Question about Jensen A400HLX Car Audio Amplifier
Jensen 400W A400HLX Power Problem
I have a Jensen 400W amp that I have been running for a couple years with o probem. I disconnected it for a while and ran another amp for a while until that one quit. When I hooked the Jensen back up, it worked for a couple months and the did the same thing tha the pioneer i had before it.
What it does is when i turn the amp on it turns on and then shuts off with the power protect light on. If I leave it on for a little bit, it will pop back on and then off instantly again with the power protect light on. Both the Jensen and the Pioneer amp that I have are doing the same thing.
Originally I thought it was a problem with the amps, but now I am wondering if there is something wrong with the car tht is messing the amps up. Any suggestions or help would be great.
Thank you for your time,
Jim
  • Jim Olmstead
    Jim Olmstead Sep 25, 2008
    If it is the transisters, I should be able to test them to findout wich one(s) is/are causeing the problem right? Or not? If I can figure out the bad one(s), I could possable try to make a replacement and see if it will work again. What do you think?
    Thanks again for the time and help,
    Jim
  • Jim Olmstead
    Jim Olmstead Sep 26, 2008
    Thank you again for all the help that you have given me so far. I found the information that you gave me very informative and I will be kiiping it on hand while i continue my journey towards making this amp work again someday. In the mean time, if you don't mind me asking a few more question, I would greatly apreciate it.
    I have attached this picture of the amp tore apart. I am not exactly sure what parts i should be specifically looking at, but this is what i can see so far. If these are what i am looking for, I will do what is needed to test them and then I will have to find out where I can order the replacement parts.
    Thank you again for your help and time,
    Jim
Yes, you should be able to find the defective transistors. It may be as simple as replacing the defective output transistors but there could be additional damage.
Read through the following page if you want to try to find the defective components. Let me know if you have any other questions.
Amp repair primer
Posted on Sep 25, 2008
  • 631 Answers
If the amps are going into protect mode, it's likely that the output transistors have failed in both amps. This can be due to many things. Generally it's caused by running the amps at too low of an ohm load. If you drive the amps hard on a daily basis, that can also cause the amps to fail prematurely.
Posted on Sep 24, 2008
  • Perry Babin Sep 26, 2008
    The 6488s and the 64981s are the output transistors. The Z46s are the power supply FETs. The 1620s are the rectifiers.
Why does my Jensen TV keep looping?
try leaving off for about 15 minutes then turn back on may have a button battery for mrmory if so will need to remove for a couple minutes hand
Jun 28, 2014 | Jensen Televison & Video
I have 2 pioneer 6x9 400w, pioneer GM 6500f 760w amp and a kenwood KFC W1012 sub, how d i get the best sound from these?
pioneer gm 6500 is a 4 ch amp rated at 60w-4 way to small of an amp to run your sub. UNDER-POWERING your sub is more likely to damage spkr than over-powering. my advice,get mono-block to run sub
Jan 04, 2013 | Pioneer 6X9 5WAY 400W SPKR Car Speaker
I have a 400w rms @ 4ohm sub. What amp do i need? If i want to connect it via 2 channel, bridgeable amp, what wattage does each channel need to be? Do i need a second amp for 2 6x9s?
almost any amplifier amp would push a 400 watt sub. try to stick with a name brand, and steer away from no name brands like boss, jensen, etc.you will only need a 2 channel amp to run your sub.you will need a second amp to run your 6x9'sor you could get a 5 channel amp, and run all your speakers, and the 5th channel for your sub
Oct 25, 2012 | Car Audio & Video
Jensen ka4400 400w amp
Hello Brian,
I have done a search for the Jensen KA-4400 Amplifier manual, without any luck. Sorry.
However the following might be useful for you to continue the search:
(1) Jensen Customer Support: 800-732-6866
(2) Go to: http://caraudio.manualsonline.com/manuals/mfg/jensen/jensen_car_amplifier_product_list.html
(Be careful to copy ALL of the URL address).
Then click on "Ask the membership for help locating your Jensen Car Amplifier manual"at the bottom of the screen.
Then fill in the form.
Good luck.
Dec 13, 2011 | AMP Car Audio & Video
What kind of fuse
take your amp to Kragen Auto Parts or Pep Boys and show the guy. They have every kind of fuse.
class d
400W is most likely the peak power rating not the RMS
(root mean square)value,so ohms law would not apply,
IxV=P or I squared over R=P. Peak power is sometimes
over twice the constant power i.e. RMS power rating.
To answer your question,a 20 amp fuse should do fine,
if it blows your amp has a problem
May 09, 2011 | Jensen Car Audio & Video
Amp was working, then it goes out
it could have a short inside of the amp. my old amp did that and i moved my grounding wire and it shot sparks all throughout my trunk..... try to return it. or exchange it. tell them its defected
Aug 01, 2009 | Jensen LXA300 Car Audio Amplifier
Amp doesn't come on
Hello rheabarb,
You did not say whether or not you checked the wiring going to your subs. Many times, a shorted or grounded speaker wire will cause an amp to fail. And if the amp powers up OK with the subs disconnected, I'd suspect one or more of the wires.
Hope this helps.
May 19, 2009 | Clarion APX1300 Subwoofer Mono Amp - 300W...
How to adjust the controls and gain on my kenwood 9104d 1800w amp
Hook the speakers in series to decrease your chances of blowing the amp and/or speakers themselves. And at high volumes make sure that the bass control is set for flat response.
Jun 25, 2017 | Car Audio & Video
Jensen XA4100
try using power directly from main to the remote terminal to see if headunit has a problem or the amp.please disconnect remote from head first.
Aug 18, 2007 | Jensen XA4100 Car Audio Amplifier
Jensen A400HLX Car Audio Amplifier Logo
808 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
