Question about Ricoh FT5832 Copier
Ricoh FT3713 getting an E70 error message and copier will not make copies........any ideas??????
  • 3 Answers
That's an oldie, but if I remember correctly the code is related the waste toner being full, which is to the left of the drum unit.
Posted on Oct 04, 2008
  • 97 Answers
Try to properly close the cover and also the Drum Section
Posted on Sep 23, 2008
Have a PE error code, can't find anything in the service manual. I am a Ricoh Technician.
That is a Paper Empty message.
Check the paper cassett home switch and sensors for the tray stack.etc. Then clean or replace the rollers.
Apr 26, 2011 | Ricoh FT3713 Copier
My ricoh FT4418 wont copy at all error code E70. what does that mean?
It means the toner overflow sensor was tripped: http://www.copier-help.com/copier-help/ecs/ricoh/ecrft4418.html
Mar 14, 2011 | Ricoh FT5832 Copier
Error code E-22 in RICOH FT3713
· Scanner home position sensor failure
· Defective scanner motor
· Defective main motor
· Defective dc power supply board
· Incorrect scanner drive wire position
· Defective dc harness
· CN103 or CN105 on the main board is not correctly connected.
· FU202 on the dc power supply board open (blown fuse).
Jan 08, 2010 | Ricoh FT3713 Copier
ERROR MESSAGE ON RICOH BLACK AND WHITE FT3713 ERROR E70
Waste toner is full. Remove cleaning station, empty waste hopper, and run "SP83" to clear code.
Apr 22, 2009 | Ricoh FT3713 Copier
My Ricoh FT3713 is making a loud screeching noise when it makes a copy can you help me?
The scanner sometimes does that. If you put a copy on the glass and keep the cover opened, does it seem to happen in time with the scanner sliding back and forth?
If so, you could remove the glass and put a little oil on the rails.
** please rate me :)
Mar 18, 2009 | Ricoh FT3713 Copier
Ricoh ft3713 error code e54, where is the fuser and thermistor
You need a tech, or a new machine. The fuser is the heater section nearest the exit of machine - where they are always located. Your error message indicates a blown fuse, or lamp, or thermistor. The code can only be reset in service mode after the problem is fixed.
Mar 08, 2009 | Ricoh FT3713 Copier
Hello mine is really an FT3713
This sounds very scary...
Your Machine is very old..
What did you do last to the Copier to get it in this condition?
All you should have done is empty the Waste Toner bottle, and do SP83.
Oct 26, 2008 | Ricoh FT3713 Copier
Ricoh ft3713 toner overflow
remove the toner bottle, open the back cover and look for the small DIP Switch turn on and off, by doing this you are forcing the machine to come out from add toner condition. Then you do 20 sky shoot.
Oct 24, 2008 | Ricoh FT3713 Copier
Ricoh ft3713
Please properly installed the Drum Unit
Sep 22, 2008 | Ricoh FT3713 Copier
Ricoh FT5832 Copier Logo
192 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
