Question about Navionics: Gold+ Chart Cartridge
Color definition I have a Lowrance LMS-332 and Navionics Gold chart.There is hardly any color difference between land / water.Water is a light tan color and land is a darker color tan.I have a freind with the same set-up and is not like this.Any help would be greatly appreciated.... Cliff
    Scholar:
  • 157 Answers
Hello bidder42955. I suggest you check your controls for a brightness or contrast adjustment. An X-ray should not have an effect on the LCD display.
Posted on Sep 29, 2008
How do I get my lake map chip to come on
With your card in your unit follow these steps it should accomplish letting you view your map data.
push MENU twice
Highlight CHART push ENTER
Highlight CHART DATA push ENTER
Highlight LOWRANCE push ENTER.
You will note there is an option for Lowrance and Navionics, if you select Navionics you will see a distinct difference in the way the base map displays on your unit.
Hope this helps.
Feb 11, 2015 | Lowrance HDS 5 Fishfinder GPS Chart...
Navionics maps don't seem to work on my lowrance elite 5 chirp
In your menu under CHARTS there is a choice for either LOWRANCE or NAVIONICS. Select NAVIONICS and you should be able to see your chart maps.
Jan 20, 2015 | Lowrance Boating
Why didn't my Navionics gold card download work?
Your running an elite 7. It's not compatible with navionics platinum.
Sep 04, 2014 | Lowrance Elite-7 HDI...
Navionics card wont work
You most likely need to change the map data displayed.
The elite series won't change for you automatically. Lowrance Elite 7 HDI Hybrid Dual Imaging Fishfinder Chartplotter
here is a link to the elite 7 page where you can download a pdf owners manual.
go to the gps/map page on your unit. Find "chart data" on your menu.
select nation is as your chart data. Then you will be ableaving to see your map data.
Jul 30, 2014 | Lowrance Elite7m Chartplotter With Gold...
Charting a route on water
Hi, a waypoint is used to mark a point of interest for location purposes only whether it be for fish, hazards or a boat ramp etc. it is not intended to replace common sense. Your navionics card if purchased will show land masses, shallow waters, channel markers and known hazards. Regards Phil.
Jul 18, 2012 | Lowrance Hds 5 Hds5 Fishfinder gps Chart...
Navionics Gold charts will not display on a Lowrance Endura
i have lost my maps on the gold card Australia e&n i have not taken the card out of my lowrance gps sounder lms 339c since new some three & a half years can they be restored i have had no luck trying to contact navionics australia
Jun 07, 2010 | Navionics Gold United States East...
Hi,when i switch on my lms-332c the map does not come up on the screen.If I remove and replace the map card it works perfectly. Can I fix this? regards nigel
I am guessing that the card you are using is a NAVIONICS chart? There have been some Lowrance units that were made around the same time that have had problems recognizing a Navionics chart right from power up.
Make sure the LMS-332 has the latest firmware version which can be downloaded from http://www.lowrance.com/en/Products/Marine/Full-Size-SonarGPS-Chartplotter-Combos/LMS-332C/Downloads/LMS-332C-Software-Update/
If the update doesn't help, this is going to be a compatibility problem with the LMS-332 and that particular card. You will need to replace the card or upgrade to a newer unit...but probably can just get used to removing and replacing the card when you turn the unit on.
Jul 08, 2009 | Lowrance LMS 332c Mapping Sonar/GPS...
Lowrance Lms 522c 5" Screen Color Internal Gps And 200 Khz Sonar
If it is normal in deeper water, it is most likely just returning stuff in the water (debris, algae, anything floating around...choppy water can cause this). Try installing the latest updates from http://www.lowrance.com/en/Downloads/Product-Software-Updates/
If it doesn't help, adjusting the sensitivity or setting the SURFACE CLARITY option from the SONAR FEATURES menu to LOW, MEDIUM, or HIGH...whichever gives the best results.
Jun 09, 2009 | Lowrance Lms 522c 5" Screen Color Internal...
How do you get the gps to show depth and markers on the water?
It depends on what model you have. Most chartplotters require a chip with regional chart data. Most Lowrance models use Navionics charts. If you have a chip in the GPS, go to the map screen and press the "menu" key. Somewhere in the map setup menu will be a field where you can specify which chart to display.
For example a Navionics gold chart may cover the entire east coast, but it is broken down into a few sub regions. If you are boating in New England you would select the sub region labeled Northeast. Some of the earlier models didn't name the regions, they used model number for each region such as "XL904G". In that case your best bet is to try each one until you can view the charts in your area. Zoom in to 1/2 mile scale to make sure you can see charts.
If you have done all that and still can't see the chart details, there is also a setting in the map setup menu that allows you to set the level of detail. Make sure it is set to normal, more, or most. If you see a declutter setting on the setup menu, try setting it to off.
Jul 21, 2008 | Lowrance GPS
Navionics: Gold+ Chart Cartridge Logo
185 people viewed this question
Top Navionics Boating Experts
Mike Marcotte
Mike Marcotte
Steve
Steve
John
Level 1 Expert
Are you a Navionics Boating Expert? Answer questions, earn points and help others
