Question about Acer Aspire 5600 Series 5610-2013 Notebook
My acer aspire z series wont boot up - Acer Aspire 5600 Series 5610-2013 Notebook
  • Paul Bade Oct 18, 2011
    Does it start the power cycle? Can you get into the BIOS setup? If so, is your hard drive model shown in the device list? What is your operating system version?
  • Lebanon Raingam
    Lebanon Raingam Oct 18, 2011
    Please let us know with more details about your problem. It's not possible without knowing the condition of your laptop. At least try to explain whether it boots up or never. Also check the battery/charger. Make sure the battery is working. Remove the battery and connect the charger. Try booting the system only with the charger. Thanks a lot.
  • Acer Master
  • 17,130 Answers
Possible that PC is hanging up as there is fault on the OS (operating system) or a virus in the OS. Also it is possible that the backup battery (CMOS) has low voltage or the memory card is a suspect. In this case you need to check the voltage and also try and swap a memory card. Sometimes the memory card connections can be faulty either on the card or on the slot. Cleaning the slot and card must be done before you try a replacement. If the PC boots and fails then the hard disc can have bad sectors or is corrupt. However if there is no result the motherboard also can be suspected. In this case you might need the help of proper tools and equipment support to do a chip level service.
Posted on Oct 18, 2011
4 Suggested Answers
SOURCE:
tat4u
  • 520 Answers
SOURCE: acer aspire 5610 wont boot windows XP
turn on pc enter bios setup select default settings save and restart.have os disk in drive wait for screen display any key to start from cd.press any key to load disk.in options select install windows ( not repair) your system will find existing os ,now you can choose repair or install fresh copy.if you choose to install fresh copy delete partition first and create new partition and format.
Posted on Mar 02, 2008
mewms_14904
  • 1027 Answers
SOURCE: new laptop
Open the hard drive bay and make sure the hard drive is properly seated. close bay
reboot and enter bios to see if hard drive is detected in bios, if the hard drive is detected and still will not boot use recovery console to recover the OS.<ALT><F10>
If the bios does not recognize tthe hard drive, replace hard drive.
Posted on May 08, 2008
leethedeuce
  • 4472 Answers
SOURCE: acer aspire 5570z wont boot to windows
Insert a windows boot disc. Go into the bios select it to boot from CD-ROM first. Then you can go from there. If you get it to boot to windows disc, then you could start reinstalling windows. If you are still having issues then there is a more serious issue. If you have any other questions let me know.
Thanks,
Lee
Posted on Aug 11, 2009
I used it the night before it was fine i plugged in the charge and it wont turn on at all
laptop charger for acer aspire 3600 3680 series 3650 3610
www.amazon.com/LAPTOP-CHARGER-ACER-ASPI...
Amazon.com, Inc.Amazon.com: LAPTOP CHARGER FOR ACER ASPIRE 3600 3680 SERIES 3650 ...When I was looking for a charger cable for my laptop, i was not sure whether I ... it was really good and worked, it heats up a little bit but for now its working ...
When your acer aspire 5738 z laptop adapter is not working ...
docslide.us > Business
Aug 18, 2015 - When Your Acer Aspire 5738Z Laptop Adapter is Not WorkingA ...Quicker Charging of Laptop Battery with an Acer Aspire 3600 AC Adapter ...
batteries-store.pblogs.gr/.../when-your-acer-aspire-5738z-laptop-adapter-...
Jan 14, 2016 | Acer Aspire 3600 Laptop Charger...
Acer Aspire 5552-3691 Screen Wont Come On
Have you tried re-seating the memory, if yes and still not booting then it is most likely the mainboard as it was the most common faulty item with this series.
Jul 10, 2014 | Acer Aspire 5552-3691-24271 Laptop
My acer aspire one 722 wont boot startup repair wont fix it
This is a problem in your BIOS which is a common problem on acer aspire one laptop model. To fix that you need to flash your bios. Please watch this video for a step by step guide on how to do that.
Feb 15, 2013 | Acer Aspire One 722-0022 : 1.0GHz C-Series...
I have an acer aspire one series ZG5 that wont boot up in windows? what do i do?
Somehow the BOIS password has been enabled. If you dont know this password then you going to prob have to take to a computer shop unless you know how to access the motherboard and remove the cmos battery and short the terminals for 10 seconds. this will erase the memeory and reset the bois to default which doesnt require a password.
Hope this helps
Roger
Feb 07, 2012 | Acer Computers & Internet
Acer 5200 inspire wont boot and no screen - dvd works and fan comes on
This is most likely common problem with ACER 5000 SERIES With Chipset motherboard problem and motherboard will need repair. Contact kapilsabarwal@gmail.com for solution or call +919811049801.
Jul 06, 2010 | Acer Aspire 5100-5022 Notebook
How to reset my ASPIRE 5534 Series laptop do to
I can't get my Acer Aspire 5534 to play movies on DVD
Jan 06, 2010 | Acer Aspire One PC Notebook
ACER ASPIRE 5100 SERIES. WILL NOT DO ANYTHING. NOTHING WORKS, MOVES, MAKES ANY SOUNDS, BLANK DISPLAY. BATTERY LIGHT FLASHES WITH CHARGER PLUGGED IN. TRIED REMOVING RAM, AND HARD DRIVE. NOTHING.
the battery might be hosed up will it boot without the battery and just plugged to ac - if it wont boot from ac with the battery remover send it to acer
Dec 27, 2009 | Acer Aspire 3000 Notebook
Black screen on acer aspire one series zg5
You should contact Acer. They know they have a display problen with the Acer Aspire One that can be fixed with a BIOS upgrade. We got our done. They sent us a USB thumb drive with the files and instructions on how to boot the thumb drive. After a couple of minutes the Acer restarted and all is fine.
Jun 01, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire 5600 Series 5610-2013 Notebook Logo
177 people viewed this question
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
