then restart it.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems if they are not serious.
Or they are sometimes just a glitch.
How old is the appliance?Write back and tell me the age of the dryer.
If this fails let me know!
Huuum
Here is an interesting report I read recently.
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Posted on Sep 23, 2008
Whirlpool gas dryer will not gethot enough to dry
the usual problem is lint build up and or to long of a run for the exhaust tube..When was the last time you cleaned you dryer exhaust ? I had an issue where I had to run my dryer through 4 cycles before a load would get close to being dry. I thought I has cleaned out all the lint from the dryer.. Finally I just ripped out all my exhaust tunes and sure enough there was a a large amount of lint build up where the shop vac did not reach. SO i replaced all the exhaust tubing and since I have a long run I added an exhaust fan, now the dryere works like it should,..
Apr 29, 2014 | Frigidaire Dryers
When Exhaust button pressed, vent fans not working, but microwave running for 30 seconds.
test the components and fix it. God bless you
  1. Exhaust fan motorIf your exhaust fan motor is not running, there are a couple of things that you can check involving the motor to locate the problem. After removing the fan motor, you can manually attempt to turn the fan blades with your hand. If the fan motor is working properly, the blades should spin effortlessly. If this does not occur and the blades are taught, the motor will need to be replaced. Secondly, the fan motor itself can burn out due to time and usage. Using an ohm meter, the exhaust fan motor should read open for continuity. If it does not, then the fan motor has expired and will need to be replaced.
  2. ThermostatAnother part that could cause the microwave exhaust fan to not work is a faulty thermostat. A thermostat gauges the air temperature, which activates the exhaust fan when required. If this part becomes flawed, the exhaust fan will not energize and the thermostat will need to be replaced.
  3. Main control boardIf your exhaust fan is still not working and the microwave fan motor, wiring, and thermostat are operating accurately, the root cause could be with the main control board. Replace the main control board.
Oct 24, 2013 | Frigidaire Microwave Ovens
The vent fan is not working but micro is. Replaced charcoal filter & reset still not working.
follow this steps and fix it. God bless you
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#12#ixzz2gURd1VtM
Sep 30, 2013 | Whirlpool WMH2175XVB Microwave Oven
We changed the charcoal filter & reset it. The vent fan still does not run. I cannot turn the vent on by pressing the vent button but the micro still heats up. What happened to the fan?
follow this steps and fix iT. God bless you
Volkswagon POLO 2001 Manual Problem: thermo fan not working. Hi all, I have since ordered and replaced the fan with a another fan and the fan still does not work!! Could it be the fuse? Initial...
CHECK TO SEE IF POWER GOING TO COOLANT FAN AND COOLANT FAN THERMO SWITCH.THERMO SWITCH LOCATED BOTTOM OF RADIATOR ON THE LEFT HAND SIDE.IF POWER GOING TO THERMO SWITCH THEN SWITCH IS FAULTY.IF NO POWER GOING TO THERMO SWITCH OR COOLING FAN.CHECK LARGE FAN FUSE IN THE ENGINE COMPARTMENT AND YOU HAVE FUSE 16 IN FUSE HOLDER.IF FUSES GOOD YOU HAVE SHORT IN THE FAN WIRE OR FAULTY FAN CONTROL MODULE.SHAKE FAN WIRES IF FAN WORKS PROBLEM IN THE FAN WIRES YOU HAVE A SHORT IN THE WIRES..
Jan 12, 2011 | 1996 Volkswagen Golf
Missing remotes for hampton bay ceiling fans
https://www.google.com/search?q=remotes+for+hampton+bay+ceiling+fans&rlz=1C1PQHB_enUS689US689&espv=2&biw=1536&bih=748&source=univ&tbm=shop&tbo=u&sa=X&ved=0ahUKEwik3qiMx4bTAhXh5oMKHV3vDJ4QsxgIGg
Apr 02, 2017 | Hampton Bay 52 In. White Redington...
MY husband replaced coils on top of gas valve. He
is it completely dead now or does some things still operate??? and what make is the dryer?
Oct 05, 2009 | Dryers
Whirlpool model # lgr7646ez3
Here are a list of causes that may contribute to this lack of sufficient drying.
CAUSE
• Lint screen is clogged with lint.
• Restricted air movement.
Exhaust vent or outside
exhaust hood is clogged with
lint.
• Exhaust vent is crushed or
kinked.
• One fuse is blown or circuit
breaker is tripped. The dryer
will appear to operate, but you
will not get any heat.
• Cycle Control knob or temperature
selector is set on air dry.
• Load not contacting the sensor
strips and automatic cycle
ending early.
• Fabric softener sheets blocking
exhaust grill.
• Dryer located in room with
temperature below 45ºF (7ºC).
• Large amount of moisture in
the load.
• Cold rinse water used.
• Load too large and bulky to
dry quickly.
Here are the solutions to combat the issues.
SOLUTION
• Clean lint screen.
• Run dryer for 5-10 minutes. Hold hand under
outside exhaust hood to check air movement. If you
do not feel air moving, clean exhaust system of lint
or replace exhaust vent with heavy metal or flexible
metal vent.
• Replace with heavy metal or flexible metal vent
• Replace fuse or reset breaker.
• Select the right cycle and temperature for the types
of garments being dried.
• Level dryer.
• Use only one softener sheet per load and only use
it once.
• Move dryer to a location with temperatures above
45ºF (7ºC).
• Expect longer dry times with items that hold more
moisture (cottons).
• Expect longer dry times.
• Separate load to tumble freely.
This will help you fix this problem. i suspect an exhaust obstruction.
Mar 11, 2009 | Whirlpool LGR7646E Dryer
I have a large capacity front load LG electric dryer. I keep getting the "check filter" message & the filters are clean. The dryer will not stay on. HELP!
The message does not only refer to filters, badly written.
There is an air flow restriction that the machine senses and is warning about.
check the fan and fan housing for lint that has got past the screens, then pull the dryer away from the wall and check the exhaust duct for lint, all the way to the wall
then check the outside wall vent for lint build up in the rodent screen
before clean
239f28d.jpg after clean
a605f7e.jpg no clean
Oct 10, 2008 | LG Dryers
Fan is not working
exhaust fan on dryer is not working. I have cleaned the area at the bottom of the lint filter and cleaned the passage of the blower thoroughly.
Jun 09, 2008 | GE Profile Harmony DPGT750EC Electric...
GE Profile Harmony DPGT750EC Electric Dryer Logo
216 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
