Question about Gateway 7405GX Notebook
Can not even use restore disks
I had serious errors reported out of no where, now i am unable to get into windows... I use a SP3 disk to try and restore and it was unable to finsih due to a missing file and i got a blue screen a couple of times while trying... i used the gateway restore and it too can not get past the blue screen of death just durning installing and formating... how is that even possible?
error: PAGE_FAULT_IN_NONPAGED_AREA
0x00000050 (0xE17C323e, 0x00000001, 0x80468c80, 0x00000001)
when you can't factory restore what can i try!?!?!!?
  • 84 Answers
From microsoft below ....
Bug check 0x50 usually occurs after the installation of faulty hardware or in the event of failure of installed hardware (usually related to defective RAM, be it main memory, L2 RAM cache, or video RAM).
Another common cause is the installation of a faulty system service.
Antivirus software can also trigger this error, as can a corrupted NTFS volume.
Resolving the Problem Resolving a faulty hardware problem: If hardware has been added to the system recently, remove it to see if the error recurs. If existing hardware has failed, remove or replace the faulty component. You should run hardware diagnostics supplied by the system manufacturer. For details on these procedures, see the owner's manual for your computer.
Resolving a faulty system service problem: Disable the service and confirm that this resolves the error. If so, contact the manufacturer of the system service about a possible update. If the error occurs during system startup, restart your computer, and press F8 at the character-mode menu that displays the operating system choices. At the resulting Windows Advanced Options menu, choose the Last Known Good Configuration option. This option is most effective when only one driver or service is added at a time.
Resolving an antivirus software problem: Disable the program and confirm that this resolves the error. If it does, contact the manufacturer of the program about a possible update.
Resolving a corrupted NTFS volume problem: Run Chkdsk /f /r to detect and repair disk errors. You must restart the system before the disk scan begins on a system partition. If the hard disk is SCSI, check for problems between the SCSI controller and the disk.
Finally, check the System Log in Event Viewer for additional error messages that might help pinpoint the device or driver that is causing the error. Disabling memory caching of the BIOS might also resolve it.
Posted on Sep 23, 2008
Running avast computer shuts down showing system recover from serious error.
Did you have Avast installed previusly or was it the first run?
In any case, try to do a System Restore to a point previous to this strange behaviour.
If you can't localise it in your Programs (Start) find exe file in
C:\Windows\System32\restore\rstrui.exe
Presume your system disk is C: and system forlder is windows. Use the proper one if it's different
Aug 01, 2015 | Microsoft Windows XP Professional
Download OS Cd for emachines E728
which operating system??????
try downloading the operating system again
SP3 is the third and final service pack released for Microsoft Windows XP, and it eliminates many of the security holes that previously affected XP. While Microsoft recommends that users download SP3 using Windows Update, some users are unable to do so. However, it's easy to create a Windows XP SP3 installation CD; it requires only that you download the pack from the website and burn it to a CD-R/DVD-R using an ISO burner program.
Download the SP3 installation ISO by visiting the first link listed in the "Resources" section of this article. Save it to your Desktop. Download ImgBurn and save it to your Desktop. Double-click the installation executable for ImgBurn and click "Next." Follow the remaining onscreen prompts and click "Finish" to complete installation of ImgBurn. Insert a blank CD-R/DVD-R into your DVD drive. Open ImgBurn by going to "Start," "Programs" and "ImgBurn." Click "File," then "Browse for a source file." Navigate to your Desktop and select the SP3 ISO file. Click "Open." Click the blue "ISO to CD" button located on the bottom left of ImgBurn. The program will begin creating the Windows XP SP3 installation CD. This process may take anywhere from 10 to 20 minutes to complete depending on the speed at which the CD-R/DVD-R is being burned. Click "OK" once the CD-R/DVD-R has finished burning. You've successfully created a Windows XP SP3 installation CD.
http://www.microsoft.com/downloads/details.aspx?FamilyID=2fcde6ce-b5fb-4488-8c50-fe22559d164e&displaylang=en XP PRO SP3 ISO Download the iso also download the imageburn http://www.imgburn.com/
http://windows-xp-pro-startup-disk.soft32.com/ http://support.microsoft.com/kb/322389 http://windows-xp-pro-startup-disk.soft32.com/free-download?gclid windows xp pro start up disc
Apr 10, 2013 | Acer Computers & Internet
Restore Disks for Sony Vaio Notebook Model PCG-491L
Download the SP3 installation ISO. Save it to your Desktop. Download ImgBurn and save it to your Desktop. Double-click the installation executable for ImgBurn and click "Next." Follow the remaining onscreen prompts and click "Finish" to complete installation of ImgBurn. Insert a blank CD-R/DVD-R into your DVD drive. Open ImgBurn by going to "Start," "Programs" and "ImgBurn." Click "File," then "Browse for a source file." Navigate to your Desktop and select the SP3 ISO file. Click "Open." Click the blue "ISO to CD" button located on the bottom left of ImgBurn. The program will begin creating the Windows XP SP3 installation CD. This process may take anywhere from 10 to 20 minutes to complete depending on the speed at which the CD-R/DVD-R is being burned. Click "OK" once the CD-R/DVD-R has finished burning. You've successfully created a Windows XP SP3 installation CD.
http://www.microsoft.com/downloads/details.aspx?FamilyID=2fcde6ce-b5fb-4488-8c50-fe22559d164e&displaylang=en xp pro sp3 iso http://www.imgburn.com/ Download the iso also download the imageburn or
http://windows-xp-pro-startup-disk.soft32.com/ Bootable disk for XP Professional. The Windows XP start up disk allows computers without a bootable CD-ROM to perform a new installation of the operating system. Hope this helps.
Dec 26, 2012 | Computers & Internet
Windows 7 boot manager missing after buying and loading restore disks from hp
The error befalls when your PC is unable to interact with Windows due to the corrupted Windows installation, or it is trying to boot from a wrongly configured or improperly connected hard drive or flash drive among other external medium...... read more
Aug 31, 2012 | Computers & Internet
I dont have a branded pc its a clone so heres the problem i have upgraded my pc with 3 dvd combo drives but when i try to repair it using the windows xp 2sp2 disk it always shows an error message i cant...
You plug in the drives, you don't have to repair windows just because you added drives.
You can't repair xp it does not have a repair, it only has recovery, and unless you made a recovery disk or have one you can't.
Windows xp is up to SP3.
Did it boot from the disk ? you need to force boot to cd, But try this.
When your BIOS post, first screen, hit the F8 key, and see if you can boot into safe mode.
Then go to start, accessories, system tools, system restore, and restore it.
Any other questions of you have have more details after you try this post back.
Feb 07, 2010 | Acer Veriton 5600GT PC Desktop
Changing Windows Disk XP Home Edition/SP2 to SP3
Try downloading SP3 again and save to desktop, then re-install (replacing 1st. installation). There might have been a glitch in the first download.
Oct 14, 2009 | Computers & Internet
Wont boot up and cant use restore
It sounds like a virus or spyware corrupted both your windows restore points and your partition...Do you have the discs that came with your system? I am afraid you'll have to manually restore.
Apr 13, 2009 | Acer Aspire 5100 Notebook
Can't Boot
restore disks are not worth a w**k......
all you need is xp disk with a cd key...
you can repair (dos prompt) or reinstall or repair(windows app)same as restore.
you can download xp/xppro of net though it does take a while.
if you have ares you could get off me my pc has been uploading xp pro with sp2 integrated all day and most of the night to various people also xp pro with sp3 integrated I also have iso of xp pro sp3 integrated and registered all you have to do is load it then install updates dont even need the key cos that also is integrated.
can give you links if you want but like I say it takes a while to download.
Jan 25, 2009 | Computers & Internet
Can't run 1701 Ad with Windows XP SP3
Use restore point and go back to before SP3. Wait a couple of weeks and download it again. They should have the bugs out by then.
Dec 22, 2008 | Aspyr 1701 A.D. for Windows, Mac
Gateway 7405GX Notebook Logo
130 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
