Where can I locate the over fill switch on a Calypso washing machine
    Sergeant:
  • 409 Answers
it's usually located inside behind the drum.
Posted on Sep 23, 2008
Drummernick
  • 440 Answers
SOURCE: Washing machine fills with water overnight or when not in use Kenmore calypso
fill area has crack or leaking in repair that in valve
Posted on Feb 04, 2008
canbruce75
  • 1776 Answers
SOURCE: Whirlpool Calypso top loading washing machine
I would check the water inlet valve first. Unplug the machine, turn off the water, and remove the supply hoses. Check the small metal screens inside the openings on the valve. Make sure they are clear of rust or debris and check the solenoids using a multimeter or ohmmeter. Check for continuity. A lack of continuity will mean a bad solenoid and the inlet valve assy will need replaced. I will attach a photo for reference. Sorry for your trouble and I hope this helped. Best wishes.
Posted on Oct 07, 2009
blueextc3221
  • 15935 Answers
SOURCE: Where is the reset switch located on the Calypso
There is no reset.
Simply unplug for 40 minutes to reset the ECU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
jharvey572
  • 447 Answers
SOURCE: Kenmore elite calypso 22066 runs through cycle but
check the water inlet solinoid to see if its working
Posted on Jul 24, 2011
  • 3 Answers
SOURCE: Whirlpool Calypso once wash cycle is selected. The
I had the same problem. My first indication of a problem was that when I washed whites with bleach, I would get dark stains on them. After ignoring problem for a while, then my washer got stuck in a wierd rinse / drain cycle. I decided to unbolt the washplate and found a black sock under the washplate. It seems that the plastic seal around the washplate has worn and allows clothes to get under the washplate and aslo snags clothes. After reassembling the washplate, I decided to pull washer out and inspect. I removed back plate and found another sock stuck in the drain tube. I removed the drain tube from the white plastic tank on washer. The other end of this tube connects to the pump. Once this obstruction was cleared the washer worked fine. My suggestion is: 1.Disconnect all hoses and inspect for objects in them. 2. Look under washplate. 3. With bright flashlight look in plastic tub. All except washplate can be done from back of washer. I still have to address the worn seal on the washplate. Any ideas anyone?
Posted on Oct 18, 2011
Kenmore Model 21082000 won't fill during wash cycle
Try checking the lid switch. Sometimes the switch goes bad or the stem breakes and when the lid shuts it will not activate the switch. Usually located on the right side of the dryer. When the lid closes it will allow water to.fill. Washers are easy to fix and the part is cheap. Get it from amazon dont pay the crazy price your dealer wants. Trust me, i just fixed my mothers...
Feb 16, 2013 | Kenmore Calypso
My calypso GVW9959KQ2 displays L5
its probably LS not L5 code,which is a lid switch failure and this will result in a machine that will fill and possibly agitate,but wont spin out.replace lid safety switch located underneath top of units outer case
Aug 01, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
No water in tub,water supply is conected but it doesn't fill the tub
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Mar 08, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Water isnt going into the machine
heatman101
Dec 05, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Wash drum will not fill with water at all
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
heatman101
Aug 31, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Washing machine starts filling then wont go any
there are a lot of questions of a simular nature check the diaphram switch this controls how much water is taken in and wont progress until the switch says so what you dont say is if the machine keeps filling or stops filling and wont progress
Jan 16, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Machine fills w/water quits flashes lb? lz?
There is a water pressure switch that operates when the required water fills in the tub. this pressure switch in your machine is possibly faulty. In ur case the water keeps filling then it detects an error and stops that's when the lights start flashing. the pressure switch fails to detect the amount of water in the drum and so the machine doesn't move on to the next cycle
Oct 08, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
There is no reset.
Jul 19, 2009 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
