Question about GE (PSS26MSRSS) Side by Side Refrigerator
Running long time
Left for 2 days - I think the fridge door wasn't all the way shut - freezer seems fine everything frozen came home yesterday and found this put thermeter in to check temp woke up this morning and was 32.5 turn down control up fridge kicked off -- open doors for a minute to get to kick on it did ran for about 20 mins and kicked off on its own and when I got home from work this afternoon around 3:30 was running and is still running now 6:55 temp around 38 Is this normal???
  • 943 Answers
Hi thanks for the question. yes if that's the temp that you say 36 to 38 degrees is normal operating temp thanks the appliance doc
Posted on Sep 24, 2008
My ge profile arctica is about 9 years old. It is freezing food in the refrigerator, temp control is set at a 4 and the thermometer inside reads anywhere from 28 -40 in various areas of the fridge. Milk...
first run the diagnostics on the unit from the tech sheet inside the unit,then if thermistors are bad replace these there are 2 one on the left and one on the right wall in both fridge and freezer,if good per diagnostics then replace the electronic damper door located between the fridge and freezer compartments in the upper left hand corner of the fridge behind the plastic grille as these doors break and jamb open or shut and the temps can no longer be regulated during the diagnostics tests you can hear this door operate if its operating correctly,lastly,if these fail to solve your problem,replace the main control board in the back behind a panel
Aug 22, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Left the freezer door open all night and morning noticed it in the afternoon. Thawed it and now the freezer works fine but the fridge doesn't cool
these fridge freezers have a damper flap which means your fridge will not cool until everything in the freezer is frozen hard again this may take up to two days depending how much you have in your freezer
Regards
Ian
Apr 19, 2011 | Hotpoint Refrigerators
Hi i have a magic chef model # mcbr 1010b it was working great unti i left the door ajar overnight and now it gets very cold in freezer @ 0 degreeze and refrig part stays around 50 and seems like it will...
Since you left door open I think the evaporator is frozen up .Just shut it off for a while and let everything defrost then turn it back on and you should be fine
Jan 05, 2018 | Magic Chef CTB1722 Top Freezer...
The refrigerator has stopped running.
A fridge is divided by many parts. if the main motor dies then the whole fridge will not function. In your case the freezer is still working but the rest isnt. Still, i think you should have it checked out by a repairman to determine any inside problem and to avoid any future trouble.
May 20, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
The fridge of my American style fridge/freezer is
You can use a hairdryer on the frozen parts.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
My fridge in my fridge freezer keeps freezing everything in it.
If the fridge side is frozen you have a door seal issue.
If the freezer side is frozen you have a defrost component issue.
Your post was not clear as to which side is frozen.
Jun 16, 2009 | Hoover HFA270K Bottom Freezer Refrigerator
We left the freezer door open all night by accident two days ago
I turned the fridge side off on mine, and left it overnight (last night!). This morning there is frozen stuff in the freezer. I think the compressor motor just needed ALOT of time to cool down b4 it would work properly again
Jan 11, 2009 | Whirlpool GC5SHEXNS Side by Side...
No water flow
turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
Dec 06, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Servis fridge freezer
Hi ,
ngafm at your service,
If its cold and frozen it may be that the door switch that activates this light in the case that the door is ajar, is faulty.
Or it may be that the temperature is dropping to slowly for you to see it by eye!
The whole purpose of the, "door ajar" light is to protect you food from spoilage and to warn you before it gets to warm!
Door ajar or not!!!
My advice is to fix the problem now no matter if it is only the switch causing a false alarm.
Or the worst case scenario !
You need hands on service!
Bless You ,
ngafm,
please give me a good rating before you sign off.
Thank you.
Sep 07, 2008 | Freezers
Maytag side by side slowly getting warmer
I have actually been having the same problem. We have a Maytag MTB2156GEQ and it hasn't been cooling well at all lately. Temp in the fridge is about 52 degrees even on the highest setting. The freezer seems to be fine. I pulled off the back panel and vacuumed out the condensor coil and everything else under there. I then pulled out the control panel on the ceiling of the fridge. The channel between the freezer and fridge was almost completely blocked with ice. I cleaned it out by taking out the back panel of the freezer and pouring hot water down through the hole until it was clear.
that seem fix the issue.
Aug 10, 2008 | Maytag MSD2656G Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
134 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
