Question about Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range
Oven does not heat up, element problem
Just fund your site today. Very impressive, I had the range replaced w/i warranty for chipping enamel, and serviced for a control board. Range is now 6+ years old.
Found that a section of the element has broken off thus breaking the circuit. Please provide the steps for replacement, I have an idea how to (I'm a EE) but would still like some guidance along with any tips on how to complete the job.
Also, have checked on the WEB for the part but have not found the exact item, any suggestions would be appreciated.
  • 116 Answers
For the element you could check at www.repairclinic.com
with respect to replacing the heating element you did not say which one it was (bake or broil). But you should be able the replace the elements by (first unplugging the unit) removing the scews from the panel at the back of the unit. Once removed you should have access to the "stab on" connectors - undo them then undo the two screws that secure the element inside the unit. replace with new one and reconnect and redo screws
Regards
Posted on Sep 23, 2008
A plastic plate was put by mistake into our oven. It melted all over the bottom enamel. Trying to get this off with a knife and a razor blade has chipped some of the enamel. Can this be repaired .....
IM NOT SURE ABOUT THE TOXICITY BUT IF YOU HEAT UP THE OVEN AND WITH A GLOVE ON HAND AND A PUTTY KNIFE YOU SHOULD BE ABLE TO REMOVE MOST OF IT. THEN MAYBE RUN A SELF CLEAN CYCLE WHEN YOU CAN OPEN THE WINDOWS AND REMOVE ANY SMALL CHILDREN FROM THE HOUSE.OTHER THAN THAT THE SPOT YOU REMOVED THE ENAMEL YOU MAY USE A BBQ GRILL PAINT TO COVER THE METAL OR JUST LEAVE IT.GOOD LUCK!
Mar 07, 2010 | Kitchen Ranges
If you enter the model number on this website, you will get the exploded view, and you can buy the part.
Oct 04, 2008 | Ovens
Electric oven will not heat
Hello there:
This conditin is usually caused by a faulty element and or the relay for the element is bad and also the temperature setting switch could be faulty
so what i would have to suggest is to have the heating element replaced first cause the temperature switch rarely fails ok
If you still; have the warranty with this oven i would use it the element is going to cost around 50 dollars or so ok
Best regards Michael
Dec 04, 2009 | Kitchen Ranges
Enamel chipping
the interior of the oven cavity is chipping??? if so not a worry or concern for saftey or health concerns stictly cosemetic
Nov 12, 2008 | Ovens
Heating element in GE Range Oven
get the model number and order the exact repacement bake element
Mar 10, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Oven enamel chipping
Never heard of such a problem, you are the first to post it. There is no fix for this.
Apr 03, 2017 | Dacor Epicure ERD30 Dual Fuel (Electric...
PAINT CHIPPING
you can go to the appliance parts store and get touch up enamel or Lowe's carries it too if its not too old check your owners manuel for extended warranties some are warranted for extended periods but most consider it normal wear and tear
Jan 25, 2008 | Kenmore 46123 Stainless Steel Electric...
LG Range Element Will Not Heat
on my 30755 top left element will turn on but not adjust top right turns on to high only will not adjust . 3months out of warenty
Nov 27, 2007 | LG LRE30755 Electric Kitchen Range
Electric oven does not heat up enough
I had the same problem before the warranty expired. The heating element had exploded and there was white powder all over the inside of the oven. They replaced the heating element and it works as it should, however, this oven has never baked right. It gets hotter on the right hand side than it does the left and I have to constantly watch whatever I bake. I'm not very happy with this oven.
Apr 27, 2007 | Maytag MER5755QAS CleanDesign Electric...
The only solution I know of for the enamel coming off on these units is replacement of the unit, and since it is 4 years old you are going to have a tough time getting dacor to replace it or even give you a credit towards a new one. I have never actually seen the problem on a Dacor. Does the unit have a hidden lower bake element? If you cannot seee the elemnt its hidden, and you cannot put tin foil on the floor of any unit wiht a hidden bake element, as it will damage the finish. I know this isnt much help, but I work on Dacor products regularly as we are an authorized servicer, and I can't say I've ever seen a finish problem on one. Best bet at this point is to call Dacor and see if they will do anything about it. Good Luck!
Jan 12, 2007 | Dacor ECS127 Epicure Stainless Steel...
Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range Logo
127 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
