Question about IBM NetVista PC Desktop
Will not boot up
Hi, My IBM NetVista will not boot up or turn on in any way. I suspect the motherboard is not working. Any suggestions?
Regards,
Jeff
  • Anonymous Oct 05, 2008
    3223
    Guru:
  • 257 Answers
If u are sure that the power cables are connected to the power supply very well and not even your power socket failing then there is a problem on your power pack not functioning or the motherboard is bad.then change it and have peace wiith your IBM.bye
Rate this solution.
Posted on Oct 01, 2008
How many extra usb circuits are there on my ibm 09k9982-011 mother board
IBM 09k9982 011 ATX MOTHERBOARD P3 11s19k5609z 1N0Z9131W3C Netvista Socket 370
Condition: Used - pulled - working
Content: 1 Motherboard only
Compatible part # 06P2525 01
FRU 09K9982 , 89P8010
Chipset Intel 815 - FSB 100/133 - 2x Dimm PC100/PC133 - Agp 4x - 3 PCI - 2 USB
IBM 09K9982 Netvista Pentium III Moederbord.
Socket 370 Mini-ATX.
Intel 815 chipset.
2x Dimm pc-100/pc-133
Agp-slot (4x)
3x PCI
2x USB
Sound and Video on-board.
To use with : FOR IBM Netvista Socket 370 , 6648-TAU
hope this helps
Dec 11, 2010 | IBM (09N5424) Motherboard
IBM netvista PIII type 6579 MNU doesn't boot
Sound like the memory is not compatable, try booting with no memory installed and see if the hard drive appears, if so it's a memory problem.
Apr 05, 2009 | Computers & Internet
Ibm netvista trying to boot from a non-existant lan system.
With my netvista I was able to get boot options with F12 when powering up. I don't know if this will help you because I was installing a new hard drive. Larry
Mar 06, 2009 | IBM NetVista A40 PC Desktop
I have ibm netvista desktop.when i reset biso time & date not chage.
Hi there:
when you are resetting the bios are you removing the battery from the motherboard and leaving it out for at least 30 to 60 seconds minimum please let me know there is still more that i can do to help solve this if needed ok?
best regards mike
Feb 18, 2009 | IBM NetVista A40 PC Desktop
Older model
How to enter IBM Netvista Setup F1 - BIOS setup ( press repeatedly )
F12 - Change boot order ( press repeatedly )
hope this helps
regards
Nov 19, 2008 | IBM NetVista PC Desktop
I have netvista 6578rbg, it can boot from the hard disk
Hi lyonson, I gather at one time the drive did function with Vista? IBM has some fix on their web site. Click this link below.
http://www.ibm.com/search/?v=14&en=utf&lang=en&cc=us&hpp=10&catx=Y1zkzPzk6z93z46zP7&q=netvista+6578rbg&cp=&lv=c&cat=k6&x=12&y=10
Even if one of these fix's does not match your exact model no# . Try one that is close. If it does not help call IBM. I assure you it is not your PC but Vista. (There has been & will continue to be more down time with MS's Vista than any other previous version of windows to date). If non of IBM's files listed help you, please call IBM from this link. http://www-304.ibm.com/jct03004c/support/operations/us/en/contracts?cm_re=masthead-_-myibm-_-cs-contracts
I wish I could help more but other suggestions involve erasing the drive & that's not a good idea if you have data on it.
I would appreciate it if IBM solves this issue or one of the firmware’s fix your issue & you post the results. I’d call IBM my self if I had all needed information written on the NetVista PC.
Good Luck!
Mike
Mar 30, 2008 | IBM NetVista PC Desktop
I have same problem as ninja9er
hi,
First try Using one at a time, since its not advisable to use memory chips with variable bus speeds i.e (333 & 266).
Since IBM Computer are little complicated i would suggest your to call the customer care or Tech support for assistance in buying a Memory module. In that way you can cross check the memory module you have bought is compatible with the computer.
Kindly give a feed back to Improve my statistics and to see If it was helpful for you...
Thanks and Regards
Mar 22, 2008 | IBM NetVista M42 PC Desktop
Re:Bios jumper
Your computer is an IBM Netvista 8311.
This link shows ibm netvista 8311 motherboard diagram
www-307.ibm.com/pc/support/site.wss/document....
The cmos reset jumper it is indicated on nr.10, alternatevely when you cannot find reset jumper on a motherboard you can pull out and put back motherboard battery
Best regards
Mar 17, 2008 | IBM NetVista PC Desktop
IBM NetVista PC Desktop Logo
167 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
