Question about Onkyo HTR500 Receiver
Pushed a button on the remote and now no sound
I pushed a button on the volume remote and not I can not get any sound at all from the receiver. I have no idea what button I pushed and the receiver isnt showing any mute or any other kind of information to tell me what I did. please help. what do I push to get out of this mode I have a onkyo htr510
  • 1 more comment
  • sanddlr753 Oct 10, 2008
    No, it wasnt the volume control button.
  • sanddlr753 Nov 29, 2008
    THANK YOU mingkong!!!! I know who to go to next time I need help with something! I think you should take the guru place!
  • Anonymous Mar 28, 2014
    Volume
  • 17 Answers
Make sure that the speaker A button is pressed (check the display to see if there is a letter A on it.)
Posted on Nov 28, 2008
  • 135 Answers
Did you push the volume control "UP"?
Maybe you blew it.
Posted on Oct 03, 2008
  • ted dux Oct 11, 2008
    Well, I guess it still doesn't work.
    It may require repair, sad.
  • ted dux Feb 17, 2010
    RTFM.
DCT700/US - Unable to turn on with remote. Yellow light flashes on then off to brief red light then nothing. Tried removing cables and plugging in to power outlet only, but same result.
it sounds like the box is working proper... just needs to wake up. the remote may be your problem.
God Bless Motorola For Giving Us Cable Boxes With No Buttons!
ok, does your remote have lights that flash when you hit buttons?
for example pushing volume lights up tv. if the cable light doesn't flash then it may need reprogrammed. if none of this applies to your remote... sorry
good luck
Sep 06, 2011 | Arris DCT700 DTV Receiver
My remote is fine, but i don't know which button to push or sequence once I've changed batteries to for it to work the receiver. Each time I change the batteries it doesn't interact with the receiver, but...
It's likely that you've pressed one of the input mode buttons accidentally while changing the batteries. You've probably switched the remote for operation of a TV or DVD player or some other device.
To correct this problem, simply press the RECEIVER (TAPE/AMP) button once, then try the remote again. Pressing this button informs the remote that you wish to operate the receiver with it again. The RECEIVER button is about halfway down the left-hand side, above the TV button and below MACRO 1.
Please try this first. If the receiver still does not respond, switch the receiver off and back on again. It may have lost the communication with the remote. Resetting the receiver will usually correct this problem.
Hope this helps. Please let me know if you need further assistance.
Regards,
BElectric.
Feb 26, 2011 | Onkyo TX-SR703 Receiver
I have an Yamaha HTR 5730 AV receiver. I have a red and one jack that will fit into the rear of the receiver and other end of the cord fits into my headsit area of my I Pod Touch .... where do I hook it up...
Here is what you can do. The cord coming out of the iPod should have a red and white pair of RCA connectors on it. The red one is for the right channel and the white one is for the left channel.
Plug those connectors into the back of the receiver on the "V-Aux" connectors.
Leave the iPod off. Turn the receiver ON. Turn down the volume on the receiver completely.
Turn on the iPod and put some music on at a low volume. Then push the "V-Aux" button at the top section of the remote and turn the volume up on the receiver. You should get sound. The receiver should be set up for Stereo for the test.
Hope this helps,
Good Luck,
Mark
Jan 15, 2011 | Audio Players & Recorders
Speakers on my Pioneer VSX-D466S receiver are not working. Is there an internal fuse that may be blown?
some recievers have a monitor button on them. if it gets pushed your sound wont work. look at the display and see if you see the work monitor. if so you should have a monitor button either on the reciever or the remote. it is a toggle button so just push it till it goes away and sound comes back on. make sure to turn sound back down before pushing this button as you might have turned the volume way up trying to hear it. my wife accidentally pushed it last week and she thougt is was broken untill i got home and simply pushed the button.
Dec 24, 2010 | Pioneer Audio Players & Recorders
How do i turn up my back speakers?
Grab the remote for your vsx1018 and press receiver at the bottom of the remote then press the number zero button (this button acts as the channel level function when remote is in receiver mode) you will then notice that if you repeatedly press the zero button that it will cycle through each channel on the vsx1018 display (L for front left, C for center, R for front right, SR for side right, SBR for sarround back right, SBL for sarround back left, SL for side left, and last but not least SW for subwoofer rca jack output to your sub amp. After you have selected the speaker volume you want change ( SBR and SBL in your case) then push the left or right of the circle that sarrounds the enter button on the remote in order the fine tune the volume for each speaker,and after you are finished setting the volume the way you want then push the return button that is to the lower right of the circle that sarrounds the enter button on the remote. Cool huh!! :-) Oh ya, somthing else that is cool about the vsx1018, you can put music from your computer onto a thumb drive and then plug the thumb drive in the the ipod usb and the music will play!! IE press ipod button on remote and then use the circle to change music tracks.
Aug 29, 2010 | Pioneer VSX-1018AH-K Receiver
YAMAHA AV receiver RX-V861 I have the message 'Vol-fix' appearing on Zone 2 and no sound. This was working fine until then
Setting the RX-V861 remote control to operate Zone 2:
  1. Using a ballpoint pen or similar object and press the [CODE SET] button RX-V861 remote control. The[TRANSMIT INDICATOR]on the remote should flash twice.
  2. Using the [NUMERICAL KEY PAD] on the remote and key in 9992, the [TRANSMIT INDICATOR] should flash.
Assigning the receivers internal amp for Zone 2:
  1. Set the remote control selector to [AMP]. (Located to the right of the volume buttons on the Remote.).
  2. Press the [SET MENU]button on the remote control.
  3. Arrow down to Manual Setup and press the Enter button on the remote control.
  4. Arrow to the [SOUND MENU] option and press the [ENTER] button on the remote control.
  5. Arrow to Speaker Set and press the [ENTER] button on the remote control.
  6. Arrow to the EXTRA SP ASSIGN and select ZONE2
  7. Press the [RETURN] button on the remote control to exit out and return to the Manual Setup.
NOTES: There is an option for setting the Maximum Volume and Initial Volume in the Zone Set menu.
  • Max Volume: This is an optional feature but isrecommended to prevent the accidental change in volume levels thatcould damage the speakers and receiver.
  • Initial Volume: This is also a great feature that would seamlessly start the volume level for the second or third zone at the desired level.
We do not recommend using any Speaker Selector boxes to enable more than the recommended number of speakers per terminal.
Controlling Zone 2 using the RX-V861 remote control:
  1. If the Main Zone on the receiver is on, press the [POWER BUTTON]down and while holding that button down press the [PHONO]/[**] button on the remote. The [TRANSMIT INDICATOR] will light up.
  2. You will not be able to use the following buttons on the remote: (Pressing any other button will cause the remote to exit Zone 2 mode. [POWER], [STANDBY], [VOLUME], [MUTE] and the [INPUT SELECTOR] buttons [DVD], [CD], etc.)
There are the instructions as written straight from yamaha. If you need any further assistance please let me know.
Thank you,
Lee
Dec 13, 2009 | Audio Players & Recorders
No sound when on internet radio, playtime is running, volume is not muted, internet ok
It was solved by turning the receiver off with the power button (not stand-by). After turning on the netradio did have its sound back. Apparantly it must be running some sort of Windows os.
May 16, 2009 | Denon AVR 3808Ci Receiver
Synergy V rt-u64cp remote to control Receiver volume
For those who want your audio device volume to work without changing modes here's how: hold cable and select until cable lights up - then press volume+ and then press audio. That's it.
Apr 06, 2009 | Televison & Video
Onkyo HTR500 Receiver Logo
252 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
