1997 Hyundai Sonata Logo
A
Anonymous Posted on Oct 18, 2011
Need spark plug firing order for 1997 hyundai sonata
ZJ Limited
Level 3:
  • Hyundai Master 17,989 Answers
  • Posted on Oct 18, 2011
ZJ Limited
Hyundai Master
Level 3:
Answers
17989
Questions
0
Helped
14458848
Points
60858
1997 Hyundai Sonata GL 2.0 liter DOHC L4
1997 Hyundai Sonata GL 3.0 liter SOHC V-6
I hope this helps, abd just keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment. Have a nice weekend and thanks for using FixYa.
Jose.
My 1997 Hyundai sonata, won't fire. I have
check your crank shaft sensor behind the harmonic balincer
Yahoo.com what is the firing order on a hyundai sonata 1996 2 litre
The firing order diagram you requested is below. Best of luck and thank you for using Fixya!
Greg
1996 Hyundai Sonata 2.0L Firing Order
Firing Order: 1-3-4-2
Spark plug settings for hyuandai sonata 1997
Please clarify your question. Do you need to know the spark pug gap, or the firing order, or something else. I would like to help you, but I need more information.
1helpful
2answers
I can't find the location of the crankshaft postion sensor in my 2000 Hyundai sonata
My online Sonata manual shows these possibilities, but does not identify which applies specifically to 2000 Sonata.
Also, when you talk to the dealership parts counter, you'll need to know whether your 2000 Sonata is (a) 4-cylinder 2.4L MFI DOHC engine, or (b) 6-cylinder 2.5L MFI DOHC engine.
Its easy to tell - just count your spark plug wires.
-- begine excerpt from 2000 Hyundai Sonata Repair guide --
The crankshaft position sensor is located next to the flywheel.
The crankshaft position sensor is located next to the flywheel/torque converter.
The camshaft position sensor is located on the engine near the timing belt cover and under the upper radiator hose.
The crankshaft position sensor is located on the driver-s side of the vehicle, down by the lower radiator hose.
The crankshaft position sensor is located on the engine near the crankshaft pulley.
The crankshaft position sensor is located at the front of the engine near the timing belt.
--- end excerpt from 2000 Hyundai Sonata repai guide ---
I just need a diagram of spark plug replacement in 1997 Hyundai sonata 2.0 liter engine automatic.
For the 1997 Hyundai Sonata 2.0L DOHC In-Line 4-Cylinder:
Firing Order:
1 - 3 - 4 - 2
Cylinders:
..........(back)..........
|...4....3....2....1...|
.........(front)
Coil Connections:
(back)
|..1..|
|..4..|
|..3..|
|..2..|
(front)
Let me know if this helped and THANKS for using FixYa.com!
Spark plug cylinder
For the 2005 Hyundai Sonata
I do not know if you have the 2.4L In-Line 4-Cylinder or 2.7L V6; however I have included both below....
For the 2.4L In-Line 4-Cylinder:
Firing Order:
1-3-4-2
Cylinders:
|...1....2....3....4...|
.........(front)
For the 2.7L V6:
Firing Order:
1-2-3-4-5-6
Cylinders:
|...1....3....5...|
|...2....4....6...|
.......(front)
Coil Connections:
(back)
...3
...6
...2
...5
...4
...1
(front)
Let me know if this helped, or if you have additional information or questions. Feel Free to contact me at FixYa.com!
Firing order for 1994 Hyundai Sonata 3.0 L V6
For the 3.0L:
Firing Order:
1-2-3-4-5-6
Cylinders:
....(back)
6.....4.....2
5.....3.....1
.....(front)
Distibutor Connections:
....(back)
4.....5.....6
o.....o.....o
o.....o.....o
3.....2.....1
....(front)
Let me know if this helped or if you have additional information or questions. Feel Free to contact me at FixYa.com!
2helpful
Which cylinder in #6 on a 2006 V6 hyundai sonata
Autozone.com says that for this vehicle the firing order is 1-2-3-4-5-6 and the set-up is 2/1 4/3 6/5 meaning that the #6 cylinder is far right on the back. It goes #1 #3 and #5 in the front and #2 #4 and #6 in the back.
NO FIRE
hi there, you need to make sure all wires to spark plugs are tight and very snug, you will also need to check the distributer cap to make sure no burns are on it, and make sure the plugs are in proper firing positions, the spark rotation might be out of sequence.....also make sure spark plugs are clean of all oil, and dirt, firing pin in distributer cap might be bad.....hope this helps....shia
Top Hyundai Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Hyundai Expert? Answer questions, earn points and help others
