1996 Buick Regal Olympic Gold Logo
Anonymous Posted on Sep 22, 2008
1996 Buick Regal Sport - Leaking Plastic Elbow
3.8 L V-6 - a small black plastic elbow under Alternator is leaking coolant.
No photo in manuals, don't even know what to call it .... BARS leak no help.
  • 1 more comment
  • Anonymous Sep 22, 2008
    Does this thing have a name?
  • Anonymous Mar 14, 2009
    Don't waste your time with Bars Leak or J&B Epoxy - They
    won't work !! - Follow one of the above fixes ....
    I spent over $60 and two days trying to fix the little "Elbow with no
    name" - all I did was gum up the thermostat & radiator with
    stop leak ... more $$$ and repairs
    Do it Right the FIRST time!
  • Anonymous Mar 31, 2014
    Leaking antifreeze from front of intake it looks like a plastic elbow and goes to the tensioner
DANNY COIN
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 02, 2008
DANNY COIN
Contributor
Level 1:
Answers
Questions
0
Helped
2521
Points
23
YOU NEED TO REPLACE THE BELT TENSIONER.
IF YOU BUY THE CARTER BELT TENSIONER AT ADVANCED AUTO, IT COMES WITH: A PLASTIC ELBOW WITH O RINGS, TENSIONER, PULLEY, NEW O RING WHERE THE BELT TENSIONER MATES TO THE ENGINE BLOCK AND NEW O RINGS FOR THE INLET AND OUTLET CONNECTIONS ON THE BELT TENSIONER TO THE HEATER CORE (COST $72).
IF YOU DON'T REPLACE ALL THE ABOVE O RINGS THEN YOU CAN EXPECT MORE LEAKS.
IN ORDER TO REPLACE THE PLASTIC ELBOW YOU MUST REMOVE THE BELT TENSIONER ANYWAY. IF THE BELT HAS SEVERE CRACKS REPLACE IT ALSO.
STEPS:
-REMOVE BELT
-DISCONNECT BATTERY
-DRAIN ANTIFREEZ AND DISCARD
-REMOVE ALTERNATOR
-REMOVE BELT TENSIONER
-REMOVE PLASTIC ELBOW (DO NOT ALLOW BROKEN PIECES PLASTIC OR DIRT TO GET INSIDE THE ENGINE WATER CAVITIES.
-CLEAN ALL CONNECTION WHERE O RING WILL MATE.
-TO REASSEMBLE GO IN REVERS ORDER
-REFILL THE RADIATOR WITH COOLENT 50% MIX USE THE 5 YR GUARANTEE TYPE.
-MAKE SURE THE COOLENT RESERVIOR IS
FILLED TO THE HOT LEVEL MARK.
-RUN THE ENGINE UNTILE IT IT REACHES THE 1/4 % TEMP MARK ON THE TEMPERATURE GAUGE THEN TURN THE ENGINE OFF AND OPEN THE BLEED SCREW ON TOP OF THE THERMOSTAT HOUSING.
ALLOW THE AIR TO EVACUATE, YOU WILL SEE COOLENT COME OUT THEN CLOSE THE BLEED SCREW.
-BE VERY CAREFUL WHEN YOU OPEN THE RADIATOR TO REFILL TO THE TOP.
-REPEAT THIS ONE MORE TIME.
-RUN THE ENGINE AND KEEP YOUR EYE ON THE TEMPERATURE GAUGE' IF THE TEMPERATURE GOES BEYOND THE 1/2% MARK, SHUT DOWN THE ENGINE QUICKLEY AND LET THE ENGINE COOL.
THIS MAY TAKE HOURS TO COOL DOWN BUT THE COOLING SYSTEM WILL TURN FROM PRESSURIZED TO VACUUM AND DRAW COOLENT FROM THE RESERVOIR TO REFILL THE SYSTEM.
YOU WILL NOTICE THE LEVEL DROP IN THE RESERVOIR .
Anonymous
Level 1:
  • Posted on Dec 10, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
2521
Points
This is the water pump bypass elbow ,,auto zone has them in a 2 pack ,2 sizes in the pack ,first disconnect the neg battery cable,take off the alternator and set aside leave the wires attached , find ur heater hoses they come from a box that gets it water from the pump ,,the bow is bolted on un bolt it and u will be able to change the small elbow , might have to unbolt the power steering pump too kinda hard u have to use a socket through the holes in the pulley , and might have to take off the water pump pulley also ,,
3100 engine antifreeze leaking from area under a
  • There is 1 or 2 elbows (plastic from factory) that connect the coolant channels from the engine block to the tensioner pulley housing. Mine only had one (in front, visible and disintegrated) and in the back, the pulley housing had a nipple (cast) that had o rings and was inserted into the back coolant hole in the block.
  • You need to make sure to remove all bolts holding the tensioner housing on.
  • Swivel and/or wiggle the pulley housing off very slowly so as not to break that nipple off of the pulley housing.
  • The parts stores only sell the elbows in 2 packs, but they do have metal instead of the original plastic.
How to remove belt tensioner on a 2002 buick regal l s 3.8l
disconnect battery first, unbolt alternator(3 bolts), cross bar bracket(2 nuts) unhook both heater hoses out of the connectors(each has a 7mm head bolt in them, then twist loose), remove belt, then there are 3 bolts holding it on the motor, has a plastic elbow to the intake and an o-ring seal male port that goes into the timing cover. gently pry back and forth to work it loose so not to break either the elbow or the port off. alot of times it seizes up in there. the elbow is a hat trick to get in and out also, just be patient and take your time
2answers
How do you change out a heater hose elbow in a 2005 buick lacrosse
cool car down and drain the radiator, usually a spigot or valve at the bottom. remove the clips or clamps holding the hose on, pull hose off. get a new hose from any parts store, sometime helps to have the old one with you. install new one, put on new clamps and tighten firmly, pour in new coolant. check your owners manual to see what kind of coolant Buick recommends.
Leaking coolant from 90 degree elbow
Bad clamp or hose, or even a crack in the elbow,, clean area with engine cleaner and post a better description
2answers
I have a water leak coming from my engine block. How to repair 2001 Buick 3.8 It is come out of a 5/8 pipe or around it
If it's a hose, best bet is to just replace it, and use new clamps.
If it's leaking where it's connected to the nipple, for a quick fix, you can remove the hose, cut the hose off past the leak, and reattach it.
This requires a little bit of slack in the hose, but if the leak is right at the connection, there should be enough slack in the hose to do this.
Leaking coolant
These plastic elbows (3.8L Engine) do fail. To the best of my knowledge this is a dealer only item, which is not a big deal as the cost is low (in terms of car repair). Remove the alternator to gain access to the elbow. Monitor the coolant level following repair.
As you probably know, don't let the engine run low on coolant as engine damage will follow.
Top Buick Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Buick Expert? Answer questions, earn points and help others
