Question about KitchenAid Refrigerators
Kitchenaid fridge (ksrw25crss02)icemaker slowly stopped working, decreasing in the amount of ice it made until finally no ice at all. also, water trickles from water dispencer.
  • 750 Answers
Hi kev215,
welcome to fixya.com.
Huuum at your service.
You said, the ice maker slowly stopped working, decreasing in the amount of ice it made until finally no ice at all. also, water trickles from water dispenser.
The first thing I would ask is when did you last change your water filter in the fridge?
Or if it's an older fridge with an inline filter behind the fridge!
check the shut off valve for the water line that leads to you ice maker. under the sink or in the basement or where ever the line comes from. I've seen where someone turned the valve a little clockwise unbeknown to the home owner and stopped or slowed the water flow.
The water line should be checked too, for any kinking that may be running behind the fridge or some unseen place!
How old is the fridge??
Let me know,
Thank you Huuum
Posted on Sep 23, 2008
Opened up the freezer to find a spray of ice over everything. Assumed it was water from the icemaker so shut it off. Any suggestions? Thanks in advance, bob.
Suspect ice delivery tube froze slowly causing water to compress and spray. Delivery tubes can naturally freeze. Altho it more often happens because the fill valve does not shut down 100%. Small amounts of water are pushed via line pressure and slowly restrict the delivery tube. Fill Valve 4389178 Est $85 -110.
Ric
Mar 09, 2010 | KitchenAid KSRG22FK Side by Side...
Kitchenaid Superba Ice Maker quit
If you add some water there, yourself. It should make some ice for you, untill the water runs out.
Try this
http://www.acmehowto.com/howto/appliance/icemaker/diagicemaker.php
Sep 08, 2008 | KitchenAid Superba Architect KSCS25INSS...
Our Jenn air fridge is a few yrs old. A few
ok stop the water // the water valve is bad..very bad . change it ..its a dual valve in the back . right where the lin is hooked up . this will correct problem .. **** hope this helps . i think it will .. / feed back pls ..
Jan 12, 2010 | Refrigerators
Ice maker stopped making ice yesterday. I changed the water filter, but it still hasn't done anything There are no ice cubes jammed.
the icemaker line from the basement to the fridge may be bad, clogged or the little fitting they put on the water pipe to connect the plastic line to your fridge could have sentiment in it, clogging the water. Ice Maker needs a certain amount of pressure in line to work properly!
Dec 06, 2009 | KitchenAid KSCS25FKSS Side by Side...
My icemaker overflows and does not produce cubes but a solid block of ice over the unit and down into the cube reception tray and over the bottom of the freezer unit. Have removed all the ice and restarted...
Hi
you need to adjust the water level, carefully remove the front cover of the ice maker itself.
On the front of the ice maker, there is a small nylon screw that controls the water intake amount.
If the screw is turned to the Right, it will Decrease the amount of water entering the ice maker.
If the screw is turned to the Left, it will Increase the amount of water entering the ice maker.
The screw should only be turned 1/4 of a turn at a time; therefore, more than one adjustment may be required.
The maximum adjustment is one full turn in either direction. Additional rotation could damage the ice maker..
OR
Dirty icemaker water valve or broken valve can cause icemaker to overflow.
Thanks for contacting fixya.com
Oct 22, 2009 | Hotpoint Refrigerators
Cant get water out of the fridge door
hello allamericananp,
Let me know,
Thank you Huuum
Sep 23, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Kitchenaid superba icemaker
HI thanks for the question On the ice maker you should have an metal arm thatlifts up &down Down means you want ice Up means the ice bucket is full if that arm is not there that will cause the problem if the arm is there make sure it moves up & down ok if it does Then you need a new ice maker or save money & when the bucket gets full turn off water at back of fridge to stop water from coming in thanksfor the question THe appliance doc
Sep 03, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Kitchen Aid Ice maker Stopped working
The ice maker has stopped working. The red led light blinks when the freezer door is opened. Any thoughts?
Nov 22, 2007 | KitchenAid Superba Architect KSCS25INSS...
Ice Maker leaking water in freezer and won't stop making ice
The filter should be before the fridge and should not affect it it sounds like the water valve from the fridge is defective .Other possibility is the icemaker head is defective and needs changing.
Nov 17, 2007 | KitchenAid KSCS25IN Side by Side...
Refrigerators Logo
294 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
