Question about KitchenAid (KSRD22FKST) Side by Side Refrigerator
Cant get water out of the fridge door
Need help to get water out of the door
  • allamericanp Sep 23, 2008
    i have done all that. Water comes out of filter but not the door
  • abfranksx4 Feb 09, 2009
    Icemaker works fine. I can here the solenoid hum when pushing the trigger, but no water comes out.
  • 750 Answers
Hello allamericananp,
welcome to fixya.com.
Huuum at your service.
You said, the ice maker slowly stopped working, decreasing in the amount of ice it made until finally no ice at all. also, water trickles from water dispenser.
The first thing I would ask is when did you last change your water filter in the fridge?
Or if it's an older fridge with an inline filter behind the fridge!
check the shut off valve for the water line that leads to you ice maker. under the sink or in the basement or where ever the line comes from. I've seen where someone turned the valve a little clockwise unbeknown to the home owner and stopped or slowed the water flow.
The water line should be checked too, for any kinking that may be running behind the fridge or some unseen place!
How old is the fridge??
Let me know,
Thank you Huuum
Posted on Sep 23, 2008
Water puddling under front/door. Still cold but cant find settings info and concerned seal has gone and housing will be damaged. Less than 6 months old
Freezer /fridge water/ice in fridge
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor.
However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick.
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced.
Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer.
Mar 25, 2015 | Refrigerators
Why is my Telmann fridge model HS-319 filling up with water at the bottom, and overflowing?
Freezer /fridge water in fridge
May 25, 2014 | GE Refrigerators
Kelvinator Cyclic 330, Model No: CS334A-R
Tonight, get a battery flash light, turn it on, put it in the fridge and close the fridge door. Then turn off all the lights in the room. If you can see any light escaping around the fridge door, the door seals aren't working properly, and need replacing.
This is the main reason why too much water is being condensed and causing your fridge drip tray to overflow.
May 25, 2014 | Refrigerators
I cant believe i cant find the model # of this fridge but anyway , i installed a new water filter a purr #4396841 and did it according to the instructions , did everything but the red light remains, wonder...
The model # is located inside refridgerator door on the upper right side panel.To reset the light you have to open fridge door and by the light there is a button you have to push in the button 5 times in 10 seconds to reset.Hope this helps if so give us a 4 thumbs up. THANKS
Mar 03, 2011 | Whirlpool GD2SHGX Refrigerator
Have side by side 10 years leaking water on floor in front of refrigerator there is no water connected to refrigerator, cant find an overflow pan under neath...
clogged drain causing the water that cant reach the drain pan underneath to leak on the floor. Unplug fridge and open doors for 24 to melt ice likely clogging up drain. If that doesnt fix, you'll need to call refrigerator repair service
Jul 26, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Msd2756geb water tube coming out door not hooked up?
Check diameter of pipe. Suspect its quarter inch. You will then probably need to purchase e.g. from ebay etc a 1/4'' to 3/4'' adapter which will allow you to connect your fridge pipe to a typical water pipe connector (i.e. similar connecting a washing machine), assuming you already have an available water conenction in the lcoation of the fridge!
Jun 16, 2009 | Maytag MSD2756G Side by Side Refrigerator
Water dispenser won't shut off nor will the ice dispenser motor
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | Electrolux Refrigerators
Water dispenser keeps running
Apr 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Water and Ice in Door Tastes Awful!!!
If your water tastes ok without the fridge then you'll need to replace or clean the piping inside the fridge.
If your water has the same smell and taste without the fridge then you'll need a better grade filter on the water going into the fridge.
If it's in your fridge piping try going to a plumbing supply and ask them for a cleaner to run through the fridge!
jack
Mar 08, 2009 | Amana SXD524VW Side by Side Refrigerator
Water dispenser in fridge door
Email me for the bulletin on water line freezing. Try turning on the dispenser light for 24 hours this should defrost the line.
amasuperbike@comcast.net
Jan 15, 2008 | Refrigerators
KitchenAid (KSRD22FKST) Side by Side Refrigerator Logo
296 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
rugby prop
Lawrence Oravetz
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
