Question about Sony STR-GX900ES Receiver
Need help now
I turn on my reciver and the word protecter comes up and i cant do anything no sound no nothing can u help
  • cindyed Dec 01, 2008
    The word "Protector" comes on and no sound is heard. It worked fine prior to yesterday without anything done to alter the wires or settings. Please help!
    Sergeant:
  • 243 Answers
Check all your wires and connections make sure that none have crossed or are short circuiting. What you are seeing is the circuit overload protection and generally is from 2 causes. 1 being what i stated that your wires are crossed or touching on one set of speakers creating a short. 2 is the power supply in either its not grounded or that its blown and overload protection is overriding. Check all the connections and let me know so i can further assist you.
Posted on Sep 22, 2008
Hey i have recently bought a yamaha reciver rx-767 and i wierd up my speakers and after about 5 min at a normal volyme the reciver gets verry hot and turns itself off is there a saftey switch you can turn...
remove the speaker wires all together,, and turn the unit on at a high range of volume,, and wait 10 minutes, if it shuts down then, you have a circuit problem that will need to be checked by a shop, if it stays on, turn the unit off, and add one speaker at a time, following the same procedure, that will let you know which output transistor is bad,, when the unit gets feedback , its going to shut down,
Aug 05, 2011 | Audio Players & Recorders
Reciver is going to protection mode and sound turns off
is some speakers is defective, or not present (connected), check all cables
Jun 06, 2010 | Harman Kardon AVR 340 Receiver
No audio sound, Reciver going to protection mode
If you bought the extended warranty, you need to go where you purchased it and they can look it up on their computer system. If it's out of warranty, the repair cost is debatable. Between 125-175 average. 50% of the cost.
Jun 03, 2010 | Harman Kardon AVR 340 Receiver
My reciver says: protect
If protect is coming up on the display, it means the system is detecting a short somewhere on one of the speakers and so is turning the amp off to avoid damage.
Check all the connections at the back of the amp to ensure they are not shorting, and at the back of each speaker, if nothing is found there, check each wire for damage or short.
Mar 01, 2010 | RCA RT2400R Receiver
My phone will turn on but my screen is completly black i can make calls and recive them but i cant see anything
Sounds like the phone will need to be sent in for repair :-( You can contact Motorola at 1-800-331-6456 or if you have Verizon service, 1-800-922-0204. The might do a warranty replacement for you.
Oct 14, 2009 | Motorola Mobility Rival A455 Cell Phone
Reciver overload
More than likely, it's not a problem with the receiver. The fastest way to tell is to disconnect all speakers at the back of the receiver and turn it on. If it does not shut down, your receiver is ok and is just protecting itself from damage. If it stays on, check all your wiring, what it sounds like is that you have one or two braids of wire touching the other terminal. Not enough to cause a "short" at turn on, however, when you turn up the volume the resistance increases and creates a short, thus "overload" shows on the receiver. Hope this helps. If you need more help troubleshooting, post a comment and I can help more.
Aug 16, 2009 | Technics SA-DX930 Receiver
I cant recive the files from my bluetooth
welll turn it off and then turn it on and change the settings
Jul 23, 2009 | Sony Ericsson K550i Cellular Phone
2000 watt american legacy amp protection ligh wont go off
Same thing happened to me so I returned it for repair turns out it was an internal 25amp fuse on the output. Got it back an it sounded very weak now it does not play at all. Nothing wrong with my setup as I have now got an 800watt amp that is running great.
Jul 01, 2009 | Lanzar MXA422 Car Audio Amplifier
Turn off write protection on a sd micro card
In the menu, tools, memory card, options you should find the setting for memory card password on/off
Jan 03, 2008 | Samsung SGH-E900 Cellular Phone
My KLH 2400 tuner plays wonderful and then clicks off and then on....and then off....
Suzie, your reciver is going into a protection mode. There is a problem with one of your speakers, the wiring, or +with the reciver itself. If you know how to use a multimeter, then you can test the resistance of the speaker, as if one speaker was partally shorted this problem would occor. If you have another set of speakers, try them. If not then you will need to have the reciver bench checked for a fault.
Oct 07, 2006 | KLH KL2400 Tuner
142 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
