Question about Microsoft Xbox 360 Console
Not reading discs
When i put in the disc it fails to read and makes a rubbin noise
  • 59 Answers
It could be the console is sitting on a weird angle, does it scratch the disc?
Posted on Sep 23, 2008
I have a 95 impreza and there is a squeeking noise colming from the engine when i turn the wheel , if the wheel is straight there is no noise but the moment i turn the wheel this noise comes its sounds...
Check power steering fluid, belt condition and belt tension. As soon as you move steering wheel it puts a load on the system, and these are the 3 most common reasons for noise.
Apr 09, 2011 | 1995 Subaru Impreza
My MacBook Pro won't read discs. ''mhmmm'' noise.
Hi Quilly There are two possible scenarios. 1. the lens on the cd drive is dirty and needs a clean , and 2. the drive itself has failed.
1 is easy to fix with a lens cleaning CD on a tray loading drive but is a bit more difficult on the slot-loader as the brush on the CD makes it rather difficult to insert. 2 needs a workshop and a new drive.
Apr 25, 2010 | Apple Computers & Internet
Ps3 is not reading my discs
Hi my name is Juan and the problem you got is with the bluray laser lens they have stopped reading games you can check this out put a cd on your ps3 and at the same time place your ear on top cover and will heard 3 clicking noises of the laser but make no noise because this clicking noise is so fine that you need to make no noise it goes click click click you will hear it but make sure you put your ear on top cover at the same time you insert the disk it takes about 3 -4 seconds for the clinking noise after you have insert the cd some lasers they do try to read and they make the disk to spin off and on some they do make the disk to spin normally but nothing happen and the solution is to replace the laser lens I am a ebay trusted power seller and I can get you one if you want to
Mar 27, 2009 | Sony Playstation 3 (PS3) Console
Psp3002 when the disc inserted, it made a sound
ok soyou psp made a funny sound when you were loading it up. hmmm i would say you might have a problem wit your disc reader. try other games and see if makes the same noise or doesn't make a noise it used to do like the high spinning revolutions the disc spins at. if it isnt moving then you need to get it fixed because your lense reader have probably shititself from things like smoke ashes or watrer or even heat.
Jan 01, 2009 | Computers & Internet
2002 toyota highlander transmission
First check your transmission fluid level improper fluid level is the number one cause of trans failure, you need to check it with the vehicle warmed up, on flat ground, i accidently checked mine while it was tilted in my driveway and i got a false reading on the dipstick. The fluid should have a reddish color too it, if it is light brown, its time to get it serviced, if it is dark brown or black and you can feel gritty particles while rubbin it between your fingers, your transmission is toast.
Dec 13, 2008 | 2002 Toyota Highlander
Revving noise-wont record
Turns out the rubber disc grip on the spindle simply needs to be cleaned (using an alcohol wipe). This is the part that holds the disc firm while it's spinning...the noise and failed disc reads comes from this rubber getting dirty and allowing the disc to slip. Total time to fix including disassembly was less than 15 minutes!
Aug 16, 2008 | Panasonic DMR-ES10 DVD Recorder
Unit failed to read any discs
My unit all of a sudden fails to read any discs. It just makes noises that sounds like something is stuck. Then gives the message that its a proper disc. Its says no read.
Jun 20, 2008 | Panasonic DMR-ES25 DVD Recorder
Unable to read wii discs
I had the same problem, I take it you have a modded wii(chipped), if you use a backup disc it is of a lower quality then original discs, the wii gets read errors without you noticing and tries to read those disc areas again sometimes suceeding and the gaming goes on, sometimes it fails, and a disc read error occurs. Over time the dvd assembly will take some damage it will loose it rigidity it once had and the wii stops reading discs. The problem gets worse if you have standing up, so first thing si to flip it down and try. Otherwise you (or someone you trust) will have to open the wii and adjust the lens sled so it wont flap as much up and down. Hope this helps..
Oct 01, 2007 | Nintendo Wii Console
Microsoft Xbox 360 Console Logo
32 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
