Try plugging it into the wall direct. Sometimes if you have it plugged into a power strip with all kinds of other electronics like your DVD, XBOX, SOUND SYSTEM, Etc. it may not have enough surge power to start up.
Does the front light stays green ? Or goes back to red ? The back-light going on/off maybe the problem, but it shoul return with a red blinking led (4 times ?) and if so it can be a power inverter problem.
back or front of tv .... this could be a blown tube if coming from front. from back there is a high chance this is a blown flyback. i have also seen a blown capacitor that blows a hole in the board. be careful leave unpluged.
Make sure the HDMI cable is connected to the HDMI OUT port on the
back of the PLAYSTATION 3 system. Connect the other end of the HDMI
cable into the HDMI Input port of the TV or display monitor.
While the PLAYSTATION 3 system is in standby mode (red light on the
front of the system), hold down the
touch-sensitive power button on the front of the system until the system
goes into standby mode again . (So the light cycle would go from:
red light --> green light --> then back to red light). This
will ensure that you have held down the power button long enough to
reset the Video Output Settings.
Turn on the PLAYSTATION 3 system and once the system finishes powering
up, the Video Output Settings will automatically reset to the standard
resolution (or detect the current display output settings of your
TV/monitor)....
If green light in front of TV blinks while picture goes off and comes back then its symptom of weak lamp that need to be replaced.
And if green light does not blink in above process then let me know.
Thanks.
you might be holding the power on button to long. you hold the power on button until it beeps to reset the video output. try turning it on by using your controller. just press the ps3 button and if the red light is on then it should come on.
MY TV TURNS OFF AFTER WE TURN IT ON IT GOES BACK OFF A FEW TIMES AND THEN STAYS ON. AND WHEN I COME HOME FROM WORK IT STARTS ALL OVER AGAIN, THAT HAPPENED FOR 2 WKS NOW IT JUST GOES OFF YOU ONLY SEE THE GREEN LIGHT ON THE FRONT COME ON(POWER LIGHT) AND IT GOES RIGHT BACK OFF IT WILL NOT STAY ON
When tv and ps3 backswitch turned on hold down the front power button
when off until the ps3 has done a double beep after the intitial beep
and wait for a max of 1 min and initial set up screen should appear
Read this very carefully. Turn off your ps3 from the back. Then turn it back on wait unit the light is red. Turn on the system through the front keep holding the power on. You will hear a beep one time that just tell you that the ps3 is powering on keep holding the button until you hear the second beep this will rest your video setting. If that dosnt work call me at sony
