Question about Jenn-Air PRG3010 (NP) Gas Kitchen Range
PRG3610NP Brand new. Connected flex gas and 120V. All electric stuff works but no gas going through anywere in the range. What is it? Thanks
  • 2 more comments
  • bortset Sep 23, 2008
    If I disconnect flex hose from the range and open the shut-off valve the gas is coming out of the free end of the flex under normal pressure. Thanks though for checking.
    It feels that ther is some blockage in the stove itself. I thought you know of some kind of the internal valve to check.
  • john gagnon
    john gagnon May 11, 2010
    hi did you check to see if the valve was on cause it would be very strange for no gas to go anywhere
  • john gagnon
    hi thanks for the question is the main valve turned on
  • 943 Answers
When you buy a new stove the manufacture installs a small cap on the stove side i know its silly you probably removed that part before you installed the flex line just check that if you did already well then i,m stump-ted thanks the appliance doc
Posted on Sep 23, 2008
Maytag Gemini gas range.
Not that you can do at home, I would just replace it as it is the only component that might cause this.
Jul 13, 2016 | Maytag MGR6875ADS 30" Freestanding Gas...
Gas pipe manifold pipe size is 3/4 " , should be 1/2 "
The manual says the pipe of the internal gas line is 1/2 and the external line 3/4 flex gas line :
Use 3/4" flex line to connect between the gas supply and the appliance manifold
pipe, which exits the upper rear of the appliance on 30” and 36” ranges. The appliance manifold pipe connection is 1/2" NPT. Use caution to avoid crimping the 3/4" flex line when making bends.
supply and the appliance manifold pipe.
Please click on this link and get the latest installation manual
Good luck.....
Oct 22, 2008 | Thermador Pro Harmony PRD304EHU (Dual...
What is the input - 120v or 240v?
Hello Seth Kwao - If you are referring to a gas range it is recommended to use a receptacle of 120v and a receptacle of 220v for an electric range.
Sep 25, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
We have a 1993 Wilderness RV with a Dometic refrigerator, brain box being of Dinosaur brand (which is ok - reaching 120 volts) Our question is on the front freezer door of the fridge is a strip plate...
Most of these mobile refrigerators can run on gas, 120v or 12v, your gas option is obviously OK, there should be electrical connections on the back of the unit which identify which cable are 12v and 120v.
Again most but not all units were multi option.
You will need to connect these points to the supply. To run this on mains 120v you will need to switch off the gas and 12v, similarly for 12v, no gas or 120v, and for gas no12v or 120v.
If you get the fridge to run on 12v remember that if it is on overnight it can reduce the battery charge.
The best options for these is gas or 120v when you have a mains hook up
Hope this helps
Apr 18, 2011 | Dometic Refrigerators
I have a whirpool range top that i purchased that i now realize i do not have 220 V circuit available (replacing a gas range top). I have 120v available. The range top has a sticker that says 'connect...
It will not operate. The control panel will work but you will have no heat. The top and oven need 220 to actually heat up. The only thing that will work on 120 will be your clock and a warm zone if there's one.
Mar 14, 2011 | Whirlpool Kitchen Ranges
Viking dual fuel range wiring
You will need a neutral, ground and 2 wires carrying 120V each
Dec 27, 2008 | Viking 48" 6 Burner, Grill Professional...
I need to wire up the electrics on a gas cooker
the oven should have a flex already fitted, this will need to be plugged in or connected in to a supply ensuring it is correctly fused, i suggest no more than 3 amp.
Oct 05, 2008 | Parkinson Cowan SG340 Gas Kitchen Range
Jenn air pro range 36" prg3610np
hi after the burner ignites turn knob until it stops trying to ignite thanks
Jan 07, 2008 | Jenn-Air PRG3010 (NP) Gas Kitchen Range
Jenn-Air PRG3010 (NP) Gas Kitchen Range Logo
236 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
