Question about Zonet ZSR0104CP (zsr0104cp) Router
It says to do port forwarding i need a static ip...
How do i create a static ip. I tried myself but i couldn't make it because i have a wireless connection card and my ip always changes i think
    Genius:
  • 3,422 Answers
HI,
Please let me know at which step you are stuck.
Posted on Sep 23, 2008
How to enable wireless connection on dell latitude e4300
I have had this issue on DSL troubles.The most common issue is the settings for the IP address.A computer in a business location will often be set for a static IP.You can change it,but don't forget to write down the static IP settings(as soon as you click on the "bullet" for "obtain IP address automatically" ,the static info is GONE,and there's no way to retrieve it.Go to control panel/network connections,right click on the NIC or Wi-Fi connection being used,click properties,highlight Internet Protocol TCP/IP,click properties.This will show auto or static IP.
May 31, 2012 | NetGear WGR614 Wireless Router
Hi, I have D-link AirPlus Xtreme G Wireless Router. The problem is that when i connect my laptop to the wireless connection it says it's connected but then i cant even open a page. I'm with...
The problem could be that the static IP address is not in the range as the IP address as the router.
You should let the wireless router issue an IP address to your computer.
Change the TCP/IP settings in your laptop's wireless card to Obtain an IP address automatically and Obtain DNS server address automatically.
Then reboot your laptop.
May 22, 2011 | D-Link AirPlus Xtreme G DI-624 Wireless...
I have dsl modem routeur dhcp enabled with ap wifi ssid = x everything ok ip 192.168.1.1 i have tew 637ap n upgrader wire connected on dsl modem router with static ip 192.168.1.20 ssid = y everythings...
You may be trying to connect through a G or B device to your N router. Verify that there are no serious obstructions or that the pc is not underneath something or enclosed. Metal near the pc can cause the signal to lose strength. Not having a wireless N card or adapter can also cause this.
Also if you are trying to connect through ethernet cable verify that windows is being assigned an automatic ip address, if it is static in windows change it to automatic.
Apr 29, 2011 | Trendnet TEW-638APB 300Mbps Wireless N...
I have a wired connection that i share thru my wireless internet.i can get on the internet with my computer.i have the connection being shared but everytime i do the test i get a IP address but internet...
have you restarted the modem, and then plugged in the wireless connection afterwards, you may need to configure your system to have a static ip address, this may help, here is a guid to help guide you.
Mar 29, 2011 | Video Game Consoles & Games
Connecting Linsys wireless off of 604...needs 192.168.1.* to operate...can I create this as a static IP
yes you can to do this first connect with network cable to pc enter the ip adres and log in on the router ther in the menu you can change the ip adres thad you need dont forget to save befor closing otherwise the old ip adres stays
Dec 20, 2009 | D-Link DSL 604+ (DSL-604+) Wireless Router
I have a iphone 3gs and want to access wifi or wireless on toshiba satellite pro x200
Laptop normally have single chip WiFi or Wireless Cards...
These cards could be used as client(connecting to wireless router), adhoc or access point(a WiFi card could be used as Access Point to route your LAN(Wired) connection on WLAN)...
Your laptop WiFi card is already busy as a Cleint, so if you want to use it as AdHoc, you have to remove all the other connection with the WIreless...ie, Disconnect the WLAN from connecting other devices, and follow the below mentioed steps to connect your device..
When you are using Client mode you are not able to use it on Ad-hoc or Access Point feature...
Setup laptop to Ad-Hoc
1)Navigate to control panel and choose network connection, Right click on the Wireless network connection and click on the Properties on Wireless NIC
2) Click-Wireless Networks Tab
3) Click-Add
4) Provide SSID Name, name to identify you rnetwork
5)Security -Net Auth: Open
6)Make -Data Encryption: Disabled
7) In the check box present-Check on This is a Computer to Computer (ad-hoc) network.
Change the IP address of the Wireless NIC card, by choosing TCp IP in the properties of WLAN and choosing TCP/IP v4 from the installed service
TCP/IP on Laptop
-IP: 10.0.0.1
-Subnet: 255.255.255.0
TCP/IP on iPhone
-Static IP
-IP: 10.0.0.2
Now try searching for Wireless through your phone, you should able to connect..
Please leave me comment, if you need further assistance
Rnj VINODKUMAR
Nov 01, 2009 | Computers & Internet
Wireless connection problem
When you say "IP and DNS settings are correct", can you define what "correct" is? IP and DNS settings change depending on the wireless network they're using, so one setting will not work for all networks. The most "correct" setting you can have is probably DHCP - which is called "Obtain IP address automatically" and the same for DNS. If your laptop has any statically assigned IP information, make a note of what they are, and then change it to DHCP and see if you have better luck. If you have statically assigned IP information, it will allow you to connect to the wireless network, but not provide internet access because your IP scheme and DNS settings are wrong. It sounds like the scenario you're describing.
May 17, 2009 | Dell Inspiron 8000 Notebook
Printing to a network via wireless router
Usually wireless routers prohibit master browser (network neighborhood) communications from traversing between the wireless and wired computers. You can usually overcome this by setting a static ip address for the computers with the printers so that they are not a moving target (addresses are always changing with DHCP). Then you can use UNC paths to get from wireless computer to your target on internal network. For example, to connect to printer (with shared name BrotherH) on a wired computer with static ip address of 192.168.0.19, on wireless computer create a network printer and manually enter the address \\192.168.0.19\BrotherH , now the wireless computer should be able to traverse and connect to the wired printer.
Your wireless router should have a pool of static ip addresses available, say 192.168.1.1-49, you can specify this to your liking, and then you can also have a block of handed out DHCP numbers, say 192.168.50-60 or whatever.
Jan 26, 2009 | Linksys Wireless-G WRT54G Router
Cannot log on to dwl2000ap
If the SSID changed to the default then you know that the router reset to the default settings and you should set your computer to automatically get its IP address via DHCP. I always set up my routers through a Wired connection first, just to setup the router and then go with the wireless. The default for the router should be 192.168.0.1 and subnet 255.255.255.0 . If the computer is set with a static IP address, change it to obtain an IP address automatically or the network card will not bother even looking for an address.
Aug 17, 2008 | D-Link AirPlus Xtreme G DWL-2000AP...
Can't access my DSC 950G security camera
you have to log into the main IP address, not the camera IP address. If you are using wireless, the camera will have an IP address different than the one for the router coming from the ISP.
I just bought this camera myself and am trying to work out the kinks. My ip keeps changing and i am not sure how to keep it the same, static?
Jun 02, 2008 | Black Box IP Address Translator With...
Zonet ZSR0104CP (zsr0104cp) Router Logo
64 people viewed this question
Top Zonet Computers & Internet Experts
Prashant M
Prashant M
KG John Justin
KG John Justin
Are you a Zonet Computer and Internet Expert? Answer questions, earn points and help others
