Question about EliteGroup ECS GeForce6100SM-M (1.0) Socket AM2/ MCP61S/ SATA2/ A&V&L/ MATX Motherboard
What the maximum processor can this motherboard support?
I just want to know.. please help me..
    President:
  • 2,351 Answers
Hi akonuneng, just click on this ECS link for supported CPU's for the GeForce6100SM-M:
http://www.ecs.com.tw/ECSWebSite/Support/CPU_Support_Model.aspx?detailid=685&MenuID=69&LanID=9
There you go.
Enjoy!
Mike
Posted on Sep 25, 2008
What is the maximum ram supported by a Intel pentium dual core E5200 2.5ghz processor ? I have a mobo with 8 Gb ram support max...
It depends on your operating system. If you have a 64bit OS then you'll use the 8GB. If you're using a 32bit OS you'll use about 3.65GB.
Jul 13, 2012 | Computers & Internet
HOW TO I KNOW THE BUS SPEED
You know 'Upgradation' is not a word, right? lol!
How about Upgrade ability?
The Intel D101GGC motherboard has a Front Side Bus MAXIMUM frequency rate of 800MegaHertz. (FSB max rate is 800MHz)
Therefore, it depends on the PROCESSOR that is being used, as to what frequency rate of Ram Memory that can be used.
[ Excuse me. Frequency Rate = 'Speed'. The layman's term ]
Ram Memory typically operates at HALF of the frequency rate, of the FRONT SIDE BUS for the Processor.
Have a Processor that has a maximum FSB frequency rate of 800MHz?
You can use Ram Memory that operates at a frequency rate of 400MHz, or 333MHz. (Do recommend using PC3200, however)
Have a Processor that has a Maximum frequency rate of 533MHz?
You can use DDR Sdram at 333MHz. (PC2700)
The Intel D101GGC uses DDR Sdram ram memory.
DDR Sdram at 333MegaHertz = PC2700
DDR Sdram at 400MHz = PC3200
There are TWO ram memory expansion slots.
The MAXIMUM for EACH ram memory slot is 1GigaByte. (1GB)
The Maximum TOTAL Amount for the motherboard is 2GB.
ALWAYS make SURE you have a ram memory module ('Stick'), in Slot 1 (DIMM 1)
A Processor reads Slot 1 first. If there is no ram memory in Slot 1, the computer will not work.
How to know what the FSB is of the processor, you have currently installed?
I suggest using the free CPU-Z,
http://www.cpuid.com/softwares/cpu-z.html
The above link shows the default screen for CPU-Z. The screen that automatically comes up when you open CPU-Z.
There are tabs across the top that you click on, to get other information. (Caches, Mainboard, Memory, SPD, Graphics, About)
More on this in a moment.
Let's look at the Processor example shown.
1) Name: Intel Core i7 860
It is an Intel Core i7 processor, and the model number is 860,
http://en.wikipedia.org/wiki/List_of_Intel_Core_i7_microprocessors#.22Lynnfield.22_.2845_nm.29
2) Code Name: Lynnfield
Based on the Lynnfield technology, and the 45nm architecture.
(nm stands for NanoMeter. One billionth of a Meter)
3) Package: Socket 1156 LGA
Uses an LGA1156 processor socket,
http://en.wikipedia.org/wiki/LGA_1156
4) Technology: 45nm (Already stated by looking at the Wikipedia link)
5) Core Voltage: 1.216 V
Looking at the Wikipedia link, you can see this processor's voltage range is 0.65 to 1.4 Volts.
Or stated as 0.650 to 1.400 Volts. It is -> DC Voltage.
The 1.216 Voltage stated, is what that Processor is using now.
It is real time information.
6) Specification: Intel (Registered trademark) Core (TradeMark) i7 CPU.
CPU stands for Central Processing Unit. Another term used is Microprocessor, or simply -> Processor, for short.
8) 860 = Intel Model Number
@2.80GHz stands for 2.80GigaHertz. The MAXIMUM frequency rate that the processor is designed to operate at.
9) Family, Model, Stepping, Ext.Family, Ext.Model, and Revision, are Intel technology factors, for this processor.
What Family of Processors it was developed from, what Model design, what stepping it uses, what Revision of design, and etc.
10) Instruction: The Instruction Sets, or instruction set architecture, it uses.
The basic MMX, and SSE, and variations of the SSE instruction sets, and further development of Instruction Sets through the years.
http://en.wikipedia.org/wiki/Instruction_set
http://en.wikipedia.org/wiki/List_of_instruction_sets
11) Forget about the Cache column. What you are concerned with is under the Clocks (Core#0) subheading.
I just stated the above, so you might have a better understanding, of what you are looking at.
(Also it may spark something inside you, to join a Research and Development team, and design future computer technology. Who knows, right? )
12) Core Speed:
Again with the 'Speed'. It is Frequency Rate.
This is the maximum 'speed' that the Processor will operate at.
(Maximum frequency rate)
When you have CPU-Z going, you can watch this frequency rate, change. It is showing Real Time information. AS IT HAPPENS.
13) Multiplier: The multiplier times the internal clock 'speed', of the Processor.
Forget about the information shown. It is for an Intel Core i7 processor, and this processor operates on a much different technology, than the Intel processor in your computer.
What you are concerned with is shown in the box, to the right of -
Bus Speed.
A) If you have a Processor with a 533MHz FSB, the number shown will be 133.2
Why?
Because Intel processors are 'Quad Pumped'
133.2 times 4 = 532.8
This is rounded up to 533, or 533MHz.
If you have an Intel processor with a Front Side Bus of 800MHz, the number in the box will be 200.6
200MHz (Rounded down)
Processor with an 800MHz FSB? Use PC3200.
(DDR Sdram at 400MHz)
Processor with a 533MHz FSB? Use PC2700.
(DDR Sdram at 333MHz)
For additional questions please post in a Comment.
Regards,
joecoolvette
[ Need to know how to download, install, and use CPU-Z? Post in a Comment.
You can also just post what you see on CPU-Z, and I will tell you what you are looking at.
Clicking on the Caches tab, gives you information on the Processor cache.
Clicking on the Mainboard tab tells you about your Motherboard.
Clicking on the Memory tab, gives you basic information on your Ram Memory.
Clicking on the SPD tab, gives you detailed information about your Ram Memory, AND each ram memory module.
Clicking on the Graphics tab, gives you information on your graphics chipset. Integrated on the motherboard, or on a graphics card.
Clicking on the About tab, gives you information about CPU-Z.
Jun 25, 2012 | Intel D101GGC Motherboard
I want to be know what is compatible with AOpen s651m motherboard. i'm kind of an ammature, so please help.
AOpen S651M motherboard:
1) Processor Support:
Uses Intel processors that fit in a Socket 478 processor socket,
http://en.wikipedia.org/wiki/Socket_478
The Processor has the contact pins (478 of them), and the processor socket has the socket holes. (478)
The Maximum FSB supported for the processor is 533MHz.
(Front Side Bus, 533MegaHertz)
Processors supported;
http://en.wikipedia.org/wiki/List_of_pentium_4_processors#Northwood_.28130.C2.A0nm.29
Start with the Northwood Core models shown in the link above.
The ones that have a Front Side Bus of 533MT/s, and fit in a Socket 478.
The few shown in the next chart, Prescott (90nm), may not work. The voltage requirement.
2) Ram Memory Support:
DDR Sdram that operates at 333MegaHertz, or commonly known as PC2700.
TOTAL Maximum Amount is 2GB.
There are two ram memory slots. The Maximum Amount for EACH ram memory slot is 1GB.
If you only have one ram memory module ('Stick') place it in Slot 1. (DIMM 1)
This is the ram memory slot that is closest to the Processor.
[ The Processor 'sees' ram memory Slot 1 first ]
Graphics Card Support:
The graphics expansion slot on the motherboard is an AGP slot. (Advanced Graphics Port)
It uses the AGP 4X technology.
Above the 3 white PCI slots is the brown AGP slot.
Use AGP 4X/8X graphics cards.
(These types of AGP graphics cards can be used in an AGP 4X slot, or an AGP 8X slot)
Example of a AGP 4X/8X graphics card,
http://www.newegg.com/Product/Product.aspx?Item=N82E16814139053
Another one,
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161318
,and yet another one,
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161337
For additional questions, or to have me clarify anything I have stated above, please post in a Comment.
Regards,
joecoolvette
Sep 24, 2011 | AOpen S651M (918EM10S50) Motherboard
I have a 512 DDR2 (533 FSB) RAM in one of my slot in Intel D102GGC2 Mother board,can i put a 2 GB DDR2 ram in another slot.If yes then What FSB will match and what is the maximum capacity of ram per slot?
This motherboard will support maximum 2 GB of total system memory. so configuration is should be 1GB + 1GB or one 2GB in one slot. If you attempt to install 2GB + 512MB, this is unsupported. but you can try if might the system can read it or not. there is no serious problem for installing memory exceed than maximum system memory...
Memory supported is DDR2 533 Mhz and DDR2 400 MHz...(sometimes on the market DDR2 533 will described as module name PC2-4200 and DDR2 400 as PC2 3200)
Aug 10, 2011 | Intel D102GGC2 Motherboard
I have this motherboard PACKARD BELL BV GA-T671MG. how much ram memory can it have? can i use ddr3? my pcie port supports a 2.2 graphic card?
System
System : PACKARD BELL BV ISTART F2310 AIO
Mainboard : PACKARD BELL BV GA-T671MG
Bus(es) : ISA AGP PCI PCIe USB
Multi-Processor (MP) Support : 1 Processor(s)
Multi-Processor Advanced PIC (APIC) : No
System BIOS : Phoenix Technologies, 255.255
Total Memory : 767MB
Intel Pentium D 3.00GHz
Packard Bell BV (GA-T671MG)
SiS chipset (Si671V11)
DDR2
1024mb ram
PACKARD BELL BV
Model GA-T671MG
Chipset Vendor Silicon Integrated Systems (SiS)
CPU Intel Pentium D
Cpu Socket LGA775 [Socket 775]
Processor Upgrade ZIF Socket
Max CPU Speed 3000 MHz
System Slots 2 PCI, 1 AGP
Memory Summary
Location System board or motherboard
Maximum Capacity 1024 MBytes
Memory Slots 2
Error Correction None
Use System memory
Maximum Memory Module Size 4096 MBytes
Manufacturer PACKARD BELL BV
Model GA-T671MG
CPU Intel Pentium D
Memory Summary
Memory Slots 2
Use System memory
it seems this might vary i have listed 4
hope this helps
May 17, 2011 | Computers & Internet
What is the max ram expansion for this motherboard?
The maximum RAM supported by this motherboard is 4GB if you are running a 32bit operating system on this processor and a maximum of 16GB if you are running a 64bit operating system.
Thank you for using FixYa! Have a great day and please remember to rate this solution.
Best regards,
Dustin Ellse
Jan 26, 2011 | ASUS M4A88TM Motherboard and AMD...
Maximum amount of RAM
Go to www.crucial.com and use memory selector.
Otherwise, give them a phone call.
If this helps please vote for my solution.
Feb 16, 2010 | Computers & Internet
I want to know what latest CPU and Video Card that can be installed on ECS motherboard P4VMM2 (V7.3).
Maximum processor you can install: Pentium 4A (Northwood) 2.8GHz with HT Maximum video card: ATi Radeon x1950XT AGP
.. and below. Any other video card and processor than that would never fit.
Nov 06, 2009 | EliteGroup P4VMM2 V7.3 (P4VMM273)...
Maximum processor core speed on ibm i845g motherboard?
The maximum core speed processor for IBM i845g is 1.8ghz which you already have.
Nov 01, 2009 | Computers & Internet
RAM SUPPORT
it depend on motherboard model not the chipset
Sep 02, 2008 | Intel Motherboard
EliteGroup ECS GeForce6100SM-M (1.0) Socket AM2/ MCP61S/ SATA2/ A&V&L/ MATX Motherboard Logo
124 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
