Question about DMTech DM-AV10 Digital Media Player
No turn on
Nokia charger by accident plugged in . now unit does not power up
  • 8,596 Answers
I would call the maufacturer to see if you are still under warranty. There is not a repair service for that device. Sorry.
Posted on Sep 27, 2008
How do i get my nokia lumia 521 to turn on
Hi, you should be able turn the phone on as you would normally, you may have a faulty charger, try another charger, or usb cable if you have one plugged into a laptop which is powered up. I have a Lumia 620 and a kindle charger fits mine.
Hope this helps.
Mar 09, 2015 | Nokia Lumia 521 Windows Phone T-Mobile...
Tip
Make your nokia N97 work smoothly
Many nokia N97 users face the problem that their nokia N97 phones do not work smoothly. Here, i have got some tips to make nokia N97 work smoothly. You don't need to restore or format your phone, just simply follow the below steps and you will get your nokia N97 working smoothly: 1. Turn OFF the phone. 2. Connect charger to the phone. 3. Remove the charger when the screen lights up and wait until it goes OFF. 4. Turn the phone ON immediately, using the POWER button (on top). 5. After the vibration at start-up, plug in the charger. Now, you will experience a new smoothly working nokia N97.
on Oct 02, 2011 | Cell Phones
Will American power tool batteries work after being plugged into a 220 charger
Yep. they will as long as the 220 volt charger was connected to 220. If a 220 volt charger is plugged into 110 volts it may not charge the battery but no damage to the battery will happen.
Dec 04, 2014 | Drills
My Nextbook wont turn on
Although it is not recommended for normal operation, try turning it on with the charger plugged in. If this works, check the battery status indicator. If it shows a full charge, try disconnecting the charger. If the Nextbook quits working, the battery is bad.
If it does not turn on, try holding the power button for five seconds, then while holding the power button on, plug in the charger and continue holding for five seconds. If nothing happens, release and press the power button again with the charger still plugged in. (This may reset the internal power management chip.) Also, try the recessed reset switch (see your owner's manual).
If none of this works, verify that the charger unit is good. The simplest and safest method is to measure the output voltage on the output plug with a digital multi-meter while the charger is plugged into an AC outlet. It should be within 5% of the nominal output voltage on the charger label.
The most common power problems are battery failure, broken charger wire (usually next to the plug or the power conversion box), or broken charger jack in the unit.
Jan 10, 2012 | Office Equipment & Supplies
Just replaced batteries and unit is operating good since i installed the battteries and i try to put on charger it says it is in the charge inhibit mode that is according to the flashing lights what does...
All that eans is that when you are charging the batteries you are unable to drive the chair. Its a safety feature to ensure that you won't accidently make the chair move with the charger plugged in. Just plug the charger into the charger port turn off the chair and then plug the charger into the wall charge overnight and in the morning unplug the charger from the wall and then from the joystick. Always have the charger off when plugging ang unplugging from the chair. With the M41 charger get a power strip with an on/off switch plug the charger into the strip and use the on/off switch to turn the charger on and off before you plug it into the chair Hope this helps you
Jun 20, 2011 | Electric Mobility Invacare Pronto M41...
When a plug the charging pin into nokia 2300 the display is not charging (any solution)
i have a nokia 2300 when charger is plug in it dis plays not charging
Jul 14, 2009 | Nokia 2300 Cellular Phone
IPhone dont turn on
Keep the home and power button pressed for 10 seconds, then, leave power and keep the home button pressed...shud be able to see the charging cable logo...then restore it...
Jul 05, 2009 | Apple iPhone 3G
NOKIA 5310 can't turn on
Did you replace battery recently? Sounds like it has bad or wrong battery. If not, it is just dead.
To fix:
Power up phone on charger
While it is ON, pull the battery
Leave out for 1/2 to 3hr - phone still plugged in
Replace Battery, phone will power cycle and start charging
Leave plugged into charger 10-14hrs
Should be good now
Mar 26, 2009 | Nokia 6500 Slide Cellular Phone
N70 refuses to turn on nor charge
Hi
You can reformat your unit.. just follow this instructions. just off the fone then, press together the key no. 3 Astiris and phone in.. press in sustained position then turn on the power switch then you can see your fone is starting to reformat...
your unit has a virus...
Jan 06, 2008 | Nokia N70 Cellular Phone
DMTECH DM-AV10
I would change the battey, if its not the battery i would place the media player on top
of some paper, stand back and admire your new paper weight.
Oct 27, 2007 | DMTech DM-AV10 Digital Media Player
Open Questions:
DMTech DM-AV10 Digital Media Player Logo
151 people viewed this question
Top DMTech Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a DMTech Audio Player and Recorder Expert? Answer questions, earn points and help others
