Question about Bosch Power Tools Sanders Orbital Sanders
Orbital sander 5" random orbital sander Stop working after about 10 minutes, it is brand new.
  • seal2_us Dec 12, 2008
    will not orbit takes a while to come up to speed like it is slipping.
  • 99 Answers
You should really take it back to place of purchase and get it replaced/fixed under waranty. If you try anything other than checking the fuse you will invalidate the warranty. Most manufacturers allow retailers to replace faulty tools within seven days of purchase. Be sure to take your receipt with you as a copy will be needed for the shops warranty claim.
Posted on Nov 01, 2008
Makita orbital sander does not orbit with new pad
there is bit more to the pad than just attachment surface, please have look at this page:
your description suggest that there is no connection between pad and clutch, i would recommend to study the drawing, dismantle machine again and put it together again. where appropriate, use grease (i would suggest use of ptfe (teflon) dry spray grease on all moving surfaces and bearings), after service, use lowest possible settings, (disconnect filter! it is useless - use external vacuum if possible, connect to the pipe where filter was attached.) increase settings every minute or so till you have maximum.
lower the settings to your operational requirement and use as usual.
hope this will help you solve thsi little problem, if you find this answer helpful - do not forget to say so...
Dec 21, 2014 | Makita Bo5041k 5" Inch Random Orbit Sander...
Ridgid random orbit sander will not turn on
Mine also, in the middle of a job and it just stopped, no warning , did not slow down or bog just quit.
Apr 26, 2014 | Ridgid R2601 5-Inch Random Orbit Sander
My 5" random orbit sander model 333 is spinning out of control. What do I do?
I may not have the whole picture, but all random orbits spin wildly if they are not pressed onto the wood a little. Do you mean it is not oscellating, but just spinning when it is on the wood? That would be an issue requiring cleaning or repair, otherwise, just don't turn it on until you have placed it on the wood to avoid marring.
Sep 07, 2010 | Porter Cable Random Orbital Sander, 5"
Orbital sander doesnt orbit!
Never start the Sander without first placing it against the surface to be sanded. In free air the Sander will not osolate.
Jun 12, 2009 | Makita BO5010 5" Random Orbit Sander
3725Bosch 5" random orbit sander, loss of power!!
The 3725 had an overlap winding problem in the armature allowing no full power under load, I replaced mine three times before getting a good one, best 5" on the market tho.
Jun 07, 2009 | Bosch 3725 Devs, 5" Random Orbit Sander,...
Porter Cable Random Orbital Sander rotates but does not "orbit"
Just solved my problem with Porter Cable 333 orbital sander which just groaned. I thought the worst. I carefully took it apart on the garage floor and immediately suspected it needed lubrication as the motor turned hard. I used my flexible long plastic tube lubrication and put some on the bottom bearing shaft the best I could. I worked it around and around. I began to feel it turning easier. I applied more oil and kept moving and it became completely free. I put a drop on the top bearing even though it was loose. I put it all back together and it works like new. Lesson: do not look for the worst when a tool quits. Suspect the culprit to be lack of lubrication!!!
May 20, 2009 | Porter Cable 332K Quicksand Random Orbit...
Makita 5" Random Orbit Sander
The armature windings have an overlay problem in the wiring causing this and there is no soluation except to replace the armature which is not cost efective unless you are still under Warrantee and get a free replacement, it will burn up at some point. If you bought it within the last month take it back and get a new one, over one month, pack it back up in the original box and send it to address in the owners manual for repair or replacement service addresses.
Feb 19, 2009 | Makita 5" Random Orbit Sander
Bosch Power Tools Sanders Orbital Sanders Logo
338 people viewed this question
Top Bosch Tools & Hardware - Others Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Bosch Tool and Hardware - Other Expert? Answer questions, earn points and help others
