Question about LG Washing Machines
The washing machine drum turns slowly and then stops so is unable to continue the cycle. It has power, the water is pumping normally, but will not turn once water is pumped inside. It is a front loading model from LG. Model number is WD-8013F
  • minchoi1971 Sep 23, 2008
    no error message
    Sergeant:
  • 409 Answers
do you have an error message on the display? it either the pump or the control board.
Posted on Sep 23, 2008
  • Carmen Mikulic Sep 23, 2008
    i wonder if you have something stuck in the pump, as it's not draining. have you check it out yet?
Electrolux EWF 1495 won't spin.
The belt could be stretched or the tension idler could be malfunctioning.
Feb 12, 2015 | Electrolux Washing Machines
Indesit WLA111 stuck on rinse cycle
There is a drain plug and filter under the drum. You access it from the front by taking the panel under the door off. Get ready for lots of water to come out when you take the drain plug off. Clean out the area of the filter and drain plug.
Feb 10, 2014 | Indesit WA 115 Front Load Washer
Our hotpoint ultima wmd960 washing machine timer stops with one minute remaining, but continues the wash cycle on 'a loop', and does not pump the water from the drum. We turn it off and then put it...
Have a look at this and check if your pump is full of things lost from pockets:
How to remove and clean your Hotpoint washing machine pump filter
However, I suspect the problem is really that something is causing the controller to (falsely) register an unbalanced load, and continually running the wash to try and redistribute the items.
Sorry I'm not sure what the fix is for that - could be motor tacho, or could be controller itself.
Jan 30, 2018 | Hotpoint Washing Machines
Washing machine fills with water when not in use.
Either your pressure in the main line bringing water to your machine is insufficient; or your intake water valve is defective; which you can replace easily.
Feb 22, 2009 | Asko Washing Machines
Failed to complete cycle.
Probably blockage in pump or sump hose from drum to pump.
Remove and clean.
Nov 22, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Washing Machines Logo
166 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
