Question about Goldstar MV-1526 Microwave Oven
Door Latch Well so my wife broke the latch to the microwave. I tried glueing but that didn't work. I have a Gold Star MV1501W and I don't know where to buy the latch. Can anyone help?
  • FIXIT626 Oct 01, 2008
    Ok now how do i get the door off? ha ha
  • Goldstar Master
  • 9,085 Answers
For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit them here.
Goldstar owner's manuals can be downloaded here.
Posted on Sep 25, 2008
  • William Miller
    William Miller Oct 01, 2008
    Normally
    you have to separate the door panels (as shown in the attached photo)
    and then you'll see the previously hidden screws you need to remove.
    Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
The door latch broke
Slightly different model, but this will help you fix it.
https://m.youtube.com/watch?v=JqeeGBhRwFw
Feb 06, 2016 | Samsung SMH2117S
Pushed in spring loaded latch on the microwave. Need to pull it back out. Spring is not broke.
No, you don't have a new problem to fix, and consider yourself and anyone else that uses that microwave lucky.
Depending on where that crack is you need to know that the screen like structor in the door is actually a choke to stop and microwave energy from escaping, including anything around it. They are designed to stop any stray microwave energy from leaving the microwave. This could harm you so if it is anyware near that door choke, if I were you I would order another door. The same goes for the gasket around the inside of the door it to is a choke.
You are also causing yourself some potential danger because the door must never be circumvented to keep the light on or off because if you should accidently start the microwave then you will have problems.
Apr 09, 2014 | GE SpaceMaker Microwave Ovens
Why does the light / safety switch stay on when the door latches shut ?
Most likely there is a part missing from the door latch mechanism that you need. This probably broke off when the handle failed. It would be a tab or wedge shaped piece of plastic that strikes the door switch and pushes the switch closed when the door is completely shut. You will need to find that piece and glue it back on or get a new handle assembly from Samsung.
Aug 01, 2012 | Samsung Microwave Ovens
I have a door latch on my whirlpool microwave that has broke several times. We have glued it back several times due to I am a cheap *** and don't want to buy the whole door. Well luckily my dad lo
Please Heidi,
FOR SAFETY REASONS...
It is vital that you have all covers in place and the MICROWAVE fully contained at all times when operating.
You have a high frequency radio there...
It is best to always have a substantial amount (like a cup of water) to absorb the energy...
The best thing that can happen with the energy... it will turn back on the magnetron (source) and COOK ITSELF...
The worst... you will be feeling your own
eyeballs getting WARM.
BE SAFE (please).
Carnac the Magnificent
Apr 25, 2017 | Microwave Ovens
The locker (latch) on my microwave broke. We just got the replacement part in the mail. Sears says we should be able to replace it ourselves. I see no screws to get inside the door. Does the plastic flange...
If there are no screws to hold the inside door cover in place then they are probably using snap or lock in tabs around the edges to hold it
in place. You will have to disassemble the door to replace the door latch. ----------
Its a latch spring assembly.-------- Click this link below and follow the door lock latch replacing procedure:---- http://technoanswers.blogspot.com/2011/07/how-to-replace-door-lock-latch-on.html ------------------- This will help.Thanks.Helpmech.
Jul 14, 2011 | Microwave Ovens
KitchenAid KCMS145J Microwave Door Latch Broke
I downloaded a parts schematic of the door latch assembly and thought I would determine the broken part, order a replacement and install same. As soon as I started to remove the shell of the unit to get at the latch assembly, I discovered non-standard fasteners are used. My wife advised me to stop and take it to a service center because she did not want me to mess up the containment of the radiation! Thanks for your interest. MB
Sep 04, 2009 | KitchenAid KCMS145J Microwave Oven
Door latch and Screen
This is because of the broken latch. There are switches inside the oven that are operated by the door latches to make sure you're not trying to use the oven with the door open. With the new door, your oven should be back to normal.
Feb 06, 2009 | Whirlpool Microwave Ovens
GoldStar MV1501-W taking door off
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Oct 01, 2008 | Microwave Ovens
Panasonic s550bf Door Latch
Do you still have the piece that broke off? If so, you may be able to use two part epoxy to glue it back in place. I did this with a colaric MW and it did the trick. The latch was hook shaped and made from a hard plastic. Pete
Sep 02, 2007 | Sharp R-1610 Microwave Oven
The door will not latch
The latch head (with hooklike projections) have a spring to keep it pulled down. If the latch head can be easily pushed up and falls back freely, then the monting tab on the back of the latch head is broken and it will have to be glued or replaced. The new part is better. To get to the door screws inside, you have to remove the choke cover, as shown in the photo. You can order parts for Sharp models from Tritronics at http://www.wehaveparts.com.
Aug 31, 2007 | Sharp R-1480 Microwave Oven
Goldstar MV-1526 Microwave Oven Logo
82 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
