Question about Frigidaire Refrigerators
Water dispenser does not shut off - Frigidaire Refrigerators
  • Frigidaire Master
  • 4,655 Answers
That is most likely a dual water control valve stuck open on back of refrigerator near floor. One side feeds ice maker and other side feeds the water dispenser. If the ice maker side began to leak slowly it would create quite a mess of ice flowing over ice maker and freeze every place it could inside the freezer. Part and Model Search If helpful Please Rate this solution, Thank You, Sea Breeze
Water dispenser does not shut off - sea_breeze_260.jpg Refrigerators
Freezers
Washers and Dryers
Posted on Oct 18, 2011
SOURCE:
I used the water dispenser and when done it wouldn't shut off. This is an inside of the unit dispenser. How do you fix this?
Your unit has a inlet valve that the supply of water flows to..This valve splits between allowing water to either the dispenser or the icemaker..This valve may be sticking open allowing water to keep flowing to dispenser..Google Model # w/problem to find location and part#..or call your local appliance repair company
Jan 04, 2018 | Samsung RF266AEPN Refrigeration :...
Water dispenser will not shut off
Touch Free Sensors Part number 12-2495-21
Feb 26, 2014 | Scotsman MDT5N40W-1J Touchfree Water...
Water dispenser won't shut off
Sounds like the ice maker is not shutting off like it should.
Jul 10, 2013 | Kenmore 54603 / 54606 Side by Side...
Electrolux water dispenser wont shut off
If your water dispenser will not shut off then it is either the dispenser microswitch or the water inlet valve in the back of the refrigerator. Here is link that might help http://apcoappliancerepair.wordpress.com/?s=water+dispenser . Would need a model and serial number to assist you more. Good Luck From Apco Appliance and Air .
Apr 19, 2013 | Electrolux Refrigerators
Water dispenser wont shut-off
Check the solenoid valve is not stuck open. It lets water in, pushing cold water out, and if stuck will not shut off.. It may even have a broken spring, but that is quite unusual
Apr 21, 2012 | Refrigerators
Kitchenaid model ksrs25ilss02 water filter
Are you saying water is dripping out the ice dispenser or the water dispenser, a water filter would have nothing to do with this, it only filters water, it does not pump water nor does it shut it off. If water
is dripping from the ice dispenser, it is because the rubber gasket
is bad on the flap that seals after ice is dispensed. If water is dripping
from the water dispenser, it is the shut off for the water, you can put a glass under it and push for water a few times,on and off and see if this makes it stop, if not you would need to have this replaced. Any questions please post back.
Mar 27, 2009 | LG LRSC26940ST 36" Side-by-Side...
Water dispenser wont shut off
Something from the filter went into the dispensor valve and is holding it open. You can try to backflush it with a can of air by disconnecting the filter pushing open the valve while holding the can straw tightly while discharging it. You could also backflush it with water.
Jan 12, 2009 | LG LRSC26910 Side by Side Refrigerator
Refrigerators Logo
289 people viewed this question
Top Frigidaire Refrigerators Experts
Steve Allison
Steve Allison
Thomas F. Schneider
jasbo
jasbo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
