Question about Panasonic KX-TG1033S Cordless Phone
Dial tone My phone was disconnected when my computer was being fixed. I have gotten the computer back and have hooked it back up. Now the phone has no dial tone. How do i get the dial tone back?
  • 3 more comments
  • ali_eakes Sep 23, 2008
    how do i get the dial tone back?
  • Carl Navarro
    Carl Navarro May 11, 2010
    Here's the problem. Neither your computer nor anyone here at FixYa "took" your dialtone away.
    Rather than ask us, call the company that provides dialtone. If it happens to be the same company that gives you inernet service, then you're on your way to troubleshooting the problem. If, it's the phone company, they might ask silly things like did you pay your bill, do you have dial tone at the demarc (box outside), and advise you that they'll charge if the problem is not theirs.
  • Carl Navarro
    O.K. I'll play your silly game. What does one have to do with the other?
  • Anonymous Mar 20, 2014
    Dropped the phone and now nothing works. There is no dial tone. What can I do to fix it?
  • Anonymous Mar 24, 2014
    no dial tone. need to change settings
My phone has no dial tone and when you call the phone it has a busy signal. There is no static just sounds like it is not hung up.
Posted on Oct 10, 2008
Off the hook
A "Phone Off Hook" message is not an error. It simply indicates that a telephone receiver isoff the hook(the handset is lifted) and the telephone line is open. This message would be expected in the following situations:
  • A modem on the phone line is accessing the Internet.
  • A phone connected to the HP fax (or the same phone line) is using the line, or the handset has been lifted.
  • A credit card machine is using the phone line.
  • Another electronic device is using the phone line.
  • The Start Fax button was pressed with no telephone number entered. Pressing Stop or Cancel should return the display to a ready state.
When the other device is no longer using the phone line, the display should revert to the normal message.
Lets try the following,
Disconnect the phone cable from the back of the HP product and the message should clear. If the message does not clear, unplug the power cable from the back of the unit, wait 15 seconds, and then plug in the power cable.
if issue still exists try the followign
Disconnect the phone cable from the HP product and connect it to a single line phone. Pick up the handset and listen for a dial tone. If no dial tone is present, replace the phone cable. If a dial tone is still not present, a problem exists with the phone system.
Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
HP Support
Apr 22, 2014 | HP OfficeJet 4215 All-In-One InkJet...
Dial tone of my phone disappears whenever i switch on my computer and my d link dial up modem can't find dial tone. What should i do?
Disconnect the telephone-cable from the computer's modem.
Does your telephone regain the dial-tone?
If so, then replace the computer's modem -- it is going "off-hook" as soon as you turn on the computer, not just when you try to use the modem to open a dial-up session.
Sep 27, 2010 | D-Link DFM 562IS (DFM-562IS) Modem
Phone won't transfer to next free line when a second call comes
If you are not getting a dial tone then something is holding the line off hook. Disconnect any other device you have on your lines and check to see if you get your dial tone back. If you still have no dial tone unplug each phone and check again. You may have to disconnect everything for a minute or two so the phone company will reset its equipment. Plug in your phones one at a time and check your dial tone every time you add something new.
If you add something and you loose your dial tone immediately you may have a crossed connection in the wall socket, any splitters or in the phone plug. Check to make sure all of the wires in those sockets are straight before you plug in your phone wire.
If you add your CC machine and everything is good but it fails after you run a transaction you will have to contact the supplier of your CC machine. It is not hanging up the line.
Mar 22, 2010 | Panasonic KX-T7730 Corded Phone
HP officejet all-in-one...keeps saying phone is off of the hook and will not give me a dial tone to fax. Is there a particular setting I need to check ?????
The very first thing to check with a fax machine is that the line itself is OK. The possibilities are much greater that there is a problem with the LINE and not the HP itself.
Hook up a regular telephone to the fax line, disconnecting anything else that may be on the line. If the telephone doesn't have a dial tone, call the phone company. If you DO have a dial tone, then maker sure that the phone line is connected to the correct port on the HP. There are two, usually. One is for the LINE and the other is for an EXTENSION (a phone that is daisy chained off the fax machine). If you have the LINE connected to the EXT port, it may give you this error.
If you have multiple items connected to the same phone line, try removing all of them but one regular phone, and see if you have a dial tone. If so, add the other items back, checking for a dial tone after each one. If one of them causes a lack of dial tone, replace or repair it.
The phone company may tell you that the problem lies in your inside wiring. I have seen that before. You can take your phone out to the telephone service box on the outside of the building. These usually have regular phone jacks in them. Disconnect the jack wire that runs into your house, and connect the regular telephone into the box itself. If you have a dial tone, then there is indeed a problem with the wiring in your building.
Jul 16, 2009 | HP Office Equipment & Supplies
No Dial Tone
Dear Sanyte1226,
Double Check that all handsets are registered, and make sure that you don't have to many phones connected to the jacks throughout your home. If all fail, very slowly, make sure the phone is on speaker, and slowly move the telephone port into the jack SLOWLY like slower than slow motion. If you here clicking, keep pushing it in slowly until you here a dial tone. I know this has happened to me before.
Best of luck, The Writer.
Jun 02, 2009 | Uniden DXAI5188-2 Cordless Phone
No dial tone
Please disconnect your cordless phones from telephone jacks throughout the home. The "line in use" is say that you have a short on the line, or a phone off the hook. So disconnect lines, then replug 1 corded phone in to check for dial tone. If working, continue to plug in 1 phone at a time(rechecking working one each time) to find the equipment that is causing you heartache.
Apr 21, 2009 | Uniden Cordless Phone
Phone off hook message
hi,
The most common reason for this message is when a dial-up modem is accessing the Internet on the same phone line. Just as two phone calls cannot come in at the same time, two devices cannot use the phone line at the same time.
f a broadband modem (such as DSL or ISDN) is on the same phone line and the message appears all the time, please contact your Internet provider for assistance. Even if a dial tone is present when listening to the phone line, the HP product may detect the broadband data connection at the higher line frequencies. Broadband modems must have a line filter installed to work correctly. Contact the telephone company for assistance. Please follow the directions below to verify functionality.
  1. Verify that the phone cable going into the HP fax product from the wall jack is a two-conductor cable type, not four-conductor. A two-conductor cable, like the one that ships with the HP product, has two copper leads in the connector. The connectors are usually clear, making it possible to see how many copper leads are inside the cable. Replace a four-conductor cable with a two-conductor cable.
  2. Disconnect the phone cable from the back of the HP product and the message should clear. If the message does not clear, unplug the power cable from the back of the unit, wait 15 seconds, and then plug in the power cable. If the message persists, see the "Problem still exists" section below.
  3. Disconnect the phone cable from the HP product and connect it to a single line phone. Pick up the handset and listen for a dial tone. If no dial tone is present, replace the phone cable. If a dial tone is still not present, a problem exists with the phone system. Continue with the steps below if a dial tone is present.
  4. Plug the phone cable back into the HP product and hang up any phones with a lifted handset.
  5. Disconnect, one at a time, other phones and devices using the same phone line. Check the HP product display after disconnecting each phone or device. If the message clears after disconnecting a phone or device from the line, the problem is with that phone or device.
  6. If the message still exists after unplugging all other phones or devices, see the "Problem still exists" section below.
Jun 23, 2008 | HP Photosmart C6180 All-In-One InkJet...
Dial tone
I disconnected the RadioShack phone/answering machine and plugged in an old phone. At first I didn't get a dial tone, but in a minute or so, I did get one. I doublechecked the connection with the incoming phone jack. (I had checked this before, but didn't see anything wrong.) Again, I didn't see anything wrong, but maybe that did it. Also, when I disconnected the RadioShack from the incoming phone jack, I disconnected from my computer (I used to have dial-up connection).
Don't know which of my actions worked, but now I have dial tone on Radio Shack.
Hoooooooray!!!!
Jun 22, 2008 | Radio Shack 433575 Cordless Phone
Bell phone
is your computer hooked up dsl or dial up? unplug all the phones and computer from the phone jacks.plug a corded phone into the jack and check for dial. if you don't have dial tone, call your phone company. if you do have dial tone, plug everything in one at a time and see if the phone line goes dead.if it does, the last thing you plugged in is the problem.
wg
Feb 10, 2008 | Lands Phones
Panasonic KX-TG1033S Cordless Phone Logo
485 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
