Question about Sony Handycam DCR-DVD105 DVD Camcorder
I recorded my sons wedding with a dvd-rw. I went through the finalization steps. When I tried playing it on a dvd player it wouldn't recognize the disc. I tried to finalize again or unfinalize and the handycam would not let me do either. I can play the recorded dvd in the handycam but not on any other dvd player. I recorded the reception with another disc and that one finalized. I was hoping to put an edited dvd together but don;t know what to do with the wedding dvd. Any help?
    Scholar:
    New Friend:
  • 74 Answers
There is definitely a solution for this but you must use a computer to recover the information on that disc. It also depends on the software you are using to recover such information from the disc. My recommendation would be that you start by simply inserting your disc in the DVD Rom on the computer see what happens when you open My Computer on the Desktop then you click on the DVD rom icon to see if the DVD opens. If it opens it means the information on the disc can be read. so you click again on the folder that appears. If you have a media player installed then that media player will play back those video files. These files can then be transferred to the computer then authored by a computer software like Nero. There are many other programs that can do this job. Also such software can open sometimes such a disc if and when the windows operating system's My computer fails to open it.
Posted on Oct 19, 2011
SOURCE:
How do I finalize my disk once I have finished recording from VHS tape. How do I get the finalize to light up on menu on screen?
If they are +RW discs they cant be finalized and can only be played on +RW compatible players. Use +R, -R or -RW if you need a wider compatibility (DVD-VIDEO). Finalizing is quite easy following directions in the manual.
Apr 20, 2013 | Magnavox ZV427MG9 DVD Recorder/ VCR
RECORDED DISCS NOT PLAYING BACK ON OTHER DEVICES
Did you finalize the disc on the DVD recorder that burned the file? Without more information on your DVD recorder, I can't give you exact directions to find the command on your unit. On my DVD/VCR, after recording, I usually finalize a disc before removing it from the recorder. On mine, I press Menu and go to Disc. I add a title (optional) and then select the Finalize option. Then accept the finalization (which makes it impossible to add more to the disc). For -RW discs, you can unfinalize and then reformat them. Write once discs are permanently stored.
What type of disc did you record to? Some other players may not recognize DVD+R or DVD-R discs or DL discs. Check the specs on the other players and try different brands/types of discs for future recording.
If you add a comment with the type of DVD recorder used to burn the problem discs, I may be able to give additional advice.
Oct 25, 2011 | Televison & Video
What is the difference between a DVD+RW and a DVD-RW.
DVD-RW
It is the re-recordable version of the DVD-R. To use this type of media you will need to buy a DVD-RW recorder. The DVD-RW recorders usually record DVD-R, CD-R and CD-RW media, too. Similarly to what happens to DVD-R, DVD-RW disks can be played in newer commercial DVD players without any problems. Older commercial devices cannot recognize the media, refusing to play the disk. To play a DVD-RW disk, commercial players need the disk to be finished. After finishing the disk, you can only record new data in it by reformatting it, which makes you lose all the recorded data.
DVD+RW
It is the re-recordable version of the DVD+R and everything that was said about the DVD+R is valid for the DVD+RW. Only the newest DVD players play movies recorded in disks using this format. There are recorders on the market that can record both DVD-RW disks and DVD+RW ones. These recorders are called DVD?±RW. Similarly to the DVD-RW, the disk needs to be finished to be played in commercial DVD players, and to record new data in the disk after having finished it requires reformatting it, which makes all the data in it to be erased. DVD+RW recorders are usually capable of reading DVD-RW disks (but not of recording them) and vice-versa.
There you are.
Aug 22, 2011 | Acer Computers & Internet
I just bougth a marantz cdr 300 cd recorder,everything seems to be working fine, but I'm not able to listen what I just recordered on any other cd player.Marantz cd 72 mr 2020.Thanks
It sounds like you haven't followed the last step to the burning procedure. All you need to do once you've completed burning your disc is to Finalize the disc. Read below why you need to finalize as well as the steps to follow in order to finalize the disc.
Hope this helps ;)
How to Finalize Finalizing is writing the TOC (table of contents) on a disc so a CD player can recognize the number of tracks, the total time for each track, and their location on the disc. A recorded disc must be finalized to playback on a standard CD player. Once finalized a CD-R disc can be played on CD players that support CD-R playback. CD-RW discs can only be played on CD players that support CD-RW playback. Consult your CD player owner's manual to confirm supported formats. Finalizing is necessary to: • be able to play a recorded CD-R or CD-RW disc on a CD player • prevent further recording on a disc • avoid erasing tracks on a CD-RW disc • record text information onto a disc you record Notes: • A finalized CD-R disc can never be recorded onto again. • A finalized CD-RW disc can be unfinalized for more recording. • The CDR300 can play back unfinalized CD-R or CD-RW discs. • SYNC REC+FINAL mode automatically finalizes.
Here are the steps in order to Finalize your disk
1 Push Stop. The display shows the number of tracks and their total playing time. 2 Push FINALIZE. FINALIZE is displayed for about 3 seconds.
Jul 27, 2011 | Audio Players & Recorders
Allthough The DVD's I have were made on the DRVCR900, they now cannot be played on it, I'm thinking that the finishing process never took place in order to code it to play on all devices, is there...
Finishing / finalizing DVD should be on the DVD recorder that you recorded previously..
Put it back in..
go to MENU
and look for FINALIZE title under RECORDING menu..
and select it OK ,let it finalize..then you can play it in any DVD player..
one note ..do you know that this recorder can only record to DVD-R
DVD-RW discs...as Write support..not the ones +R/RW
Hope this helps!..otherwise let me know..
Take care and please
Remember to rate/vote and give us 4 Thumbs Up
to continue f
or Helping out the Community :)
Jul 12, 2011 | Broksonic DRVCR900 DVD Recorder/VCR
Which recordable dvds play on this dvd player
this brand and model should be able to play the discs you mentioned witih no problems, unless it is defective, or a error is being made when you are recording the discs. If you are recording and they ar enot playing, most likely you are not "finalizing" the discs durring the burn processs. All discs MUST BE finalized to be played on any dvd player.
Feb 08, 2010 | Teac DV-3500 DVD Player
Our wedding video was recorded on a DVD +RW disc on a Sony DCR-DVD108 camcorder. I did watch it on the camcorder once. I then finalized it so I could play in on my computer and DVD player. Now nothing...
It's possible because your DVD is an RW that someone could have reformatted it on accident erasing the video. If you have something important to preserve make sure you do not use an RW DVD because accidents can happen and it could get wiped out unintentionally.
Aug 01, 2008 | Sony Handycam DCR-DVD108 DVD Camcorder
Unreadable disk error
The laser in 5101 could be defective or maybe just dirty.Try cleaning with a commercial cleaning disc,put a drop of rubbing alcohol on cleaning brushes.When this happens sometimes it will still be a usable disc but not always.Try putting in another dvd player or recorder or your PC if it plays dvds,the readers in PC are of a better quality and will often read discs that those cheap dvd readers can't.
R+ or R- discs need to finalized after recording RW+and RW- discs do not.It is always a good policy to finalze the second your recording is finished otherwise it may not play in other players or recorders.
When you make a recording in a dvd recorder an it doensn't recognize the disc it just recorded it quite often has a defective laser.This particular model has been plagued with early laser failure.
Mar 14, 2008 | Lite On LVW-5101 DVD Recorder
Samsung R155 Recording from VHS Issues
The reason why you are having this problem is because you haven't finalized the disc. In able for you to play that Burned DVD that you have you need to Finalized the disc. Finalizing a recordable optical disc means writing the disc's lead-in (the Table of Contents or TOC) and lead-out information (blank data that fills up the unused space at the end of the disc) so that a DVD player will know where the various tracks begin and end. Without the TOC, a conventional DVD player will not be able to read the contents of the disc. Once the disc is finalized, no more information can be written to it. Finalizing takes about two or three minutes. To finalize a DVD-RW/DVD-R: 1. Press the Menu button with the disc stopped. 2. Select Disc Manager and press Enter or the right arrow. 3. Select Disc Finalize and press Enter or the right arrow. You will be asked twice if you are sure that you want to finalize the disc. Select Yes and press Enter. Once the disc is finalized, you cannot delete entries from the record list. After being finalized, the DVD-R/DVD-RW (video mode) operates in the same manner as a DVD-Video. Recorded discs must be finalized in order to play back in non-Samsung DVD players. A DVD-RW disc that has been recorded by DAO (disk-at-once mode) in a PC cannot be unfinalized. A DVD-RW disc that has been recorded in Video Mode on a non-Samsung recorder cannot be unfinalized by a Samsung recorder. A DVD-R disc cannot be unfinalized. Note: Finalization does not apply to DVD-RAM. If you cannot finalize a DVD-R or DVD-RW disc, make sure that Disc Protection is turned off. If you are still having difficulty, you may try calling technical support of SAMSUNG. Note: Do not turn the recorder off while it is finalizing the disc. Data on the disc will be damaged if the finalization process is interrupted.
Sep 17, 2007 | Samsung DVD-R155
DVD reports: No disk when I try to play a DVD-R record by me
Dvd-R and +RW are two different formats. Check to see if your player should play -R disc.
Sep 05, 2007 | Philips DVP642 DVD Player
Sony Handycam DCR-DVD105 DVD Camcorder Logo
64 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
