Question about Cameras
I have a digital Sony Mavica FD-95, when I insert a floppy disk into the drive, it reads as "disk protected" when the disk is not protected. Also, when I insert the adapter for the memory stick [64 meg] it reads "disk error" [flashing: C:13:01]. [Disk Protect] In both instances, I double confirmed that the media was NOT write/copy protected & I have replaced the batteries in the MSAC-FD2M memory stick/floppy adapter. Can this be fixed? Skip camera12@comcast.net
  • Anonymous Dec 07, 2008
    I have a Mavica FD85 with the same issue. I check inserted Disks and they are not protected, but get a Disk Protect on disks. Camera works fine otherwise any help???
  • Cameras Master
  • 5,412 Answers
The issue is probably that the storage media you are attempting to use exceeds the equipment's capacity. This is very old technology, and is surely due for replacement.
Posted on May 25, 2017
SOURCE: Disk Protect
Try to use a can of air and blow out the inside where the disk goes. The sensor may be dirty.
Posted on Apr 15, 2007
jackboy
  • 2985 Answers
SOURCE: Mavica Fd88 & Memory Stick?
Very old model uses floppies see http://www.mouthshut.com/product-reviews/Sony_MVC-FD_88_Mavica-925013602.html
Posted on Aug 31, 2007
SOURCE: Sony Mavica FD-71 Trouble code C13-01
  1. When you insert the disc push the center edge of the disc toward the lens with a fingernail
  2. After a number of inserts you don't need to do it any more
PBL
Posted on Jun 22, 2008
SOURCE: mavica fd 83 with batterytroubles
Hi,please ask Fixya for the site of WELCOMEJEE,I have similer problems with my 83,mine shows full charge at times ,and low battery and shuts down at other times.
He says that it could be a Battery Fault,even if it shows Full Charge as batteries can be Faulty,please ask Fixya about WELCOMEJEE,regards,Walt.(rtd.)
Posted on Apr 23, 2009
shajanrs
  • 890 Answers
SOURCE: I'm looking for a Sony MSAC-FD2M Floppy Disk Adaptor and memory stick.
Please click here to view the link from Amazon to buy both Memory Stick and the Floppy Disc Adaptor.
Please let me know if you require any additional help.
Thanks for using Fixya..
Posted on Jan 24, 2012
Testimonial: "Thank you very much for your swift reply and your useful information. Carl"
I can not locate where the memory stick is located on my Digital Mavica MVC-FD85. pleaase let me know
I'm sorry to inform you that the MVCFD85 Camera does not have a Memory Stick slot. The medium using in the Mavica FD camera is floppy disc.
The MSAC-FD2M floppy disk adapter can be used in some FD Mavica digital cameras.
With the help of the above mentioned Floppy disc adapter, you can insert a memory stick inside the adapter and insert it in to the floppy disk drive on the camera.
Jan 28, 2011 | Sony Mavica MVC-FD85 Digital Camera
When a floppy disc is inserted it flashes disk
The floppy driver has an internal switch that detects when the floppy disk is protected or not.
It is likely such switch is damaged.
It is necessary to open the camera and the floppy drive to fix it.
If you have experience and skills in fixing electronic devices, or want to try it, then you can try its repair.
The alternative is to pay to have repaired, but is more likely that the quote you will receive is to replace the whole floppy drive, which costs around $40.00 plus the repair labor.
Regards,
Jul 08, 2009 | Sony Mavica MVC-FD100 Digital Camera
Sony mavica fd-88 says " NO FILE " when i put in the floppy
When inserting floppy the door won't close & I get disc error
Mar 06, 2009 | Sony Mavica MVC-FD88 Digital Camera
Sony Mavica FD75 shows NO DISK when disk has been inserted
Regards,
Jan 21, 2009 | Sony Mavica MVC-FD75 Digital Camera
How to shut off disk protect
The write protection is on the floppy diskette itself. Make sure the little sliding latch is covering the hole on the right side of the diskette. If you see through two holes on the diskette it is on write protect.
Jun 23, 2008 | Sony Mavica MVC-FD75 Digital Camera
Storage/memory used SD or usb flash disk
Try setting your picture size to a smaller size. If your pictures are used mostly for being viewed on a computer, or for smaller print sizes like 3x5 or 4x6, you should not lose any quality. The smaller file size does not take as long to write to the disk.
Feb 28, 2008 | Sony Mavica MVC-FD95 Digital Camera
Sony mavica mvc-fd91 digital camera
The first thing to check is the floppy disk itself is not protected, what this means is on the left/right corner of the floppy disk is a little tab that can be moved up or down. Check to make sure the disk is not locked (usually symbolized by a lock symbol on the disk). If that does not work, you might have a bad floppy drive
Nov 29, 2007 | Sony Mavica MVC-FD91 Digital Camera
Disk Protect
just unprotect the floppy disks...
Feb 03, 2007 | Sony Mavica MVC-FD87 Digital Camera
FD-81 ... Can it use the memory Stick Adapter
I have a Mavica FD81, and I do not believe you can use the memory stick adapter with it. This camera came out long before the adapter was available. The manual only mentions floppy disks.
Sep 13, 2005 | Sony Mavica MVC-FD81 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
