Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Fuel pump in a harley fatboy 02
Does a fuel pump run when it's out of the tank ? Should it whirr or something or does it need ground. it looks like i had alot of water in the tank, gas was a creamy color not sure who but WTF Is ther anyway to test a fuel pump short of putting it all back together.
  • Fat02 Sep 27, 2008
    help please
    I tested 12 v to the connector at the pump, it has a full 12.37 volts for about 2 seconds or so , the pump clicks but thats it any ideas ?
    Problem Solver:
  • 11 Answers
Hello...
Q: does a fuel pump run when it's out of the tank ?
A: YES it should run when out of the tank, and it should make a whirring sound when a complete circuit is formed, that means Power IN to the unit from the battery, and then Grounded back to the battery.
If it only clicks, then the pump is stuck/jammed, and you should be looking at getting a new pump.
Posted on Jan 26, 2009
2003 fatboy starts runs for about 3 seconds and quits. Alarm is off, fuel is good, batteries replaced in key fobs. Whats wrong?
Hi Ron, and the usual suspects are:
1. Severely discharged or damaged battery.
2. Loose, corroded or broken battery cable.
3. Alternator not charging or below normal rates.
4. Failed ignition coil, ignition/electronic module.
5. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor.
6. Faulty ignition switch.
7. Water or dirt in fuel system, carburetor or filter.
8. Fuel tank vent system plugged or gas cap not venting.
9. Fuel tank empty.
10. Fuel valve vacuum line broken or carburator vent line closed off.
11. Restricted, blocked or kinked fuel line.
12. Failed fuel pump, pressure regulator and or fuel injectors.
For a prime suspect please visit website below and good luck:
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley...
Nov 28, 2012 | 2003 Harley Davidson FLSTF Fat boy
2000 fatboy will start but wont stay running, have replaced the map sensor, crank sensor, cam sensor. Put a new ignition module and a new coil. Sounds great when it starts but wont stay running. Have
Hi Manda, and the usual suspects are:
9. Fuel tank empty.
Jul 28, 2012 | Harley Davidson FLSTF Fat boy Motorcycles
Does 2005 Fatboy have a reserve gas tank?
Hi Anonymous, no but it does have a warning light that activates when fuel gets down to approximately 1/2 gallon. Have nice day.
Feb 21, 2012 | 2005 Harley Davidson FLSTF - FLSTFI Fat...
2005 toyota corolla. no problems yesterday..this morning it was dead. I can jump it and it turns over but it won't stay running. doesn't seem to be getting any fuel. Which fuse could be causing this...
Fuel Pump-(test for current at the fuel pump using a multimeter or test light while cranking) Removal & Installation To Remove:
  1. Before servicing the vehicle, refer to the precautions at the beginning of this section.
  2. Relieve fuel system pressure.
  3. Disconnect the battery ground cable.
  4. Remove the rear seat cushion.
  5. Remove the rear floor service cover mounting screws and remove the cover (except '02-'04). toy_car_cor-02-04fuelpump2.gif
  6. Remove the butyl tape and remove the floor service cover ('02-'04).
  7. Remove the fuel pump vapor pressure sensor electrical connector ('02-'04).
  8. Remove the fuel line U-clip and remove the fuel line from the fuel pump module.
  9. Squeeze the fuel vent line retainer and remove the vent line from the fuel pump module. toy_car_cor-02-04fuelpump1.gif
  10. Remove the 8 fuel pump module retainer ring mounting screws and remove the retainer ring ('02-'04).
  11. Remove the fuel pump module retainer using special tool 09808- 14020 or equivalent (except '02-'04).
  12. Remove the fuel pump module.
To Install:
  1. Install a new O-ring on the fuel tank.
  2. Install the fuel pump module into the fuel tank.
  3. Use the following procedure to install the fuel pump module retainer ring (except '02-'04). Fuel pump module installation toy_cor-05-18-1203.gif
    1. Align the notch in the fuel tank with the tab in the module.
    2. Matchmark a new retainer with the fuel tank.
    3. Using the special tool install and tighten the retainer ring 2 revolutions.
  4. Use the following procedure to install the fuel tank module retainer ring ('02-'04).
    1. Install the retainer ring on the fuel pump module.
    2. Fasten the retainer with the 8 mounting screws. Tighten 53 in lb (6 Nm).
  5. Install the vent line to the pipe until the fuel vent line connector clicks into place.
  6. Install the fuel line with the U-clip.
  7. Install the fuel pump vapor pressure sensor electrical connector ('02-'04).
  8. Install the floor service cover with butyl tape ('02-'04).
  9. Install and secure the rear floor service cover with the mounting screws (except '02-'04).
  10. Install the rear seat cushion.
  11. Connect the battery ground cable.
  12. Check for fuel leaks.
Oct 16, 2010 | 2005 Toyota Corolla
2002 Harley FatBoy Fuel Injected. It ran good one day and the next it wouldnt stay running, it will start but only run for a second or Two. I can keep it running if I spray carb cleaner in the throttle...
Hi Fireman28, and the usual suspects are:
9. Fuel tank empty.
For a prime suspect please visit website below. Good luck and have nice day.
Jun 18, 2010 | 2000 Harley Davidson FLHTCUI Electra Glide...
Fuel injection Harley Davidson 02 Fatboy
System is self bleeding. You may have disturbed some debris that has gotten in the fuel injector/s. Try running some fuel injection cleaner through it and see what happens.
Jun 30, 2009 | 2003 Harley Davidson FLSTFI Fat Boy
No longer hearing the "whirr" of the electric fuel pump
if this is a no start then the next step is to pull the gas tank and replace the fuel pump module, the fact you heard the pump in many cases means the pumps shaft bearings were worn out, they are pretty silent for the most part.
Apr 09, 2009 | 1997 Chevrolet Blazer
How to repair the fuel pump on my 02 FLSTFI Fatboy
normally if you dont hear the fuel pump when you first turn it on then it shouldnt start at all. sometimes if you know where the pump is you can turn on ignition and run switch while touching the pump, you will feel if it's working. if not, check fuses, may be just blown. if fuel pump is working but dont shut off when motor starts then its not getting enough gas, try changing fuel filter. as for the GUM Berrymans B12 seems to do the trick for me, get the fuel additive and follow directions on the can.
Mar 30, 2009 | 2002 Harley Davidson FLSTF - FLSTFI Fat...
Lands Phones Logo
153 people viewed this question
Top Harley Davidson Lands Phones Experts
David Payne
David Payne
WTF Chuck.....
WTF Chuck.....
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
