Question about Asko D1996SS Built-in Dishwasher
Lights on the Asko D1996 keep blinking
The lights on the dishwash keep blinking, if I close the door on the washer while the dish washer is blinking water drains into the sink. If I hold down the start button the lights seem to reset but when I close the door nothing happens.
  • Anonymous Nov 30, 2008
    Lights blinking, dishwasher does not turn on
This depends on the blinking pattern. Of the eight lights on the panel, if the four on the left blink on and then the right four lights blink on as the left ones go off, and keep blinking back and forth, that just means the mode has been set and the Start button pressed. After closing the door it should just continue on wherever it is in the cycle. (This is normal operation).
If you hold down the Start button, this resets the dishwasher. If you then close the door, nothing will happen because it thinks it's done.
If the lights are blinking in a different pattern, such as they all blink on and off in unison, that indicates an error condition and needs to be diagnosed. If the pump is not running constantly, then at least it's not because water is leaking out somewhere.
Posted on Sep 18, 2009
GE Quiet Power 3 won't start when door is closed.
What is the exact model number? This may be an issue with the cables that connect the door to the power supply.
Apr 06, 2018 | GE Dishwashers
Dishwasher starts program, then few mins in pause/start button flashes "insufficient water supply". Checked all hoses and all clear. Anyone? Thank you. Glen
As soon as the waser begins the wash cycle pause, open door record water level in sump.
Close door and continue cycle until machine faults and stops.
Open door, record water level in sump.
Compare before and after. If level is low that the flapper valve that allows the water to drain is stuck open and the water is draining into the sink as the unit is washing.
To confirm, if the washer drain hose is connect to the neck of the disposal or sink drain, observe the drain after restarting the wash cycle from the beginning. If water is trickling out from the dishwasher while it is washing then it is confirmed the drain door is not closed if equipped with that configuration.
All washers have a process and hardware to drain. Some have a sepperate drain pump
Hope thisd helpd?
Jun 29, 2017 | Dishwashers
Water backs up from the drain in my dishwasher and smells. what is the problem?
Two things can cause this problem:
1. The check valve in your dishwasher may be defective, allowing water and food debris to seep (or run) back into your dishwasher.
2. Your drain hose may not be "mounted up" the way it should be. Look under your sink. Look at how your drain hose is connected to your garbage disposal. If the hose runs down to the floor of your cabinet and into your dishwasher, that is wrong. Instead, it should be mounted up so that water from the sink and garbage disposal would have to flow up first to get into the dishwasher. If you do this, then even if you have a bad check-valve in the dishwasher, it will prevent the problem (or greatly reduce the problem) of dirty water flowing back into your dishwasher.
May 17, 2015 | Kenmore Elite Stainless Steel 24" BuiltIn...
Bosch shv46c03uc
I would check the latch on the door..When you shut the door it makes contact telling the washer it's closed
Aug 17, 2013 | Dishwashers
Rinse aid dispenser not working
You have to take apart the whole door panel to see what the problem is,.
Jun 07, 2013 | Asko Dishwashers
The normal wash and heated dry lights keep blinking on my GE Quiet Power2 dishwasher. Every few minutes it will beep. I am unable to wash dishes.
Check the door switch, is the door completely shut? Door switches will ware out, they are used everytime you open, and close the dishwasher
Dec 13, 2012 | Dishwashers
Electrolux dishwasher overflows
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
Aug 09, 2012 | Dishwashers
Water keeps backing up on to my counter top from a drain on the sink. WHY?
If you have a built in disposal in your sink, the perforations in the disposal screen are too small to let the water exiting from the dish washer's pump to go down the drain fast enough, or the perforations are clogged sometimes. The answer is to put a sink stopper in the drain of the sink, which will block the back flow.
Jan 01, 2011 | GE Nautilus 24" Built-in Dishwasher
Dishwasher control light blinking
1 Press down the overfill protection float on the floor of the dishwasher's tub in the right, front corner near the door. If it cannot move up and down freely, the "clean" light will flash.
2 Make sure the dishwasher's water supply is turned on.
3 Look for suds on the inside of the dishwasher and wipe them off with a wet cloth. If the washer's sensor detects suds or foam, it may not run. Use the correct amount of dishwasher soap, not hand soap or detergent for washing dishes in the sink, to ensure suds and foam do not form. Also, make sure the cap on the rinse aid dispenser is secure--this will keep suds and foam from forming as well.
4 Close the dishwasher door. Push the "normal wash" button, then push the "heated dry" button. Push the "normal wash" button again, and push the "heated dry" button again.
5 Watch for all of the lights on your Kenmore dishwasher's panel to turn on and then turn off. The washer may start a new wash cycle at this point; if you do not want it to do so, press the "cancel" button. Otherwise, allow the dishwasher to run through this cycle.
Nov 25, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Asko D1996SS Built-in Dishwasher Logo
846 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
