Question about RCA 25403RE3 Corded Phone
Need ac adapter info. for the rca 2540 - RCA 25403RE3 Corded Phone
Display says "base unit no power" Is this fixable?
this is not a battery issue the actual unit that plugs into the phone socket and has a radio transmitter has no power. Look at the AC adapter plugged into the power point of the radio base device. Most likely someone has unplugged it or the AC adapter has gone faulty.
It is fixable check the AC adapter is plugged in and the power point is switched on. you should be able to buy another AC - DC adapter if it has gone faulty.
Dec 31, 2014 | Lands Phones
I get a message Ac OFF
Hi, Your assumption is correct. The phone is not sensing any external AC power. If you are sure that the AC cord/adapter is plug in to the mains, then it is either: 1. the walloutlet or where the ACplug/adapters is connected does not have any power; or 2. The adapter itself is defective. Hope this b e of some help/idea. Pls post back how things turned up or should you need further information. Good luck and kind regards.
Sep 26, 2007 | GE RCA 4-Line Speakerphone
My wireless does not work where can I find someone to work on it.
Wireless phones usually don't give problems unless the base and or the handset has fallen several times. First you need to determine if the base is receiving power from the AC adapter. Is the power light on? Is the display lit? If not. then most likely the thin cord that runs from the AC adapter to the jack is broken. You can test it simply by holding the cord just about an inch from the jack and bend the cord slowly at 90 degrees in one direction, then in the opposite direction. Repeat at the AC adapter side. You may need to hold the adapter against the socket to prevent it from working loose. If the light on the base flickers momentarily then the you need a new AC adapter. You can also check very carefully along the length of the cord to see if there is physical damage. A store like Radio Shack should be able to assist you with getting a new adapter, but you need to carry the base with you. If there is no response from the base then you can try a computer repair store. Most times, technicians who do repairs on computers know of technicians who do repairs on other electronic devices or appliances in your area. I do hope you get through.
Sep 05, 2014 | Lands Phones
AC Phone Adapter Model # 5-2777
I found several on e-bay. It took some digging. I just bought one for a little less than $24. Try this link.
http://www.ebay.com/sch/Home-Telephones-/3286/i.html?_from=R40&_nkw=RCA+power+adapter
Feb 02, 2012 | RCA 25423RE1 Phone
I've lost the ac adapter for the AT&T EP5962 telephone. Do you know where I can buy one? I'm having a difficult time finding it online. Thanks
Radio shack is an excellent place to check. If you go into the store, take the phone with you! The sales person (provided they have any knowledge about their job...lol) will need info found on the spec label. If you try doing it yourself online....it would be my recommendation to go instore first. Good luck!
Jul 06, 2011 | AT&T EP5962 Phone
Says No Link...Reconnect base AC Adapter
Disconnect the AC adapter from the unit, wait for 5 seconds, then reconnect. The plug may have become loose over time or not be fully inserted. If that does not work, try re- registering the handset.
Mar 06, 2011 | Panasonic KXTG4011 Cordless Phone
Where can I purchase an ac adapter for Model #25403/04 RCA 4-line speaker phone?
You can check ebay.com to purchase the AC adapter of your unit.
Take care.
Oct 05, 2010 | RCA 25403RE3 Corded Phone
AC phone adapters needed
If you are a US resident, you can probably take them to Radio Shack. They can probably find one compatible with your phones. You'll pay too much there but save some time since there are dozens of different connectors and polarity is important to avoid damage to the phones.
Trying to buy this kind of accessory from the company whose name is on the device is hopeless since none of them seem to support the products they sell probably because they don't make them either.
Jan 14, 2009 | AT&T E5908 Phone
RCA Phone model 252025 - displays Answer... on line 1
The Thomson folks said to reset the phone. Here's how: unplug power, then the phone line, then remove the batteries. Wait 10-15 minutes. Replace the batteries, then the phone line and finally, the power.
Note: We have 2 phones with these two lines and had to reset both of them to clear the "busy" on Line 1.
Sep 05, 2008 | RCA 25205RE1 Phone
RCA 25202RE3-B
I need a power cord for the RCA Executive series 4-line Model #25413 Re 3-A 6 volt AC ??
Jul 15, 2008 | RCA 25404RE3 Corded Phone
RCA 25403RE3 Corded Phone Logo
81 people viewed this question
Top RCA Lands Phones Experts
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
