Convergence and HDTV Screen Issues
I have a 2002 Mitsubishi 65" Widescreen Rear Projection HDTV.  Occassionally, the picture will get out of convergence, usually just for a few seconds, but sometimes for a minute or so, and then will go back to a normal picture.  It seems to happen to both SD and HD material.  Also, my screen will do a very annoying flashing of the entire screen sometimes.  It seems like this happens when there is a lot of brightness on the screen, such as a large amount of bright whites.  I notice this most when playing videogames, such as Halo, and it is very irritating.  I have gone back into the menu and reset the convergence, and it does not seem to matter--these things still happen regardless.  Is this a sign that my TV is almost done for, or is there something I can do to fix it?  I have been considering an HD projector, but I certainly don't mind postponing the expense of a projector and screen if this is an easy fix.  On the other hand, I don't want to shove a bunch of money into this TV if it just a matter of time before it dies on me.  What do you think?
    Top Expert:
  • Televison & ... Master
  • 75,462 Answers
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Convergence adjustment procedure to many popular brand TVs are given.
Posted on Mar 05, 2017
  • 65 Answers
SOURCE: Strange Image Flubbering/Convergence Problem, Flutters From Dark Picture To Light Picture.
you "tooled around with the convergence board" well this chassis has several problems if the convergence doesnt hold replace both stks resolder around that area per tosh tech bulletin the bright problem is probably the hyper module all toshs should be checked with toshiba website to see if they were part of the recalls for power supply caps
Posted on Dec 09, 2006
SOURCE: Green "halo" around the bright white images
I have a Samsung HCM5535W rear projection TV that had pretty much the exact same problem-- a green halo around bright white images. I researched it on the net, and determined the most likely problem was with the convergence STK-ICs, or the convergence board. I bought a replacement board with the STK ICs and installed it, but no luck, the problem persisted. I decided to mess with the manual focus adjustment on the green crt (i was seeing a green halo), and that fixed it. As it turns out, no replacement parts were necessary to fix the problem in the first place. Hope this helps somebody out there.
Posted on Feb 07, 2008
  • 159 Answers
SOURCE: Mitsubishi WT-42413 Blue Green and Red Line
there is a section in the tv working just to keep the screen fitting top to down (vertical section) some capacitors are dry now in that area. this one has not to be a expensive job in the workshop. Try estimates
Posted on Apr 14, 2009
SOURCE: Arched blue lines across screen of Sony 63" Rear Projection TV
Had this problem bout 2,3 years ago...it was fixed in about 5 minutes with the help of this article
Tonight I have to do this fix again..the blue lines came back about a week.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
I strongly urge you to save the web page locally on your hard drive or print it out and place with the tv manual....
Good Luck..
Posted on Jun 19, 2009
rcalorisian
  • 313 Answers
SOURCE: my Hitachi LCD rear projection TV has blue color in left corner
It is most likely the tube going out. Find some one to replace the tube if the TV is fairly new other wise it is going to be a trend. One tube now and another.. and so on. Ride it out as long as you can then go for an upgrade
Posted on Sep 08, 2009
Mitsubishi tv ws 65315 red screen
if the reds and blues look 3d etc it is a convergence problem. see attached photos of a typical convergence problem.
Apr 28, 2012 | Mitsubishi WS-65315 65" Rear Projection...
Picture Bowed towards the center
It is a convergence problem, probably one of the convergence ICs has blown and must be replaced. Call the number in the last pages of your user manual to get repair service in your area.
Jul 25, 2008 | Mitsubishi WS-65413 65" Rear Projection...
Mitsubishi WS-65869 65" blue color problem
Yes, you need to replace the convergence output amplifier IC's. They can be ordered on line. After removing the back you must remove the circuit board which houses the amps. Then desolder them and install the replacemnts. If you are extremely lucky there won't be any re-alignment issues with the new amps. Then you should be good to go.
May 03, 2009 | Mitsubishi WS-65869 65" Rear Projection...
Double image looks like a convergence issue
This is a Convergence issue, bad solder connections on the convergence IC's.
Nov 20, 2008 | Mitsubishi WS-55313 55" Rear Projection...
Big screen showing double and red ghost color
Go into your service menu and try to adjust the convergence, if it does not adjust, the IC's ( chips) are bad in that circuit. Call a local factory authorized dealer to service your tv. The cost should run around $450.00. Good luck.
Mar 29, 2008 | Mitsubishi WS-65513 65" Rear Projection...
My Mitsubishi WS-65313 65 inch, Convergence Problem???
This is a common problem on projection tvs. There are two convergence chips that need to be changed. STK394-250 or original Mitsubishi # 267P173010 (recommended)
Mar 05, 2008 | Mitsubishi WS-65313 65" Rear Projection...
Describe your Mitsubishi WS-65313 65 in.... Problem:
look for the CONVERGENCE settings either behind a small panel on the front or through the menu with the remote control
Jan 13, 2008 | Mitsubishi WS-65313 65" Rear Projection...
Picture slightly too big
To reset the convergence EEPROM, press "menu 0359 to enter the convergence menu, then press "8970" to reset.
Sep 08, 2007 | Mitsubishi WS-65613 65" Rear Projection...
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
