No monitor model told
no PC model told
no OS told
also PCs with wrong drivers, the sleep mode fails.
so turn off sleep fully in the control panel + power settings
go to performance mode.;the blow flashing light means I AM sleeping but THERE ARE ONLY 3 WAYS TO END SLEEP ON A DESKTOP(NO NOT FIDDLING A MONITOR)
wiggle the mouse or click it but of USB ports are allowed sleep that fails. hard. so never allow usb to sleep.
then way 2, hammer the space bar ,keyhboard or the ESC key
see PC exit sleep, if USB is allowed to sleep (ports)it too fails
and last the power button pushed in for 10second and released
forces a sick PC, (bad drivers that kill sleep features) this act resets the PC and reboots.
why not just turn off all sleep modes. and just allow the monitor to sleep and or power it off. not used.
also page in your manual states (see resume)
and never allow Hibernate at all it is super buggy or any deeper state.
"Press this button to turn the power on
or off. You can also configure the power
button to operate in Standby/Resume
mode or Hibernate mode. The power
indicator lights when the computer is
turned on."
why not test the PC with newer monitor 2011 newer LED back lighted monitor to be sure your older monitor is not bad as seen here in this flash light test.
rCAP
learn to
disable all forms of sleep modes, ALL no exceptions.
then see if this works if it does you just learned your drivers are bad.
or test the PC with a newer monitor 2012 is LED for sure)
learn that bad drivers most times make sleep fail
no oS told at all, not even a tiny clue is this XP the versus magnet from H3LL>? or worse upgraded to vista and drivers are all no good for vista. never up grade any os lacking oem support for all drivers.
newer. vast PCs have no upgrade path at and guess what
emachine is infamous for that fact. they stink this way but sure wins the dirt chip cost war, sure.
the fast resume is on the power button to set right]
the fast press is resume from sleep, the but is programable.
if drivers are wrong all this fails hard,
