Need parts for mita ai2310 developer gears & bushings
  • 97 Answers
Let me know your location?
Posted on Sep 22, 2008
RICOH MP 3350B ask for toner even having a new one
Take out the toner cartridge and shake it vigorously. When they sit for a long time the powder tends to clump.
Nov 19, 2014 | Ricoh Office Equipment & Supplies
Mita ai 2310 prints grey background
adjust main charge voltage down in service mode, or replace developer.
Jun 17, 2014 | Kyocera Mita AI2310 Drum Only
Kyocera mita 1620 failuire to work due to error message C2000
Drive motor problem
LOCK ALM signal remains high for 1 s, 1
s after the drive motor has turned on.
Poor contact in the
main motor connector
terminals.
Reinsert the connector. Also check for continuity
within the connector cable. If none,
remedy or replace the cable.
Defective drive
motor rotation control
circuit.
Replace the drive motor.
Defective drive
transmission system.
Check if the rollers and gears rotate
smoothly. If not, grease the bushings and
gears. Check for broken gears and replace if
any.
May 21, 2014 | Kyocera Mita Drum Cleaning Blade Km 1620...
TIme for Maintenance error code on Mita PointSource ai2310 copier. What does it mean and how do I reset it?
The printer must be cleaned and the elements inspected by a professional at regular intervals and the worn (or the ones which life has come to an end) parts replaced - like a service on a car, a big job.
This can be done only by a repairman of a dealer, you will have to call one.
Jun 06, 2011 | Office Equipment & Supplies
Kyocera FS-3900DN Ecosys Call Service 2200:0100998 Help please our printer has stopped working
The Call Service 2200 is a drum motor error. The motor or gears might need to be replaced. First remove and re-seat both the developer and the drum unit. The developer is directly under the toner cartridge - lift it up then out first, then open left side door remove the waste bin and press the button on the drum unit just above the waste bin pull the unit out (carefull not to touch the drum surface). Re-seat both units. If this does not work call in a Kyocera Tech.
May 07, 2010 | Kyocera Mita KYOCERA/MITA - FS-3900DN Mono...
-Laser Printer printing NEAR blank pages\
if this is an fs3900 tray rerunning the developer thru the machine.
Do this by going into the menus..up and down untill you see others..than right arrow..now up and down untill you see service...right arrow..than up and down untill you see developer..once you see developer hit enter twice...power off than back on machine..it will than recoat the mag roller with toner...good luck
Jan 30, 2010 | Kyocera Mita KYOCERA/MITA - FS-3900DN Mono...
KYOCERA KM2020 erreur C-4000
cause
Defective harness between drum motor and engine PWB (YC11), or
improper connector insertion.
solution
Reinsert the connector. Also check for continuity within the connector harness. If none,remedy or replace the harness.
cause
Defective drum motor drive transmission system.
solution
Check if the gears rotate smoothly. If not,grease the bushings and gears. Check for broken gears and replace if any.
cause
Defective drum motor.
solution
Replace the drum motor.
cause
Defective engine
PWB.
solution
Replace the engine PWB
Oct 26, 2009 | Kyocera Mita KYOCERA/MITA - FS-4000DN Mono...
Require a part number
call a copier company specializing in keyoceria they took over mita
Apr 23, 2009 | Kyocera Mita Office Equipment & Supplies
29 people viewed this question
jasbo
jasbo
